Generator not starting
06-19-2007, 00:05
For those of you who might be curious about my generator that would not
start I was able to find a solution at least temporarily. After
checking and determining that 12 volt was coming to the electric pump
during starter cranking but no fuel coming from the filter housing it
was thought that a new pump was in order. After conferring with Power
Tech they said any locally available pump that provided 4 to 11 PSI
would work. Being a tightwad I decided to try tapping on the side of
the pump with a metal object while my wife cranked the engine and to my
surprise it started right up and has worked flawlessly since. Thanks to
all who offered suggestions.
Alvie Miller
Arthur IL
1993 WLWB
15KW PowerTech Generator
06-19-2007, 14:54
Yup,
My old hot rod tool kit seems to have fixed your problem. We used
to keep a hammer and prophylactic in the tool kit. The premise
being 'if you can't fix it, F%$#@ it'
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "whynotam"
would not
pump
it
Power
PSI
of
to my
Thanks to
> Alvie Miller
> Arthur IL
> 1993 WLWB
06-19-2007, 16:06
> Yup,
used
> Gardner
> 78FC33
> would not
> pump
housing
> it
> Power
> PSI
> of
> to my
> Thanks to
> > Alvie Miller
> > Arthur IL
> > 1993 WLWB
One of heater stop working and with a little swift kick it started
right up! Now that's how to fix something!!!!!!!!!!!!!!!
