Vipwheels - New replacement Steering Wheel
05-07-2005, 08:10
Good Afternoon ,
Emailed Vipwheels about a replacement wheel and costs.
Charlene requested the diameter, spline count, and part
number. I can get the diameter and spline count if I
can get the wheel off, my question is how ? The wheel is
loose both (right & left), plus telescoping (up & down).
Is that ok/normal to have about 2 to 4 inches of play
in its motion ? Part # ?
Thanks,
Gene
Judy & Gene Sharp
93' WL40' Ohio
05-07-2005, 08:43
On my 83 FC the horn button pops off with a little nudge from a flat headed
screwdriver (It's a switch, not a contact ring like a car, and has a wire
attached). Look down into the hole and there is about a 1 1/8" nut. remove the
nut and the wheel should come off with the proper wheel puller.
Keep us posted, I also need to replace my steering wheel with a smaller unit.
Something about that Law Of Physics that states My belly and the steering wheel
cannot occupy the same space at the same time.
Good Luck
Glenn Shehorn
83 FC 35
KCMO
Sent: Saturday, May 07, 2005 3:10 PM
Subject: [WanderlodgeForum] Vipwheels - New replacement Steering Wheel
Good Afternoon ,
Thanks,
Gene
Judy & Gene Sharp
93' WL40' Ohio
Yahoo! Groups Links
05-07-2005, 09:03
You will probably find you want a BB1 center on your steeing wheel
Stephen
Cape0001 77fc35
http://www.capeinnovation.com
--- In WanderlodgeForum@yahoogroups.com, "judy2gene"
> Good Afternoon ,
> Thanks,
> Gene
> Judy & Gene Sharp
> 93' WL40' Ohio
05-08-2005, 06:43
Hello Again,
Forgot to say THANKS Jeff Miller for the steering wheel
supplier - vipwheels.
Thanks also for the solutions.
Gene
Judy & Gene
93' WL40' Ohio
> Good Afternoon ,
> Thanks,
> Gene
> Judy & Gene Sharp
> 93' WL40' Ohio
