Checking transmission oil level
07-26-2007, 03:21
This I guess is one of those things a guy ought to know but I thought I
better check to make certain I have it right. To check the trans level. Engine running and read the level as cold when first started and the hot level after engine and transmission are warmed up? I haven't had to check the trans levels on a vehicle in years but I thought it might not be a bad idea on a vehicle of the age of this BB John Heckman Central Pa 1973 FC converted to diesel Allison Trans 4 speed. |
07-26-2007, 04:31
Level is the operative word here. The vehicle needs to be level side to side,
front to back for accurate reading. The level markings on the transmission "dip stick" or scale should face the rear of the vehicle. Make sure the cap is in the proper position to assure proper depth when fully installed. The engine is to be a idle, trans in neutral, parking brake set. It is good to check when drive train is at operating temperature. The level can rise substantially when at temp. MH ----- Original Message ----- From: bubblerboy64 To: WanderlodgeForum@yahoogroups.com Sent: Thursday, July 26, 2007 9:21 AM Subject: [WanderlodgeForum] Checking transmission oil level This I guess is one of those things a guy ought to know but I thought I better check to make certain I have it right. To check the trans level. Engine running and read the level as cold when first started and the hot level after engine and transmission are warmed up? I haven't had to check the trans levels on a vehicle in years but I thought it might not be a bad idea on a vehicle of the age of this BB John Heckman Central Pa 1973 FC converted to diesel Allison Trans 4 speed. [Non-text portions of this message have been removed] |
