Leaking fresh water tank
04-18-2007, 08:09
Art I had a leak in my water filter under the bed last year. When I
winterized I blew out the lines then put pink stuff in from the pump. It didn't
get to the water filter. It had a real fine leak under pressure. It was hard to
see.
Don
89 SP 36'
Butler, PA
Art, just curious but do you have a hot water tank under your bed?
On 18/04/07, amweath <_amweatherly@amweatherly_
(mailto:amweatherly@...) > wrote:
> Being as how the fresh water tank was empty, I thought I'd sanitize
> it using the method described in the Bluebird manual. On entering the
> coach the next morning I found the carpet on the right side of the bed
> wet.Am I in big trouble? I've removed the mattress and the plywood
> covering. It doesn't look like any of the plumbing is leaking. The next
> step is to try and lift the tank out (it has been drained).Has anyone
> done this? I'm wondering how much of the bed frame has to be taken
> apart. Can these tanks be patched?
> Art Weatherly
> Riverside Ca
> '85 PT 36.
04-18-2007, 09:23
Art Weatherly
Riverside Ca
'85 PT 36.
04-18-2007, 10:04
> Art Weatherly
> Riverside Ca
> '85 PT 36.
Rob, Sue & Merlin Robinson
94 WLWB
04-18-2007, 12:32
The hot water tank is not under the part I've uncovered (the rear 2 feet of the
bed still has its plywood cover.
Art Weatherly
Riverside Ca.
'85 PT 36
Sent: Wednesday, April 18, 2007 3:04 PM
Subject: [SPAM] Re: [WanderlodgeForum] Leaking fresh water tank
> Art Weatherly
> Riverside Ca
> '85 PT 36.
94 WLWB
04-18-2007, 14:21
Art,
When you filled the water tank, did you fill it to the full reading on
the water tank gauge and stop filling there, or did you fill it to
running out of the overflow?
The water heater is most likely under the area you have not removed the
plywood.
Curt Sprenger
Anaheim Hills, Calif.
> feet of the bed still has its plywood cover.
> Art Weatherly
> Riverside Ca.
> '85 PT 36
> From: Rob Robinson
> > Art Weatherly
> > Riverside Ca
> > '85 PT 36.
> 94 WLWB
04-18-2007, 14:43
If you filled it full, the overflow tube may leak at the connection to
the top of the tank.
BIll 88 FC
--- In WanderlodgeForum@yahoogroups.com, "amweath"
next
> Art Weatherly
> Riverside Ca
> '85 PT 36.
