racor fuel flow gauge
05-03-2005, 11:03
once the Racor filter gets full enough to cause an increased vacume
the gauge registers high as a warning. Then when the new filter is put in place the gauge will reduce some, but not much.I simply diconnect the tube to the gauge to release the vacume and the gauge then returns to normal. If the gauge goes back up to warning area again, better start looking for other restrictions in fuel lines. Harvey Lawrence |
