Back-up camera
06-09-2007, 05:58
Back-up camera
I posted earlier about my rear view camera working fine until the
generator was turned on, then going static on the screen. Agter a little more research, I figured out it isn;t the generator. The culprit is the "electronics master" switch that controls power the the digital clocks, digitel, etc. When it is off, the camera works fine, when it is on, it goes to static. Ideas? Scott Forman 86 PT38 |
06-09-2007, 08:31
Back-up camera
I had a similar problem with my stereo radio on certain frequencies after I
installed my new camera systems and turned them on. Static taking the frequency off line. I wrapped the power wires to the LCD's with aluminum tape and have not seen the problem since. That doesn't mean it has cured it. So far so good. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Saturday, June 09, 2007 12:58 PM Subject: [WanderlodgeForum] Back-up camera I posted earlier about my rear view camera working fine until the generator was turned on, then going static on the screen. Agter a little more research, I figured out it isn;t the generator. The culprit is the "electronics master" switch that controls power the the digital clocks, digitel, etc. When it is off, the camera works fine, when it is on, it goes to static. Ideas? Scott Forman 86 PT38 [Non-text portions of this message have been removed] |
