If using BB paint codes, double check before painting.
05-17-2007, 15:10
We had to perform a small amount of body work and have one panel
repainted on our '88 WB40. Pulled the paint code from the plate mounted in the engine compartment and found out the code didn't match the body paint color. If you're doing any body painting(on your coach, not otherwise) I would double check the codes and color before painting. A minor lesson learned for me. Drew May '88 WB40 Southern Style IV Conway, AR |
05-17-2007, 15:19
Yeah, I hear you. We had our coach repainted and chose official
Bluebird colors. Dark Rose, Light Rose and Indian Silver... Looks great, but now I wish, (since we repainted the whole thing), that I had of chosen stock auto colors similar to the BB colors.. That way, matching spray cans of these colors are avalable at any Kragen, Pep Boys or Autozone.. Jack Smith 1973 FC 31 SoCal --- In WanderlodgeForum@yahoogroups.com, "dam71967" > > We had to perform a small amount of body work and have one panel > repainted on our '88 WB40. Pulled the paint code from the plate > mounted in the engine compartment and found out the code didn't match > the body paint color. If you're doing any body painting(on your coach, > not otherwise) I would double check the codes and color before > painting. A minor lesson learned for me. > > Drew May > '88 WB40 > Southern Style IV > Conway, AR > |
05-17-2007, 15:20
Same for me Drew. Of the five colours only one code was correct. I don't
know what gives but this is a common fault that I've heard several others complain about. I gave up and had my colours shot with one of those paint cameras. I've got some good touch-up paint now and some numbers that are reliable. On 17/05/07, dam71967 > > We had to perform a small amount of body work and have one panel > repainted on our '88 WB40. Pulled the paint code from the plate > mounted in the engine compartment and found out the code didn't match > the body paint color. If you're doing any body painting(on your coach, > not otherwise) I would double check the codes and color before > painting. A minor lesson learned for me. > > Drew May > '88 WB40 > Southern Style IV > Conway, AR > > > -- Rob, Sue & Merlin Robinson 94 WLWB [Non-text portions of this message have been removed] |
05-17-2007, 16:00
Just curious. Are your paint colors BASF paint? They would typically be
identified by a 5 digit number. ie. 81735 is a rose tone. 79773 is Silver. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack & Donna Smith To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 10:19 PM Subject: [WanderlodgeForum] Re: If using BB paint codes, double check before painting. Yeah, I hear you. We had our coach repainted and chose official Bluebird colors. Dark Rose, Light Rose and Indian Silver... Looks great, but now I wish, (since we repainted the whole thing), that I had of chosen stock auto colors similar to the BB colors.. That way, matching spray cans of these colors are avalable at any Kragen, Pep Boys or Autozone.. Jack Smith 1973 FC 31 SoCal --- In WanderlodgeForum@yahoogroups.com, "dam71967" > > We had to perform a small amount of body work and have one panel > repainted on our '88 WB40. Pulled the paint code from the plate > mounted in the engine compartment and found out the code didn't match > the body paint color. If you're doing any body painting(on your coach, > not otherwise) I would double check the codes and color before > painting. A minor lesson learned for me. > > Drew May > '88 WB40 > Southern Style IV > Conway, AR > [Non-text portions of this message have been removed] |
05-18-2007, 01:34
No, they began with letters and I thought the code started with LF.
Leroy Eckert curious. Are your paint colors BASF paint? They would typically be identified by a 5 digit number. ie. 81735 is a rose tone. 79773 is Silver. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack & Donna Smith To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 10:19 PM Subject: [WanderlodgeForum] Re: If using BB paint codes, double check before painting. Yeah, I hear you. We had our coach repainted and chose official Bluebird colors. Dark Rose, Light Rose and Indian Silver... Looks great, but now I wish, (since we repainted the whole thing), that I had of chosen stock auto colors similar to the BB colors.. That way, matching spray cans of these colors are avalable at any Kragen, Pep Boys or Autozone.. Jack Smith 1973 FC 31 SoCal --- In WanderlodgeForum@yahoogroups.com, "dam71967" > > We had to perform a small amount of body work and have one panel > repainted on our '88 WB40. Pulled the paint code from the plate > mounted in the engine compartment and found out the code didn't match > the body paint color. If you're doing any body painting(on your coach, > not otherwise) I would double check the codes and color before > painting. A minor lesson learned for me. > > Drew May > '88 WB40 > Southern Style IV > Conway, AR > [Non-text portions of this message have been removed] --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. [Non-text portions of this message have been removed] |
05-20-2007, 15:43
I have been on the road this weekend.
I have a can of Indian Silver Met in front of me. R-M Diamont manufactured by BASF a German Corp. Code 79773 My Rose metallic also has a 5 digit code. No letters. Don't want to bother you just wondering. I have seen several posts about paint problems. It took me awhile but I figured it out. Base coat clear coat is really not that difficult to work with. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Drew May To: WanderlodgeForum@yahoogroups.com Sent: Friday, May 18, 2007 8:34 AM Subject: Re: [WanderlodgeForum] Re: If using BB paint codes, double check before painting. No, they began with letters and I thought the code started with LF. Leroy Eckert BASF paint? They would typically be identified by a 5 digit number. ie. 81735 is a rose tone. 79773 is Silver. Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jack & Donna Smith To: WanderlodgeForum@yahoogroups.com Sent: Thursday, May 17, 2007 10:19 PM Subject: [WanderlodgeForum] Re: If using BB paint codes, double check before painting. Yeah, I hear you. We had our coach repainted and chose official Bluebird colors. Dark Rose, Light Rose and Indian Silver... Looks great, but now I wish, (since we repainted the whole thing), that I had of chosen stock auto colors similar to the BB colors.. That way, matching spray cans of these colors are avalable at any Kragen, Pep Boys or Autozone.. Jack Smith 1973 FC 31 SoCal --- In WanderlodgeForum@yahoogroups.com, "dam71967" > > We had to perform a small amount of body work and have one panel > repainted on our '88 WB40. Pulled the paint code from the plate > mounted in the engine compartment and found out the code didn't match > the body paint color. If you're doing any body painting(on your coach, > not otherwise) I would double check the codes and color before > painting. A minor lesson learned for me. > > Drew May > '88 WB40 > Southern Style IV > Conway, AR > [Non-text portions of this message have been removed] --------------------------------- Don't be flakey. Get Yahoo! Mail for Mobile and always stay connected to friends. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
