Round TV Turner
07-04-2007, 13:26
Round TV Turner
Stephen,
I finally got around to replaceing my dish I purchased from you at
the RATS Rally. Do I also need to replace the electonics inside the
bird or only the outside dish? I have tested the new dish with old
electronics and appears to work fine. Will I loose some features by
not replacing the inside electronics?
Al Johnson
'96 BMC B100
Mandeville, Louisiana
07-04-2007, 14:28
Round TV Turner
No you can use the same electronics. if you do not already have one
you can run wire to the bedroom and wire in the additional remote you
now have
using the screw terminal reading left to right then bottom row left to
right
use five cable control cable or door bell cable or telephonecable
1.yellow
2.black
3 white
4 brown
5 red
Stephen 77fc35
--- In WanderlodgeForum@yahoogroups.com, "Al" wrote:
> Stephen,
> Al Johnson
> '96 BMC B100
