3208 Water Pump R&R
07-24-2007, 06:11
3208 Water Pump R&R
With coolant running out from behind the pulley on the water pump
shaft, I suppose it is time to replace the pump. This is a 3208T 225HP. Has anyone done this job? Are there any "gotchas" that I should know about during the Remove and Replace process? Is my local Cat dealer as good as any other source for parts? Are there any other "soft parts" I should order aside from the pump and gaskets? Thanks in advance for any tips and advice. Bob Griesel '84 FC31 WLII WA |
07-24-2007, 09:25
3208 Water Pump R&R
Haven't done it but I did buy a spare water pump on Ebay. Looks like a pretty
standard and normal procedure from the appearance of the pump. Kerry 82 FC 35 Denver --- In WanderlodgeForum@yahoogroups.com, "freewill2008" > > With coolant running out from behind the pulley on the water pump > shaft, I suppose it is time to replace the pump. This is a 3208T 225HP. > > Has anyone done this job? > > Are there any "gotchas" that I should know about during the Remove and > Replace process? > > Is my local Cat dealer as good as any other source for parts? > > Are there any other "soft parts" I should order aside from the pump and > gaskets? > > Thanks in advance for any tips and advice. > > Bob Griesel '84 FC31 WLII WA > |
