Red Light Switch?
08-15-2007, 09:36
Red Light Switch?
Hey all, there is a red light switch behind the drivers seat on my
84FC35. What does it control?
Thanks, Keith
84FC35
08-15-2007, 10:02
Red Light Switch?
Electric battery heaters.
Scott Forman
86 PT38
Memphis
--- In WanderlodgeForum@yahoogroups.com, "Keith Strehle"
> Thanks, Keith
> 84FC35
08-15-2007, 10:08
Red Light Switch?
Block Heater(s).
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Keith Strehle
Sent: Wednesday, August 15, 2007 4:36 PM
Subject: [WanderlodgeForum] Red Light Switch?
Thanks, Keith
84FC35
08-15-2007, 10:19
Red Light Switch?
Yep, I believe you're right. Not that I'll ever use them here in San
Diego. But you never know when I might end up in the cold country.
Thanks for the info.
Keith
84FC35
> Scott Forman
> 86 PT38
> Memphis
my
> > Thanks, Keith
> > 84FC35
08-15-2007, 11:42
Red Light Switch?
Keith, Should be for the battery heaters, if they are still connected and or
functional.
Thanks, Keith
84FC35
Doug Engel, Gunnison, CO. Bird Usta Be, now 1990 Thomas Skoolie, "Hormone
Derange"
Shape Yahoo! in your own image. Join our Network Research Panel today!
08-15-2007, 12:04
Red Light Switch?
Might be the engine heater -- used to help with cold weather starts.
Run it 24 to 36 hours before the planned start. I also have a red
switch under the kitchen sink that operates the "Konstant hot" water
heater.
El Sobrante CA
aeonix1@...
> Thanks, Keith
> 84FC35
08-15-2007, 13:21
Red Light Switch?
Block heater switch on FC is at passenger's toes.
Scott
starts.
water
> heater.
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Thanks, Keith
> > 84FC35
08-15-2007, 15:43
Red Light Switch?
This is probably like every thing else and varies from bird to bird. The
switch behind the driver's seat on our bird is a double pole switch, on two
separate circuits, that powers two freeze plug block heaters on either side
of the 3208. The switch by the passenger's feet controls a tank type block
heater. Maybe that is why our FC31 came with a 12.5kw generator!
- Chuck Wheeler -
82 FC 31 SB
Fort Worth, TX
_____
[mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of Scott Forman
Sent: Wednesday, August 15, 2007 8:22 PM
Subject: [WanderlodgeForum] Re: Red Light Switch?
Scott
starts.
water
> heater.
> Pete Masterson
> El Sobrante CA
> aeonix1@...
> > Thanks, Keith
> > 84FC35
