Guages needed
06-18-2007, 13:33
Guages needed
I need a transmission temp guage and a generator oil pressure guage for
my 1984 PT 40 with a detroit 6v92. Any ideas? Eddie Moranii |
06-19-2007, 11:56
Guages needed
Are you sure the gauges are bad? You can perform simple tests outlined at
ww2.tflx.com/tech.html to determine if it is the gauge, the sender or a wire problem. I am sure the gauges are Teleflex black faced International land type with white and amber index. Once you are certain let us know. I have spent the last month researching Teleflex International gauges and senders. The guages are available through BB, but not necessarily the correct senders. I will be posting the pn's as soon as I can figure out how to get a chart on the site. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: eddiemoranii To: WanderlodgeForum@yahoogroups.com Sent: Monday, June 18, 2007 8:33 PM Subject: [WanderlodgeForum] Guages needed I need a transmission temp guage and a generator oil pressure guage for my 1984 PT 40 with a detroit 6v92. Any ideas? Eddie Moranii [Non-text portions of this message have been removed] |
06-19-2007, 14:00
Guages needed
I believe that they are the Teleflex International, the only
difference is that the BlueBird gauges have a silver painted edge on the bezel. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Are you sure the gauges are bad? You can perform simple tests outlined at ww2.tflx.com/tech.html to determine if it is the gauge, the sender or a wire problem. I am sure the gauges are Teleflex black faced International land type with white and amber index. Once you are certain let us know. I have spent the last month researching Teleflex International gauges and senders. The guages are available through BB, but not necessarily the correct senders. I will be posting the pn's as soon as I can figure out how to get a chart on the site. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: eddiemoranii > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 18, 2007 8:33 PM > Subject: [WanderlodgeForum] Guages needed > > > I need a transmission temp guage and a generator oil pressure guage for > my 1984 PT 40 with a detroit 6v92. Any ideas? Eddie Moranii > > > > > > [Non-text portions of this message have been removed] > |
06-19-2007, 14:29
Guages needed
Yes, they are Teleflex International Line(Land). The new part numbers have a
different profile on the bezel but are easily painted silver with a paint stick to look very good. If the index has been changed the senders will need to be special ordered because BB has not changed the senders to comply with the index change. Otherwise, everything should match. ww2.tflx.com/search.html will show the various gauges and sender types available. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL ----- Original Message ----- From: Jeff Miller To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, June 19, 2007 9:00 PM Subject: [WanderlodgeForum] Re: Guages needed I believe that they are the Teleflex International, the only difference is that the BlueBird gauges have a silver painted edge on the bezel. - Jeff Miller --- In WanderlodgeForum@yahoogroups.com, "Leroy Eckert" > > Are you sure the gauges are bad? You can perform simple tests outlined at ww2.tflx.com/tech.html to determine if it is the gauge, the sender or a wire problem. I am sure the gauges are Teleflex black faced International land type with white and amber index. Once you are certain let us know. I have spent the last month researching Teleflex International gauges and senders. The guages are available through BB, but not necessarily the correct senders. I will be posting the pn's as soon as I can figure out how to get a chart on the site. > > Leroy Eckert > 1990 WB-40"Smoke N Mirrors" > Niceville, FL > ----- Original Message ----- > From: eddiemoranii > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, June 18, 2007 8:33 PM > Subject: [WanderlodgeForum] Guages needed > > > I need a transmission temp guage and a generator oil pressure guage for > my 1984 PT 40 with a detroit 6v92. Any ideas? Eddie Moranii > > > > > > [Non-text portions of this message have been removed] > [Non-text portions of this message have been removed] |
06-20-2007, 02:22
Guages needed
Ed,
Bluebird has some. If you go to the teleflex site they have a list of gauges, they also have a list of suppliers, I got some gauges from an outfit in NJ. Make sure that new gauge is indexed the same as old gauge if not you will need a new sender... Jim Riordan 88 WBWL XXV Stuart, Fl. eddiemoranii I need a transmission temp guage and a generator oil pressure guage for my 1984 PT 40 with a detroit 6v92. Any ideas? Eddie Moranii --------------------------------- Now that's room service! Choose from over 150,000 hotels in 45,000 destinations on Yahoo! Travel to find your fit. [Non-text portions of this message have been removed] |
