zf transmission no engagement
05-04-2005, 12:58
Hi,
I have 1987fc with a zf transmission. I am having infamous problem of the tranny not engaging, I have lots of neutrals. I have gone over some of the past posts, it seems that a common problem is low voltage to the ECM. Where would I check this at, and is there anything that I can check Thanks Ron Hazlett 1987fc Ohio |
05-04-2005, 13:04
feel free to call I had this fixed this this year on my 88fc
mark 310 560 4454 --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" wrote: > Hi, > I have 1987fc with a zf transmission. I am having infamous problem of > the tranny not engaging, I have lots of neutrals. I have gone over > some of the past posts, it seems that a common problem is low voltage > to the ECM. Where would I check this at, and is there anything that I > can check > > Thanks > Ron Hazlett > 1987fc > Ohio |
05-04-2005, 14:26
I had this same problem several years ago on my 88 fc. Turned out a
spring had broken on the push button linkage under the control box. I replaced the spring and problem was solved. Ray Pander 88 FC Ohio --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > Hi, > I have 1987fc with a zf transmission. I am having infamous problem of > the tranny not engaging, I have lots of neutrals. I have gone over > some of the past posts, it seems that a common problem is low voltage > to the ECM. Where would I check this at, and is there anything that I > can check > > Thanks > Ron Hazlett > 1987fc > Ohio |
05-04-2005, 14:35
The first thing to try is the TPS (Throttle Position Sensor). It is a
rheostat/sensor connected to a throttle cable, mounted to the outside- rear (rear of coach) of the battery box. If the sensor is not returning to the idle position (jammed, broken return spring, cable came loose, etc.) the transmission will think the throttle is wide-open and not shift into gear. - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > Hi, > I have 1987fc with a zf transmission. I am having infamous problem of > the tranny not engaging, I have lots of neutrals. I have gone over > some of the past posts, it seems that a common problem is low voltage > to the ECM. Where would I check this at, and is there anything that I > can check > > Thanks > Ron Hazlett > 1987fc > Ohio |
05-05-2005, 00:58
Ron,
I also have an 87FC35. I had the same problem and it was resolved by fixing the Throttle Position Sensor spring - as Jeff Miller has noted. Even though you already have the right answer, I just wanted to let you know to call me anytime to discuss 87FC issues, my number is in the database. - Rick 87FC35 Rochester, MN --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > Hi, > I have 1987fc with a zf transmission. I am having infamous problem of > the tranny not engaging, I have lots of neutrals. I have gone over > some of the past posts, it seems that a common problem is low voltage > to the ECM. Where would I check this at, and is there anything that I > can check > > Thanks > Ron Hazlett > 1987fc > Ohio |
05-05-2005, 13:27
Thanks to Mark,Jeff,Ray and rick for the help with my tranny problem.
The problem was a corroded plug connection on the throttle position sensor. I cleaned it up, then wraped with electrical tape to keep out moisture. Its nice to have the Tranny shifting again! Thanks Ron Hazlett 1987fc Ohio |
05-05-2005, 13:32
Whew! You had me worried for a while there, ...
- Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "Ron Hazlett" > Thanks to Mark,Jeff,Ray and rick for the help with my tranny problem. > The problem was a corroded plug connection on the throttle position > sensor. I cleaned it up, then wraped with electrical tape to keep out > moisture. Its nice to have the Tranny shifting again! > > Thanks > Ron Hazlett > 1987fc > Ohio |
05-05-2005, 14:51
Ron, If its not too much work to dig back into, instead of just electrical tape,
I'd use the liquid electrical tape out not to really seal out the moisture. Mark, 80FC35 PA for now Ron Hazlett Thanks to Mark,Jeff,Ray and rick for the help with my tranny problem. The problem was a corroded plug connection on the throttle position sensor. I cleaned it up, then wraped with electrical tape to keep out moisture. Its nice to have the Tranny shifting again! Thanks Ron Hazlett 1987fc Ohio --------------------------------- Yahoo! Groups Links To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
05-05-2005, 22:37
Mark Garber wrote:
> Ron, If its not too much work to dig back into, instead of just > electrical tape, I'd use the liquid electrical tape out not to really > seal out the moisture. > > Mark, 80FC35 PA for now > > > Thanks , Mark I will look into getting a bottle. Ron Hazlett 1987fc Ohio > > > |
