Perkins fuel injector pump.
06-12-2007, 12:28
A while ago I posted that mine was leaking. The engine starts, runs,
and leaks. I went to a mechanic today and he said there is an
inspection port that has allignment marks on it and that if these are
aligned with a mark on the housing, I should be able to remove that
pump and take it to a rebuild shop. Question: Has any of you done this?
I can take anything apart, but if it has to have timing marks alligned-
what can I expect or look for??
Thanks to all for this.
Ernie-83PT40 in Montana- why should this leak-- only has 6500 hours on
the clock???
06-12-2007, 20:31
Thank you very much, John. I did not realize that was an Allen head bolt in
the back of the pump. I , too, have lots of paint on the pump. Can you forward
some cash for the rebuild?? VBG!!
83PT40
Livingston, Mt
06-13-2007, 00:26
Good Morning Ernie,
I'm not sure what inspection port that the mechanic is talking about,
but I just recently removed and replaced the injector pump on my
Perkins and here are a couple of photo tips for you, the first one
will show you where those timing marks are located, believe me they
are very hard to see, check out;
http://www.pbase.com/iamflagman/image/80456505
The second photo tip will show you what it takes to remove the
backside bolt on the injector pump;
http://www.pbase.com/iamflagman/image/80456508
Be sure to follow the instructions on the injector pump removal found
in the Perkins Workshop Manual under SECTION N.
I will expect this repair to be completed on your injector pump and
ready for my inspection when I arrive up there next month :o)
JOHN FINN
1982 FC35RB BLUEBIRD WANDERLODGE
HOPKINS, SOUTH CAROLINA
VISIT THE FINN'S INN EXPRESS REMODELING ADVENTURE AND TECH. TIPS
http://www.pbase.com/image/24977457
--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg"
are
this?
alligned-
on
> the clock???
06-13-2007, 01:38
Ernie,
You might want to go to the Links section and look at the Perkins
Engine Repair Manual that is available online. It is a very big help.
1991 WB40 "Texas Minivan"
> the clock???
06-13-2007, 05:36
Thanks, Mike, will do.
83PT40
Livingston, Mt
