Constant Door Chime
04-04-2007, 04:39
Constant Door Chime
Gregory you're not nearly old enough to remember that movie.
Sent: Tuesday, April 03, 2007 3:06 PM
Subject: [WanderlodgeForum] Re: Constant Door Chime
Keith, Kevin is thinking you are using the wrong switch. You need a
momentary switch like the old starter buttons; the moment you push-
it makes contact, the moment you release- it loses contact. If the
doorbell button you are using now clicks when pushed, it may unclick
when pushed the second time. That would be a POPO switch
I am looking for a door bell chime that rings like the NewMoon
trailer in the LongLong Trailer movie.
GregoryO'Connor
94PTRomolandCa
--- In
WanderlodgeForum@yahoogroups.com,
"Keith Strehle"
> Okay, I got it. SPST = Single Pole Single Throw. A SPST momentary
> switch returns to its normally open (off) position when you release
> the button. A standard doorbell switch. It doesn't solve the
problem
> (yet) but I know what it is now...
> Thanks, Keith
> 84FC35
> --- In
krminyl@ wrote:
> > Are you sure it's a momentary, SPST push button switch? What
> happens when
> > you disconnect both wires from the switch? Does the chime
stop?
> Touch the
> > wires together, does the chime turn on again? If so, your
switch
> is the wrong
> > type. Use a multimeter on the switch contacts, and see what the
> switch does.
> > The switch could be grounded also, with one of the poles being
> momentary
> > "on" and the other always "on" always and off when pushed.
> > Kevin Mc
> > Yorba Linda, CA
> > 86 38 PT
> > ************************************** See what's free at
> http://www.aol.com.<http://www.aol.com./>
04-04-2007, 06:05
Constant Door Chime
Hey Shane, I just called Nutone. The told me to go to Radio Shack
and pick up diode 1N4002 thru 1N4009. They said any of them will
work. I'll pick one up and let you know what happens.
Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@...>
> Hi Keith,
> That same thing happened to me- I believe that it has something
to
> do with the original door chime button being an "insulated" switch.
> Most of the newer residential ones are mounted to wood brick molding
> or a non-grounded aluminum screen door frame. In a residential
> application, this doesn't matter because the door frame is not
> grounded, so if the metal housing for a residential switch contacts
> the spring mechanism in the doorbell- nothing happens. On our
coaches,
> however, this creates problems because the skin of the coach serves
as
> a ground and as soon as you attach to new doorbell, the switch
grounds
> itself. Bluebird appears to have used an insulated switch mechanism
> where the spring does not contact the metal switch housing. I'd like
> to replace mine too, but it's not very high on the priorities list
so
> I did not pursue it. Please let us know if you find a suitable
> replacement.
> Shane Fedeli
> 85PT40
> Hershey, PA
> --- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> > It's a standard door bell switch from Home Depot. It releases
when
> > you stop pushing. But even if you pushed it down and held it
there
> > the bell should stop ringing until you push it again. Otherwise
> > every kid in the hood would be taping your dooebell button down!
> > It's a basic doorbell switch just like the one in my house.
There
> > must be something else to this story. ?????????
> > Keith
> > 84FC35
> > --- In WanderlodgeForum@yahoogroups.com, "Gregory OConnor"
need a
push-
> > unclick
> > > GregoryO'Connor
> > > 94PTRomolandCa
> > momentary
> > release
> > > problem
> > > > Thanks, Keith
> > > > 84FC35
What
> > > > happens when
> > > stop?
> > > > Touch the
> > > switch
> > > > is the wrong
what
> > the
> > > > switch does.
> > being
> > > > momentary
> > > > > Kevin Mc
> > > > > Yorba Linda, CA
> > > > > 86 38 PT
> > > > http://www.aol.com.
04-04-2007, 10:53
Constant Door Chime
Keith. Not sure if this will help you but, I got courious with all this door
chime talk, seeing as mine didn't work either. Mine was a 2 part problem. First
thing I did was to throw in a new set of batteries. I pressed the switch, and
nothing. So I took of the cover of the chime, and jumped the 2 wires and still
nothing. I took the chime off of the wall and dug out the booklet for it and
started reading it. On the back , right under the part where it basicly says
it's going to outlive you, there was what appeared to be some type of rectifier
taped to the book. The scotch tape was rather yellow and brittle so not sure if
it was a factory issue or not, but anyway, I took the circut board out of the
plastic housing, and the groundstrap, for one of the batteries fell out on the
dinette table It looked like someone had dissassembled it and while
reassembling, maybe put a little too much pressure on the tabs ( you have to do
this to get the board back in) I soldered the tab back
on and traced down the location of the diode rectifier It fits in the D9 slot
marked on the circut board. I was going to solder the new one in but decided to
put it back together, I jumped the terminals while it was on the table, and off
it went. I installed it back on the wall and again tried it, with the switch,
and nothing. I removed the switch (mine has a brass rectangled backing plate
about 1 1/4" x 2 1/2" or so, with a white button that looks like it should
light. I threw my ohm meter across the terminals while on the bench, and pressed
the button, and no change on the meter, which told me the switch was open. I
layed the switch horizontally and sprayed CRC Powerlube in the button. I like to
use this lube for a few reasons. It's dielectric, which means you can use it in
electrical switches, and dries after a day or so, so when you spray it inside
your ignition switch, you can put your keys in your pocket, without staining
your clothes.lol I use this on anything that
moves. It works real well on the drawer slides etc. Anyway I started pressing
the button with the meter connected and after about a dozen times the meter
started to move, the switch was stuck open, after a few more times moving it it
was working fine. I tested also for a grounded switch and it wasn't grounded at
the button, it's insulated, I installed it back on the bus and although no light
it works just fine, I think the light is not servicable, it looked sealed. I
hope this helps.
Jimmy Harvie
82FC 35 SB
Boston Ma
Keith
84FC35
> Hi Keith,
to
coaches,
as
grounds
so
> replacement.
> Shane Fedeli
> 85PT40
> Hershey, PA
when
there
There
> > Keith
> > 84FC35
need a
push-
> > unclick
> > > GregoryO'Connor
> > > 94PTRomolandCa
> > momentary
> > release
> > > problem
> > > > Thanks, Keith
> > > > 84FC35
What
> > > > happens when
> > > stop?
> > > > Touch the
> > > switch
> > > > is the wrong
what
> > the
> > > > switch does.
> > being
> > > > momentary
> > > > > Kevin Mc
> > > > > Yorba Linda, CA
> > > > > 86 38 PT
> > > > http://www.aol.com.
Never miss an email again!
Yahoo! Toolbar alerts you the instant new Mail arrives. Check it out.
04-04-2007, 11:13
Constant Door Chime
Mine does not have batteries in it. But it still works from the
button on the unit. Actually, it works fine from the remote button,
except that it won't stop. The folks at Nutone said to attach the
diode on the button teminals then attach the wires and it should
work. The diodes are availabble at Radio Shack. Only problem is
they come 25 to a package. The good news is they are $2.59 per
package. So, if you or anyone else needs a door bell diode....
Keith
84FC35
--- In WanderlodgeForum@yahoogroups.com, James Harvie
this door chime talk, seeing as mine didn't work either. Mine was a 2
part problem. First thing I did was to throw in a new set of
batteries. I pressed the switch, and nothing. So I took of the cover
of the chime, and jumped the 2 wires and still nothing. I took the
chime off of the wall and dug out the booklet for it and started
rectifier taped to the book. The scotch tape was rather yellow and
brittle so not sure if it was a factory issue or not, but anyway, I
took the circut board out of the plastic housing, and the
groundstrap, for one of the batteries fell out on the dinette table
It looked like someone had dissassembled it and while reassembling,
the D9 slot marked on the circut board. I was going to solder the new
one in but decided to put it back together, I jumped the terminals
while it was on the table, and off it went. I installed it back on
the wall and again tried it, with the switch, and nothing. I removed
the switch (mine has a brass rectangled backing plate about 1 1/4" x
2 1/2" or so, with a white button that looks like it should light. I
pressed the button, and no change on the meter, which told me the
switch was open. I layed the switch horizontally and sprayed CRC
Powerlube in the button. I like to use this lube for a few reasons.
It's dielectric, which means you can use it in electrical switches,
and dries after a day or so, so when you spray it inside your
staining your clothes.lol I use this on anything that
started pressing the button with the meter connected and after about
a dozen times the meter started to move, the switch was stuck open,
after a few more times moving it it was working fine. I tested also
for a grounded switch and it wasn't grounded at the button, it's
insulated, I installed it back on the bus and although no light it
sealed. I hope this helps.
Jimmy Harvie
82FC 35 SB
Boston Ma
Radio Shack
> Keith
> 84FC35
> --- In WanderlodgeForum@yahoogroups.com, "sfedeli3" <sfedeli3@>
> > Hi Keith,
> to
switch.
molding
contacts
> coaches,
serves
> as
> grounds
mechanism
like
list
> so
> > replacement.
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> when
> there
down!
> There
> > > Keith
> > > 84FC35
> need a
> push-
If
> the
> > > unclick
NewMoon
> > > > GregoryO'Connor
> > > > 94PTRomolandCa
> > > momentary
> > > release
> > > > problem
> > > > > Thanks, Keith
> > > > > 84FC35
> What
> > > > > happens when
> > > > stop?
> > > > > Touch the
> > > > switch
> > > > > is the wrong
> what
> > > the
> > > > > switch does.
> > > being
> > > > > momentary
> > > > > > Kevin Mc
> > > > > > Yorba Linda, CA
> > > > > > 86 38 PT
> > > > > http://www.aol.com.
out.
04-04-2007, 17:49
Constant Door Chime
When the door bell is next on the list of repairs, the friggin bus must
be road ready. Mount a knocker and go RV'n
GregoryO'Connor
94ptRomolandCa
04-04-2007, 21:52
Constant Door Chime
Hi Keith,
Mine is 12V like yours. Are you saying to solder the diode between
the two contacts on the back of the new switch? What polarity is
recommended? Sounds like an easy fix and I already have a really nice
bronze switch to try out.
-Shane Fedeli
85PT40
Hershey, PA
> Keith
> 84FC35
> Jimmy Harvie
> 82FC 35 SB
> Boston Ma
> Radio Shack
> > Keith
> > 84FC35
> > wrote:
> > > Hi Keith,
> > to
> switch.
> molding
> contacts
> > coaches,
> serves
> > as
> > grounds
> mechanism
> like
> list
> > so
> > > replacement.
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
> > when
> > there
> down!
> > There
> > > > Keith
> > > > 84FC35
> > need a
> > push-
> If
> > the
> > > > unclick
> NewMoon
> > > > > GregoryO'Connor
> > > > > 94PTRomolandCa
> > > > momentary
> > > > release
> the
> > > > > problem
> > > > > > Thanks, Keith
> > > > > > 84FC35
> > What
> > > > > > happens when
> > > > > stop?
> > > > > > Touch the
> > > > > switch
> > > > > > is the wrong
> > what
> > > > the
> > > > > > switch does.
> > > > being
> > > > > > momentary
> > > > > > > Kevin Mc
> > > > > > > Yorba Linda, CA
> > > > > > > 86 38 PT
> > > > > > http://www.aol.com.
> out.
04-05-2007, 03:40
Constant Door Chime
A door knocker! Dang! I never thought of that! Greg, this doorbell
thing is one of those little things you think will be an easy fix. A
new doorbell button and in five minutes, done. It didn't work out
that way and became more like a challenge. We all have them.
Your're a pretty intelligent guy. Tell me whay it doesn't work like
it's supposed to?
Thanks, Keith
84FC35
must
> GregoryO'Connor
> 94ptRomolandCa
04-05-2007, 04:24
Constant Door Chime
The Nutone tech support person said to "attach" the diode to the
terminals. No mention of polarity? I'm going to wrap the diode
wires around the terminal screws, hook it up and see what happen. If
it doesn't work, I'm out $2.59....
> Hi Keith,
nice
> -Shane Fedeli
> 85PT40
> Hershey, PA
button,
> > Keith
> > 84FC35
all
a 2
cover
says
type of
I
table
reassembling,
fits in
new
terminals
on
removed
1/4" x
light. I
reasons.
switches,
about
open,
also
it
> > Jimmy Harvie
> > 82FC 35 SB
> > Boston Ma
> > Radio Shack
will
> > > Keith
> > > 84FC35
> > > wrote:
> > > > Hi Keith,
something
> > > to
> > switch.
> > molding
> > contacts
> > > coaches,
> > serves
> > > as
switch
> > > grounds
> > mechanism
I'd
> > like
> > list
> > > so
> > > > replacement.
> > > > Shane Fedeli
> > > > 85PT40
> > > > Hershey, PA
releases
> > > when
it
> > > there
Otherwise
> > down!
> > > There
> > > > > Keith
> > > > > 84FC35
You
> > > need a
you
> > > push-
contact.
> > If
> > > the
may
> > > > > unclick
> > NewMoon
> > > > > > GregoryO'Connor
> > > > > > 94PTRomolandCa
> > > > > momentary
you
> > > > > release
solve
> > the
> > > > > > problem
> > > > > > > Thanks, Keith
> > > > > > > 84FC35
switch?
> > > What
> > > > > > > happens when
chime
> > > > > > stop?
> > > > > > > Touch the
your
> > > > > > switch
> > > > > > > is the wrong
see
> > > what
> > > > > the
> > > > > > > switch does.
poles
> > > > > being
> > > > > > > momentary
pushed.
> > > > > > > > Kevin Mc
> > > > > > > > Yorba Linda, CA
> > > > > > > > 86 38 PT
free at
> > > > > > > http://www.aol.com.
it
> > out.
04-05-2007, 04:38
Constant Door Chime
The first item in the Nutone online FAQ is:
What is the small electronic part that comes with the LA-52WH?
It is a diode that needs to be put across the button that connects to the front
terminals. The diode is polarized. If it does not work when first installed,
then reverse the diode.
>wrote:
>> Hi Keith,
>nice
>> -Shane Fedeli
>> 85PT40
>> Hershey, PA
>button,
>the
>> > Keith
>> > 84FC35
>all
>a 2
>cover
>the
>says
>type of
>and
>I
>table
>reassembling,
>fits in
>new
>terminals
>on
>removed
>1/4" x
>light. I
>reasons.
>switches,
>about
>open,
>also
>it
>> > Jimmy Harvie
>> > 82FC 35 SB
>> > Boston Ma
>> > Radio Shack
>will
>> > > Keith
>> > > 84FC35
>> > > wrote:
>> > > > Hi Keith,
>something
>> > > to
>> > switch.
>> > molding
>> > contacts
>> > > coaches,
>> > serves
>> > > as
>switch
>> > > grounds
>> > mechanism
>I'd
>> > like
>> > list
>> > > so
>> > > > replacement.
>> > > > Shane Fedeli
>> > > > 85PT40
>> > > > Hershey, PA
>releases
>> > > when
>it
>> > > there
>Otherwise
>> > down!
>> > > There
>> > > > > Keith
>> > > > > 84FC35
>You
>> > > need a
>you
>> > > push-
>contact.
>> > If
>> > > the
>may
>> > > > > unclick
>> > NewMoon
>> > > > > > GregoryO'Connor
>> > > > > > 94PTRomolandCa
>> > > > > momentary
>you
>> > > > > release
>solve
>> > the
>> > > > > > problem
>> > > > > > > Thanks, Keith
>> > > > > > > 84FC35
>switch?
>> > > What
>> > > > > > > happens when
>chime
>> > > > > > stop?
>> > > > > > > Touch the
>your
>> > > > > > switch
>> > > > > > > is the wrong
>see
>> > > what
>> > > > > the
>> > > > > > > switch does.
>poles
>> > > > > being
>> > > > > > > momentary
>pushed.
>> > > > > > > > Kevin Mc
>> > > > > > > > Yorba Linda, CA
>> > > > > > > > 86 38 PT
>free at
>> > > > > > > http://www.aol.com.
>it
>> > out.
>Yahoo! Groups Links
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
04-05-2007, 05:00
Constant Door Chime
Thanks Don, it's a small project but didn't make sense so I couldn't
just drop it. One of the others here Shane(?) mentioned that he
found a diode taped to the booklet that came with his Nutone door
chime.
Thanks, Keith
84FC35
to the front terminals. The diode is polarized. If it does not work
when first installed, then reverse the diode.
If
> >wrote:
> >> Hi Keith,
between
> >nice
> >> -Shane Fedeli
> >> 85PT40
> >> Hershey, PA
> >button,
> >the
should
is
per
> >> > Keith
> >> > 84FC35
with
> >all
was
> >a 2
> >cover
> >the
started
basicly
> >says
> >type of
> >and
anyway,
> >I
> >table
> >reassembling,
do
> >fits in
> >new
> >terminals
back
> >on
> >removed
> >1/4" x
> >light. I
CRC
> >reasons.
> >switches,
I
> >about
> >open,
> >also
it's
light
> >it
looked
> >> > Jimmy Harvie
> >> > 82FC 35 SB
> >> > Boston Ma
to
> >> > Radio Shack
> >will
> >> > > Keith
> >> > > 84FC35
<sfedeli3@>
> >> > > wrote:
> >> > > > Hi Keith,
> >something
> >> > > to
an "insulated"
> >> > switch.
brick
> >> > molding
residential
not
> >> > contacts
our
> >> > > coaches,
coach
> >> > serves
> >> > > as
> >switch
> >> > > grounds
> >> > mechanism
housing.
> >I'd
> >> > like
priorities
> >> > list
> >> > > so
suitable
> >> > > > replacement.
> >> > > > Shane Fedeli
> >> > > > 85PT40
> >> > > > Hershey, PA
> >releases
> >> > > when
held
> >it
> >> > > there
> >Otherwise
button
> >> > down!
house.
> >> > > There
> >> > > > > Keith
> >> > > > > 84FC35
OConnor"
switch.
> >You
> >> > > need a
moment
> >you
> >> > > push-
> >contact.
> >> > If
> >> > > the
it
> >may
> >> > > > > unclick
switch
> >> > NewMoon
> >> > > > > > GregoryO'Connor
> >> > > > > > 94PTRomolandCa
Strehle"
SPST
> >> > > > > momentary
when
> >you
> >> > > > > release
> >solve
> >> > the
> >> > > > > > problem
> >> > > > > > > Thanks, Keith
> >> > > > > > > 84FC35
> >switch?
> >> > > What
> >> > > > > > > happens when
> >chime
> >> > > > > > stop?
> >> > > > > > > Touch the
so,
> >your
> >> > > > > > switch
> >> > > > > > > is the wrong
> >see
> >> > > what
> >> > > > > the
> >> > > > > > > switch does.
> >poles
> >> > > > > being
> >> > > > > > > momentary
> >pushed.
> >> > > > > > > > Kevin Mc
> >> > > > > > > > Yorba Linda, CA
> >> > > > > > > > 86 38 PT
> >free at
> >> > > > > > > http://www.aol.com.
removed]
Check
> >it
> >> > out.
> >Yahoo! Groups Links
> Don Bradner
> Eureka, CA
