Mountain Driving with 1995 42', 42,000 lb. Blue Bird
06-25-2007, 07:12
Ron, I may be wrong but don't the newer coaches weigh more then the 42,000
pounds? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] |
06-25-2007, 07:28
This is a question that lots of people might want to explore. Would
someone with a lot of experience driving a big rig in the mountains please write up a good descriptive instruction for mountain driving. I have never driven in the big mountains with a normal vehicle much less a 42,000 lb motor coach. I am planning a trip through the mountains maybe this year but definitely next year from Texas through the Rockies and on up to Alaska. It would sure be helpful to have some pointers from an expert. Best regards, Ron Thompson |
06-25-2007, 10:43
Ron,
Seeing no response yet, I'll drop my two cents in and hope it's helpful to you. I have driven in the mountains frequently in my 84 Blue Bird that had a magnetic retarder and a coach with a more conventional Jake brake. The old rule of thumb is to come down in the same gear you came up in. Two caveats: One..modern engines and transmissions can come up a grade more easily than they used to..so your upgrade gear selection may be higher than what's safe coming down. Two...the down-grade can be different from the up-grade..so my take on it is..just be in full, positive control of your speed at all times. If you need to use your retarder or downshift to do that, do whatever it takes early on (before you start down the grade) to stay in control and save your service brakes (brake pedal) for traffic slowdowns and emergencies. If your retarder won't keep your speed under control, and you can't downshift yet, apply your brake pedal firmly but for no more than 3 to 5 seconds at a time to slow down a little below your "comfort" speed in a series of brake applications. If you have a magnetic retarder, be aware that it will build up considerable heat if used for several minutes..so downshift to help it out. I don't think your Jake brake or Pac brake is limited that way but a diesel mechanic can be more specific. Downshift sooner rather than later. Your transmission will not downshift beyond certain speeds. You can always ease off but it's hard to clamp down. Also, if the weather is warm, turn on your fan override switch and keep it on until you're back on level terrain. Keeping your engine cool helps your transmission cooler work more efficiently. Finnally, don't be in a hurry. Don't worry about the cars stacked up behind you. They'll get around you or get used to you. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: cockyfox@...: Mon, 25 Jun 2007 19:28:28 +0000Subject: [WanderlodgeForum] Mountain Driving with 1995 42', 42,000 lb. Blue Bird This is a question that lots of people might want to explore. Wouldsomeone with a lot of experience driving a big rig in the mountainsplease write up a good descriptive instruction for mountain driving.I have never driven in the big mountains with a normal vehicle muchless a 42,000 lb motor coach. I am planning a trip through themountains maybe this year but definitely next year from Texas throughthe Rockies and on up to Alaska. It would sure be helpful to havesome pointers from an expert.Best regards,Ron Thompson _________________________________________________________________ With Windows Live Hotmail, you can personalize your inbox with your favorite color. http://www.windowslive-hotmail.com/learn...T_TAG\ LM_HMWL_reten_addcolor_0607 [Non-text portions of this message have been removed] |
06-25-2007, 10:55
Ron I have a Class A license and spent a fair amount of time behind the
wheel of a Kenworth going back and forth over the grapevine (a long 6% grade in California). Big rigs and motor homes (buses) are different creatures. Big rigs often have 15 gears forward and 3 in reverse and run at 80,000 pounds. More gears equals better matching load to horsepower and engine braking ability. The best people to ask about mountain driving in a bluebird are the people on this site. I am assuming you have plenty of ponies, and an engine brake of some type. My basic rules are simple. 1) Make sure you vehicle is in good shape with proper tire pressure fluid levels, and brakes properly adjusted. 2) When going up grades keep your RPM high and watch your engine, transmission and axel temps. If anything starts to get hot downshift. 3) Be considerate of other driver truck and car. Pass only when you can move at least 5 miles per hr faster than the vehicle you are overtaking. Use the slow vehicle lane only if you are going slow, if you are going slow use vehicle turn outs as a courtesy to others. Some say to go down a hill (grade) in the same gear you came up, but that is not always true. Uphill is where you break things downhill is where you kill things. When starting down a steep grade 6% or so put the vehicle in a gear that will allow you to control your speed without overtaching the engine. The brakes are meant to slow the vehicle down use them. Old school was to apply the brakes hard and slow down then release the brakes to cool while you gain speed. The currently recommend method is to apply constant steady pressure to the brakes to maintain a safe speed ( one from which you could stop the vehicle with the distance allowed in front of you) down the grade. I agree with the second method, the first is for race cars. So when descending a grade. 1) shift to a lower gear and use your engine brake without overtaching. 2 ) apply steady continuous pressure to the brakes to slow the vehicle while keeping an eye on you air pressure. (if you smell brakes you are in too high of a gear) 3) Be careful overtaking slow moving vehicles. 4) watch out for idiots who think you can stop on a dime. 5) you are not under the same rules as the semi trucks i.e. Lane restrictions and speed limits. Drive at a speed that you feel is safe for you. I am sure there will be additional opinions, but just to tick them off they are wrong! Just kidding. Jim Hutchings From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ron Thompson Sent: Monday, June 25, 2007 12:28 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Mountain Driving with 1995 42', 42,000 lb. Blue Bird This is a question that lots of people might want to explore. Would someone with a lot of experience driving a big rig in the mountains please write up a good descriptive instruction for mountain driving. I have never driven in the big mountains with a normal vehicle much less a 42,000 lb motor coach. I am planning a trip through the mountains maybe this year but definitely next year from Texas through the Rockies and on up to Alaska. It would sure be helpful to have some pointers from an expert. Best regards, Ron Thompson [Non-text portions of this message have been removed] |
06-25-2007, 11:08
Thanks Jim, You are exactly the kind of person I was hoping would reply back.
You have made that trip many times and have a load of experience. I appreciate your answers very much, thank you. Regards Ron Thompson James Hutchings have a Class A license and spent a fair amount of time behind the wheel of a Kenworth going back and forth over the grapevine (a long 6% grade in California). Big rigs and motor homes (buses) are different creatures. Big rigs often have 15 gears forward and 3 in reverse and run at 80,000 pounds. More gears equals better matching load to horsepower and engine braking ability. The best people to ask about mountain driving in a bluebird are the people on this site. I am assuming you have plenty of ponies, and an engine brake of some type. My basic rules are simple. 1) Make sure you vehicle is in good shape with proper tire pressure fluid levels, and brakes properly adjusted. 2) When going up grades keep your RPM high and watch your engine, transmission and axel temps. If anything starts to get hot downshift. 3) Be considerate of other driver truck and car. Pass only when you can move at least 5 miles per hr faster than the vehicle you are overtaking. Use the slow vehicle lane only if you are going slow, if you are going slow use vehicle turn outs as a courtesy to others. Some say to go down a hill (grade) in the same gear you came up, but that is not always true. Uphill is where you break things downhill is where you kill things. When starting down a steep grade 6% or so put the vehicle in a gear that will allow you to control your speed without overtaching the engine. The brakes are meant to slow the vehicle down use them. Old school was to apply the brakes hard and slow down then release the brakes to cool while you gain speed. The currently recommend method is to apply constant steady pressure to the brakes to maintain a safe speed ( one from which you could stop the vehicle with the distance allowed in front of you) down the grade. I agree with the second method, the first is for race cars. So when descending a grade. 1) shift to a lower gear and use your engine brake without overtaching. 2 ) apply steady continuous pressure to the brakes to slow the vehicle while keeping an eye on you air pressure. (if you smell brakes you are in too high of a gear) 3) Be careful overtaking slow moving vehicles. 4) watch out for idiots who think you can stop on a dime. 5) you are not under the same rules as the semi trucks i.e. Lane restrictions and speed limits. Drive at a speed that you feel is safe for you. I am sure there will be additional opinions, but just to tick them off they are wrong! Just kidding. Jim Hutchings From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Ron Thompson Sent: Monday, June 25, 2007 12:28 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Mountain Driving with 1995 42', 42,000 lb. Blue Bird This is a question that lots of people might want to explore. Would someone with a lot of experience driving a big rig in the mountains please write up a good descriptive instruction for mountain driving. I have never driven in the big mountains with a normal vehicle much less a 42,000 lb motor coach. I am planning a trip through the mountains maybe this year but definitely next year from Texas through the Rockies and on up to Alaska. It would sure be helpful to have some pointers from an expert. Best regards, Ron Thompson [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
06-25-2007, 11:28
My BB has an engine retarder. I have no idea what that is exactly. I assume it
is using the compression of the engine to hold back the transmission which will hold back the BB What is a Jake Brake? I don't think my 1995 has a magnetic retarder. I remember once I was in Los Angeles and a cousin took me up on bald mountain in a 1949 Chevrolet, six cylinder, old hydraulic brakes. On the way down those brakes got so hot that the vehicle began to pick up speed and I managed to find a wide spot where I ran into an uphill ramp and got it stopped. Had to wait for a long long time for those brakes to cool off. Scared the hell out of me. Thanks for your help. Jim Hutchings wrote a pretty good description. He used to drive a big Kenworth with 80,000 lb loads. So his words were very welcome as yours are. Your experience will be very relevant since we both have BB's. Thanks again. Ron Thompson brad barton <bbartonwx@...> wrote: Ron, Seeing no response yet, I'll drop my two cents in and hope it's helpful to you. I have driven in the mountains frequently in my 84 Blue Bird that had a magnetic retarder and a coach with a more conventional Jake brake. The old rule of thumb is to come down in the same gear you came up in. Two caveats: One..modern engines and transmissions can come up a grade more easily than they used to..so your upgrade gear selection may be higher than what's safe coming down. Two...the down-grade can be different from the up-grade..so my take on it is..just be in full, positive control of your speed at all times. If you need to use your retarder or downshift to do that, do whatever it takes early on (before you start down the grade) to stay in control and save your service brakes (brake pedal) for traffic slowdowns and emergencies. If your retarder won't keep your speed under control, and you can't downshift yet, apply your brake pedal firmly but for no more than 3 to 5 seconds at a time to slow down a little below your "comfort" speed in a series of brake applications. If you have a magnetic retarder, be aware that it will build up considerable heat if used for several minutes..so downshift to help it out. I don't think your Jake brake or Pac brake is limited that way but a diesel mechanic can be more specific. Downshift sooner rather than later. Your transmission will not downshift beyond certain speeds. You can always ease off but it's hard to clamp down. Also, if the weather is warm, turn on your fan override switch and keep it on until you're back on level terrain. Keeping your engine cool helps your transmission cooler work more efficiently. Finnally, don't be in a hurry. Don't worry about the cars stacked up behind you. They'll get around you or get used to you. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: cockyfox@...: Mon, 25 Jun 2007 19:28:28 +0000Subject: [WanderlodgeForum] Mountain Driving with 1995 42', 42,000 lb. Blue Bird This is a question that lots of people might want to explore. Wouldsomeone with a lot of experience driving a big rig in the mountainsplease write up a good descriptive instruction for mountain driving.I have never driven in the big mountains with a normal vehicle muchless a 42,000 lb motor coach. I am planning a trip through themountains maybe this year but definitely next year from Texas throughthe Rockies and on up to Alaska. It would sure be helpful to havesome pointers from an expert.Best regards,Ron Thompson __________________________________________________________ With Windows Live Hotmail, you can personalize your inbox with your favorite color. http://www.windowslive-hotmail.com/learn...T_TAG\ LM_HMWL_reten_addcolor_0607 [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
06-25-2007, 11:32
I don't know about the new ones but mine is a 1995 and the body tag says 42,000
lbs. My guess would be that it is probably heavier than the new ones. They are taking weight out of them to cut the cost of production. Just my thoughts./ Regards, Ron Thompson erniecarpet@... wrote: Ron, I may be wrong but don't the newer coaches weigh more then the 42,000 pounds? Ernie Ekberg 83PT40 Livingston, Mt ************************************** See what's free at http://www.aol.com. [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
06-25-2007, 12:32
Ron, if you have a Allison HT-755 five speed with a retarder, I have
know advice, if you have a 1995-42' you should have a Allison HD-4060 and a DD series 60 with a 3 position Jacobs engine brake. Jacobs's brakes close the valves and turn the cylinder into a compressor creating braking horsepower, each position adds more cylinders. I haven't driven a 95 in the mountains but I have driven over a lot of the passes in the Cascades, Montana, Idaho and so on, but I can't imagine that if your in the right gear at the right RPM that the engine brake won't hold it back. For me with a less effective Pac Brake, it is 4th gear at 50 mph at about 2400 rpm's on a 6% or so, on a steeper grade it's 3 gear at 35-40 mph and I almost never have to use my air brakes. If I am in 4th and it starts to run away, faster that I like, I use the brakes to get the coach down to the speed that I can select the next lower gear. If the Jacobs brake doesn't hold you back, maybe there is something wrong with the Jacobs brake? As for the "Drum type" air brakes, if you have been on the road for a time and the ambient temp. is hot, and If you ride the brakes for a long period of time the drum can expand away from the shoe and you lose your brakes. With some real bad luck you could heat the wheel up so hot that it heats the tire up and blowout. Marty 95 BMC 37 Kennewick Wa |
06-25-2007, 12:47
Ron,
The truckers are certainly the pros and I have learned a lot from their experience. But Jim is right to mention RV's are different in many ways. I hadn't heard about holding the brakes on for longer than a few seconds. I wonder if newer brake shoe materials can handle that kind of heat better. Your magnetic retarder works on the principle of creating magnetic eddys or currents that resist the momentum of the metal in your drive shaft or differential. But like brakes, it converts motion into heat. It is a silent, elegant way to slow down your coach. The Jake brake is built into your engine. It creates back pressure in your diesel engine resisting the momentum of the pistons. It makes a lot of noise but works very well. The Pac brake is not as sophisticated or adjustable but does the same thing, only it's built into your exhaust system instead of the engine itself. As to questions about weight, I believe the early 2000 Birds were the heaviest. Mine grosses out at over over 50K, but BB has probably done a lot to cut a lot of the weight and much of the cost out of its newer coaches. Brad Barton 00LXiDFW bbartonwx@... _________________________________________________________________ Live Earth is coming. Learn more about the hottest summer event - only on MSN. http://liveearth.msn.com?source=msntaglineliveearthwlm [Non-text portions of this message have been removed] |
06-25-2007, 12:56
Ron,
One more ramble and I'll quit. Marty is right about heat. A dragging brake on a tour bus evacuating nursing home patients from Hurricane Rita in Houston, blew out one time on I-45. The driver didn't understand English, so he continued on after the tire was changed. The brake heated up again even in stop and go traffic. The wheel became red hot and caught the rear of the bus on fire. The driver failed to notice until portable oxygen tanks used by the patients began exploding. The bus turned into a crematorium for 24 of those patients. I'll never forget watching the bus burning up live on TV. Also, I left my magnetic retarder on by mistake in Flagstaff and nearly caught my 84 Bird on fire. I burned through the air line that operated the driver's seat slide. Imagine smoke coming from under your coach and you're struggling to get to the extinguisher with your seat next to the doghouse. Fire on a motorcoach is almost as serious as fire on board an airplane. Brad Barton 00LXiDFW bbartonwx@... To: WanderlodgeForum@...: martingregg598@...: Tue, 26 Jun 2007 00:32:18 +0000Subject: [WanderlodgeForum] Re: Mountain Driving with 1995 42', 42,000 lb. Blue Bird Ron, if you have a Allison HT-755 five speed with a retarder, I have know advice, if you have a 1995-42' you should have a Allison HD-4060 and a DD series 60 with a 3 position Jacobs engine brake. Jacobs's brakes close the valves and turn the cylinder into a compressor creating braking horsepower, each position adds more cylinders. I haven't driven a 95 in the mountains but I have driven over a lot of the passes in the Cascades, Montana, Idaho and so on, but I can't imagine that if your in the right gear at the right RPM that the engine brake won't hold it back. For me with a less effective Pac Brake, it is 4th gear at 50 mph at about 2400 rpm's on a 6% or so, on a steeper grade it's 3 gear at 35-40 mph and I almost never have to use my air brakes. If I am in 4th and it starts to run away, faster that I like, I use the brakes to get the coach down to the speed that I can select the next lower gear. If the Jacobs brake doesn't hold you back, maybe there is something wrong with the Jacobs brake? As for the "Drum type" air brakes, if you have been on the road for a time and the ambient temp. is hot, and If you ride the brakes for a long period of time the drum can expand away from the shoe and you lose your brakes. With some real bad luck you could heat the wheel up so hot that it heats the tire up and blowout.Marty95 BMC 37Kennewick Wa _________________________________________________________________ Play free games, earn tickets, get cool prizes! Join Live Search Club. http://club.live.com/home.aspx?icid=CLUB_wlmailtextlink [Non-text portions of this message have been removed] |
