Troubleshooting icemaker
07-03-2007, 09:02
My icemaker is getting cold and there's water in the line to the unit but no
water is flowing in to the icemaker. Any troublshooting hints. I'm guessing it's the valve that controls the flow of the water. Anything else I should be looking at? Kerry 82 FC 35 Denver |
07-03-2007, 09:15
Kerry,
You say "getting cold"...let it run a while longer, to freezing, and maybe the water valve will open. Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, Calif. davidkerryedwards wrote: > My icemaker is getting cold and there's water in the line to the unit > but no water is flowing in > to the icemaker. Any troublshooting hints. I'm guessing it's the valve > that controls the flow > of the water. Anything else I should be looking at? > > Kerry > 82 FC 35 > Denver > > |
07-03-2007, 09:26
Is the water pump on? More than once I have made this mistake.
Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > My icemaker is getting cold and there's water in the line to the unit but no water is flowing in > to the icemaker. Any troublshooting hints. I'm guessing it's the valve that controls the flow > of the water. Anything else I should be looking at? > > Kerry > 82 FC 35 > Denver > |
07-03-2007, 09:35
Water pump is on. It hadn't occurred to me that the unit would only let water
in once a freezing temperature was reached. I'll leave it on for a while. I took the water valve apart and it seems functional. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <sforman@...> wrote: > > Is the water pump on? More than once I have made this mistake. > > Scott Forman > 86 PT38 > Memphis |
07-03-2007, 09:38
Kerry, the water inlet valve is controlled by a timer/solenoid. If you
don't have ice in a while (you can hear it hit the container) check to make sure you have power to the solenoid. Mine sometimes has to set for a while before it starts up again. Has to do with the eject step I believe so that it completes a full cycle. Terry Neal Bozeman, MT 82PT40 6V92TA 74FC34 6V53T Scott Forman wrote: > Is the water pump on? More than once I have made this mistake. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com > > > > > > My icemaker is getting cold and there's water in the line to the unit > but no water is flowing in > > to the icemaker. Any troublshooting hints. I'm guessing it's the > valve that controls the flow > > of the water. Anything else I should be looking at? > > > > Kerry > > 82 FC 35 > > Denver > > > > [Non-text portions of this message have been removed] |
07-03-2007, 10:45
Kerry,
I am sure you looked, but I will ask anyway. Are you sure the pump is on and has not turned itself off? Al Johnson '96 BMC B100 Mandeville, Louisiana --- In WanderlodgeForum@yahoogroups.com, "davidkerryedwards" > > My icemaker is getting cold and there's water in the line to the unit but no water is flowing in > to the icemaker. Any troublshooting hints. I'm guessing it's the valve that controls the flow > of the water. Anything else I should be looking at? > > Kerry > 82 FC 35 > Denver > |
07-03-2007, 12:50
Well I don't know if it was because I disassembled and reassembled the solenoid
valve or because I let it run longer, but now it seems to be working. Kerry 82 FC 35 Denver--at 100 degrees and glad to have ice. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger > > Kerry, > You say "getting cold"...let it run a while longer, to freezing, and > maybe the water valve will open. > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. |
07-03-2007, 13:08
That is dry heat, huh? Wanna trade locations? I can leave tomorrow. lol
Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Today 90, Humidity 95% with T/S, no breeze except in T/S ----- Original Message ----- From: davidkerryedwards To: WanderlodgeForum@yahoogroups.com Sent: Tuesday, July 03, 2007 7:50 PM Subject: [WanderlodgeForum] Re: Troubleshooting icemaker Well I don't know if it was because I disassembled and reassembled the solenoid valve or because I let it run longer, but now it seems to be working. Kerry 82 FC 35 Denver--at 100 degrees and glad to have ice. --- In WanderlodgeForum@yahoogroups.com, Curt Sprenger wrote: > > Kerry, > You say "getting cold"...let it run a while longer, to freezing, and > maybe the water valve will open. > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, Calif. [Non-text portions of this message have been removed] |
