Solar panel for FC
03-31-2007, 12:51
Solar panel for FC
I would like to install a solar charger on my FC and am looking for
suggestions on which model to buy, where to mount the panel, and how to
run the wiring down from the roof. Anyone install one on their FC?
Scott Forman
82 FC35RB
Memphis
03-31-2007, 13:25
Solar panel for FC
Iwould run the wiring down the fridge vent its a straight from top to
bottom on its close the the bin with the chargers
Stephen 77fc35
> Scott Forman
> 82 FC35RB
> Memphis
03-31-2007, 15:11
Solar panel for FC
Got two biguns on the roof, 20" X 48" wires down the refer chimney to controller
in side compartment with inverter and 4 AGMs.
Mike Hohnstein
Germantown, WI
83FC35 rear bath
Sent: Saturday, March 31, 2007 6:51 PM
Subject: [WanderlodgeForum] Solar panel for FC
Scott Forman
82 FC35RB
Memphis
03-31-2007, 16:28
Solar panel for FC
I am running off of memory here as I sold this coach to Dave Beatty.
On my then 83 FC35 with a 120 Watt solar panel, the cable was
drilled down through roof at the very front, behind the front
overhead.
A remote display panel was installed in the front overhead. The
cable then ran down the driver side far front left channel at the
windshield, which led down very near the front left battery location.
This worked out very well. From the drivers seat, or while seated
in the front salon, the solar remote display panel was clearly
visible. It was also the most direct feed to the FC battery bank at
front left.
Dan now 94 BB BMC 37'
NM
how to
> Scott Forman
> 82 FC35RB
> Memphis
03-31-2007, 16:28
Solar panel for FC
What brand did you use?
to controller in side compartment with inverter and 4 AGMs.
> Mike Hohnstein
> Germantown, WI
> 83FC35 rear bath
> From: Scott Forman
for
how to
> Scott Forman
> 82 FC35RB
> Memphis
03-31-2007, 16:38
Solar panel for FC
Evergreen
MH
Sent: Saturday, March 31, 2007 10:28 PM
Subject: [WanderlodgeForum] Re: Solar panel for FC
> Mike Hohnstein
> Germantown, WI
> 83FC35 rear bath
> From: Scott Forman
for
how to
> Scott Forman
> 82 FC35RB
> Memphis
