Checker cab as a tow car?
05-03-2005, 22:31
Anyone out there know if the Checker cab can be flat towed?
Mel MEllinger
85PT36
Fort Lauderdale
05-03-2005, 23:48
--- In WanderlodgeForum@yahoogroups.com, "offngo" <melmellinger@m...>
> Mel MEllinger
> 85PT36
> Fort Lauderdale
only if it has a standard transmission. an automatic would be the same
as any other car.
Harvey
05-04-2005, 00:09
If it has the turbo 350 or 400 Transmission or a powerglide 2 speed
you have to install a driveshaft disconnect
Stephen
Cape0001 77fc35
> Mel MEllinger
> 85PT36
> Fort Lauderdale
05-04-2005, 02:42
I think the Checker used GM small block engines and 350/400
transmissions for many years. If the Checker you have in mind uses
this drivetrain, then the towing requirements should be the same as a
GM vehicle of the same period.
If the Checker front end will track 4-down (not a given) then the worst
case setup would be an auxillary transmission oil pump or a driveline
disconnect.
Bob Griesel
> Mel MEllinger
> 85PT36
> Fort Lauderdale
Loading...
