water heater - r/r -
07-14-2007, 03:27
A 1/2 inch hole can be drilled into the metal cover plate.
Then it is easy and simple to reset the over temp safety switch.
Bill 88 FC Michigan
--- In WanderlodgeForum@yahoogroups.com, "Eric Johnson"
> Hello Roger,
> I have an Atwood water heater in our coach that I installed to
replace our original. I've
> found that the electric heater element trips out whenever water
from the engine exceeds
> 185 ºF. After consulting the factory, the way I remedy this
situation is as follows:
> 1. Shut off power to the heater.
> 2. Remove sheet metal screws from the square cover over the
heating element.
> 3. Use a screwdriver to push in the red reset button buried in
between the electrical plugs
> that supply power to the heater.
> 4. Replace the cover and restore power.
> In the summer I close the hot water circulation off to the heater
to prevent this problem.
> Long term fix...replace the Atwood heater with a better choice.
> Regards, Eric in San Antonio
> 84FC35SBWL2
> --- In WanderlodgeForum@yahoogroups.com, "rogerwwebb"
> > The electric heat supply to my water heater has stopped working.
It is
> > an Atwood model, 10.5 gallons.
> > I have not taken it apart, but assume I will need to replace the
whole
> > unit.
> > Is this a correct assumption, or per chance, can you replace just
> > heating element on this unit?
> > Roger Webb
> > 91WBWL
> > Cedar Rapids, IA
