Aux Batt solenoid on PT
05-27-2007, 02:02
Hmmm..."what is your problem"...there's a wide ranging question....
Really I don't have a problem right now. I am just trying to learn
my new coach. I knew my old FC inside and out, and that gave me some
confidence that if I ever had a problem on the road, maybe I could
diagnose it & fix it. I want to feel that way about my PT, too. I
also want to make sure that the charging circuit is charging the
generator battery as it is supposed to.
Scott
--- In WanderlodgeForum@yahoogroups.com, wrote:
> Scott,
> May I be so bold as to ask what is your problem?
> Howard Truitt
> Camilla, Ga.
> 86 PT40
> > From: "Scott Forman" <sforman@...>
> > Date: 2007/05/26 Sat PM 08:17:02 EDT
> > To: WanderlodgeForum@yahoogroups.com
> > Subject: [WanderlodgeForum] Re: Aux Batt solenoid on PT
> > OK...a little help...
> > There are solenoids all over the place. There's one on the front
> > wall of the batter charger compartment. There are two others on
> > metal panel that folds down to give access to the charger
> > compartment. And there are three of them behind the step well,
> > although it looks like two of them are for the leveling pump.
None
> > of these make the audible "click" when I hit the Aux Batt
switch.
> > The drawings in my Blue Box aren't as comprehensive as they were
in
> > my FC, so I am having trouble figuring all this out.
> > Help!
> > Scott Forman
> > 86 PT38
> > > Scott,
> > > On my 86 PT40 mine is in the compartment with the chargers. But
> > knowing BB and your coach being a 38 footer it may be different.
> > > Howard Truitt
> > > Camilla, Ga.
> > > 86 PT40
> > > > From: "Scott Forman" <sforman@>
> > > > Date: 2007/05/26 Sat PM 02:53:55 EDT
> > > > Subject: [WanderlodgeForum] Aux Batt solenoid on PT
> > > > Where is the auxillary battery solenoid on a PT?
> > > > Scott Forman
> > > > 86 PT38
05-27-2007, 02:20
Scott,
That's a good idea. I am electrically and mechanically challenged. I had a
problem with my generator battery not charging that part I was able to diagnose.
I suspected the diode but had no idea where it was located. I was told it was up
front in the battery compartment, was under the coach up front, was near the
breaker box at the generator. I finally found it in the charger compartment in
the rear.
Turns out my problem was a blown 30 amp circuit breaker. I am also the proud
owner of a new diode and a new solenoid.
Howard Truitt
Camilla, Ga.
86 PT40
> Date: 2007/05/27 Sun AM 10:02:55 EDT
> Scott
> > Scott,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> the
> None
> switch.
> in
> > > Help!
> > > Scott Forman
> > > 86 PT38
> > > > Scott,
> > > > Howard Truitt
> > > > Camilla, Ga.
> > > > 86 PT40
> > > > > Scott Forman
> > > > > 86 PT38
05-27-2007, 02:32
Scott,
Have you used your multimeter and checked the voltage at the gen.
battery? First before you start the gen. Than again after the gen. is
running. The increase in voltage when the gen. is running tells you
that the charge circuit is working. No change in voltage, or lower,
you know the charge is not working.
Curt Sprenger
Anaheim Hills, Calif.
> Scott
> , wrote:
> > Scott,
> > Howard Truitt
> > Camilla, Ga.
> > 86 PT40
> the
> None
> switch.
> in
> > > Help!
> > > Scott Forman
> > > 86 PT38
> , wrote:
> > > > Scott,
> > > > Howard Truitt
> > > > Camilla, Ga.
> > > > 86 PT40
> > > > > Scott Forman
> > > > > 86 PT38
05-27-2007, 10:38
OK, the voltage went up with the gen running. So I guess the circuit
works.
Scott
> Scott,
is
you
lower,
> Curt Sprenger
question....
some
> > Scott
> > , wrote:
> > > Scott,
> > > Howard Truitt
> > > Camilla, Ga.
> > > 86 PT40
front
on
> > the
> > None
> > switch.
were
> > in
> > > > Help!
> > > > Scott Forman
> > > > 86 PT38
> > , wrote:
> > > > > Scott,
But
different.
> > > > > Howard Truitt
> > > > > Camilla, Ga.
> > > > > 86 PT40
> > > > > > Scott Forman
> > > > > > 86 PT38
05-27-2007, 10:56
Agree. Good.
Do the same test using shore power.
Curt Sprenger
> works.
> Scott
> , Curt Sprenger
> > Scott,
> is
> you
> lower,
> > Curt Sprenger
> question....
> some
> > > Scott
> > > , wrote:
> > > > Scott,
> > > > Howard Truitt
> > > > Camilla, Ga.
> > > > 86 PT40
> front
> on
> > > the
> > > None
> > > switch.
> were
> > > in
> > > > > Help!
> > > > > Scott Forman
> > > > > 86 PT38
> > > , wrote:
> > > > > > Scott,
> But
> different.
> > > > > > Howard Truitt
> > > > > > Camilla, Ga.
> > > > > > 86 PT40
> > > > > > > Scott Forman
> > > > > > > 86 PT38
05-27-2007, 11:05
Isn't it all one circuit?
> Agree. Good.
> Curt Sprenger
circuit
> > works.
> > Scott
> > , Curt Sprenger
> > wrote:
> > > Scott,
gen.
gen.
> > is
> > you
> > lower,
> > > Curt Sprenger
> > question....
learn
me
> > some
could
too. I
> > > > Scott
> > > > , wrote:
> > > > > Scott,
> > > > > Howard Truitt
> > > > > Camilla, Ga.
> > > > > 86 PT40
> > front
others
> > on
> > > > the
well,
pump.
> > > > None
> > > > switch.
they
> > were
> > > > in
> > > > > > Help!
> > > > > > Scott Forman
> > > > > > 86 PT38
> > > > , wrote:
> > > > > > > Scott,
chargers.
> > But
> > different.
> > > > > > > Howard Truitt
> > > > > > > Camilla, Ga.
> > > > > > > 86 PT40
> > > > > > > > Scott Forman
> > > > > > > > 86 PT38
05-27-2007, 11:11
TO be assured that the gen battery is charging under all conditions,
check with the shore power, then generator running , then the engine
alternator running and charging.
Bill 88 FC Michigan
> > Agree. Good.
> > Curt Sprenger
> circuit
> > > works.
> > > Scott
> > > , Curt Sprenger
> > > wrote:
> > > > Scott,
> gen.
> gen.
> > > is
tells
> > > you
> > > lower,
> > > > Curt Sprenger
> > > question....
to
> learn
gave
> me
> > > some
I
> could
> too. I
charging
> the
> > > > > Scott
> > > > > , > wrote:
> > > > > > Scott,
> > > > > > Howard Truitt
> > > > > > Camilla, Ga.
> > > > > > 86 PT40
> > > front
> others
> > > on
> > > > > the
charger
step
> well,
> pump.
> > > > > None
Batt
> > > > > switch.
> they
> > > were
> > > > > in
> > > > > > > Help!
> > > > > > > Scott Forman
> > > > > > > 86 PT38
> > > > > , > wrote:
> > > > > > > > Scott,
> chargers.
> > > But
> > > different.
> > > > > > > > Howard Truitt
> > > > > > > > Camilla, Ga.
> > > > > > > > 86 PT40
> > > > > > > > > Scott Forman
> > > > > > > > > 86 PT38
05-27-2007, 11:24
And what voltage should it show when charging?
--- In WanderlodgeForum@yahoogroups.com, "pattypape"
conditions,
engine
> Bill 88 FC Michigan
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@>
> > wrote:
> > > Agree. Good.
> > > Curt Sprenger
> > circuit
> > > > works.
> > > > Scott
> > > > , Curt Sprenger
> > > > wrote:
> > > > > Scott,
> > gen.
> > gen.
> > > > is
> tells
> > > > you
> > > > lower,
> > > > > Curt Sprenger
> > > > question....
> to
> > learn
> gave
> > me
> > > > some
maybe
> I
> > could
PT,
> > too. I
> charging
> > the
> > > > > > Scott
> > > > > > , > > wrote:
> > > > > > > Scott,
> > > > > > > Howard Truitt
> > > > > > > Camilla, Ga.
> > > > > > > 86 PT40
PT
on
> the
> > > > front
> > others
> > > > on
> > > > > > the
> charger
> step
> > well,
leveling
> > pump.
> > > > > > None
> Batt
> > > > > > switch.
as
> > they
> > > > were
> > > > > > in
> > > > > > > > Help!
> > > > > > > > Scott Forman
> > > > > > > > 86 PT38
> > > > > > , > > wrote:
> > > > > > > > > Scott,
> > chargers.
> > > > But
> > > > different.
> > > > > > > > > Howard Truitt
> > > > > > > > > Camilla, Ga.
> > > > > > > > > 86 PT40
PT
> > > > > > > > > > Scott Forman
> > > > > > > > > > 86 PT38
05-27-2007, 11:28
The charging source varies...gen, shore, engine alternator. Additional
wiring, etc. for each source.
Curt Sprenger
> , Curt Sprenger
> > Agree. Good.
> > Curt Sprenger
> circuit
> > > works.
> > > Scott
> > > , Curt Sprenger
> > > wrote:
> > > > Scott,
> gen.
> gen.
> > > is
> > > you
> > > lower,
> > > > Curt Sprenger
> > > question....
> learn
> me
> > > some
> could
> too. I
> the
> > > > > Scott
> > > > > , > wrote:
> > > > > > Scott,
> > > > > > Howard Truitt
> > > > > > Camilla, Ga.
> > > > > > 86 PT40
> > > front
> others
> > > on
> > > > > the
> well,
> pump.
> > > > > None
> > > > > switch.
> they
> > > were
> > > > > in
> > > > > > > Help!
> > > > > > > Scott Forman
> > > > > > > 86 PT38
> > > > > , > wrote:
> > > > > > > > Scott,
> chargers.
> > > But
> > > different.
> > > > > > > > Howard Truitt
> > > > > > > > Camilla, Ga.
> > > > > > > > 86 PT40
> > > > > > > > > Scott Forman
> > > > > > > > > 86 PT38
05-27-2007, 11:29
Absolutely correct Bill.
Curt Sprenger
> Bill 88 FC Michigan
> , Curt Sprenger
> > wrote:
> > > Agree. Good.
> > > Curt Sprenger
> > circuit
> > > > works.
> > > > Scott
> > > > , Curt Sprenger
> > > > wrote:
> > > > > Scott,
> > gen.
> > gen.
> > > > is
> tells
> > > > you
> > > > lower,
> > > > > Curt Sprenger
> > > > question....
> to
> > learn
> gave
> > me
> > > > some
> I
> > could
> > too. I
> charging
> > the
> > > > > > Scott
> > > > > > , > > wrote:
> > > > > > > Scott,
> > > > > > > Howard Truitt
> > > > > > > Camilla, Ga.
> > > > > > > 86 PT40
> the
> > > > front
> > others
> > > > on
> > > > > > the
> charger
> step
> > well,
> > pump.
> > > > > > None
> Batt
> > > > > > switch.
> > they
> > > > were
> > > > > > in
> > > > > > > > Help!
> > > > > > > > Scott Forman
> > > > > > > > 86 PT38
> > > > > > , > > wrote:
> > > > > > > > > Scott,
> > chargers.
> > > > But
> > > > different.
> > > > > > > > > Howard Truitt
> > > > > > > > > Camilla, Ga.
> > > > > > > > > 86 PT40
> > > > > > > > > > Scott Forman
> > > > > > > > > > 86 PT38
