Step Solenoid Valve
04-19-2007, 10:06
Step Solenoid Valve
Does anyone have a schematic of the internal workings of the step
Solenoid valve. Also, it has two pins or needles which appear to be adjustable. I have a small air leak at one of those pins. The solenoid clicks with 120 psi air and the step does not move. Every switch makes the solenoid click. Open the door and it clicks. The safety strip makes the valve click. I'm wondering if the thing is stuck somehow. I can see the valve on the drawings but nothing more. Thanks for any info. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL |
04-19-2007, 13:17
Step Solenoid Valve
Thank you. I will get after it when I get it out of the shop.
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: rogerwwebb To: WanderlodgeForum@yahoogroups.com Sent: Thursday, April 19, 2007 8:22 PM Subject: [WanderlodgeForum] Re: Step Solenoid Valve I do not have a schematic of the step solenoid, however, I recently had a problem with my step not fully opening and locking into place. I was advised by another forum member to remove the air valves (spark plug looking devices)on the bottom of the solenoid and clean them up. This fixed the problem. Seems some 'crud' was clogging up the valves. The adjustments on the two valves increases or decreased the speed of opening and closing. Roger Webb 91WBWL Cedar Rapids, IA [Non-text portions of this message have been removed] |
04-19-2007, 13:22
Step Solenoid Valve
a problem with my step not fully opening and locking into place. I was advised by another forum member to remove the air valves (spark plug looking devices)on the bottom of the solenoid and clean them up. This fixed the problem. Seems some 'crud' was clogging up the valves. The adjustments on the two valves increases or decreased the speed of opening and closing. Roger Webb 91WBWL Cedar Rapids, IA |
