Toilet emergency...Help!
09-01-2007, 13:01
Mine has a cut-off, thankfully.
Still need to know how to fix it.
Scott
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Scott,
> I had mine start leaking at RIV last year. I replaced the old OE
toilet with a new china one and put in a cut off valve while doing
the change. You might want to add a cut off valve tomorrow to get you
through the weekend. I was dumbfounded that BB did not have a cut
off on the toilet. When you consider all the other redundant items on
the coach someone dropped the ball.
> Howard T., Sowega, 86 PT40
> From: Scott Forman
> Sent: Friday, August 31, 2007 7:16 PM
> Subject: [WanderlodgeForum] Toilet emergency...Help!
> I am at a Football tailgate, and my toilet will not quit filling.
I
> have the original toilet, and don't even know how to take it
apart to
> look at anything. Any suggestions? I am having to keep my water
pump
> off now, and it is quite inconvenient & will create a challenge
for
> taking showers tomorrow morning.
> Help!
> Scott Forman
> 86 PT38
> Memphis
> No virus found in this incoming message.
> Checked by AVG Free Edition.
> Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date:
8/28/2007 4:29 PM
09-01-2007, 13:06
Did you see the link to the manual and the steps to fix I posted? Repeated
below.
The manual has diagrams, but you might not need them. I don't think I would
attempt it without removing the toilet - rock it up and out to avoid destroying
the wax ring, or get a new ring.
The troubleshooting in the microphor manual at
http://www.microphor.com/pdf/LF-220_Manual.pdf says "Water continues to
run. Obstruction in water Solenoid Valve. Remove and inspect Solenoid Valve -
see Solenoid Valve Cleaning" The latter section says:
1 Disconnect the power by removing the two blue wires from the solenoid.
2 Disconnect the water supply line at china end.
3 Remove two screws securing the solenoid to the mounting bracket.
4 Pull solenoid away from the Vacuum Breaker.
5 Remove water supply tube.
6 Remove four (4) screws from Solenoid Valve Body and remove spring and
diaphragm.
7 Clean holes in the diaphragm if clogged. Inspect solenoid for debris and
clean. Reassemble in reverse order.
Don Bradner
90 PT40 "Blue Thunder"
Eureka, CA
09-01-2007, 13:25
I do not have a microphor, it's an old fashioned Thetford, no air, no
electronics. It's exactly the same toilet that was in my 82 FC.
Scott
Repeated below.
I would attempt it without removing the toilet - rock it up and out
to avoid destroying the wax ring, or get a new ring.
to
Solenoid Valve - see Solenoid Valve Cleaning" The latter section says:
solenoid.
and diaphragm.
debris and clean. Reassemble in reverse order.
> Don Bradner
> Eureka, CA
09-01-2007, 13:36
Hi Scott:
Your going to need a ball valve replacement package. If your commode is the
original and is the starlight or galaxy, the part number is #09868 and
there should be the needed replacement instructions.
But a couple of short cuts might help. 1. Turn off the water and look where
the water hooks up to the ball valve and un screw the nut holding the tube
to the valve. 2. Open the top lids and on your left as you face the front
of the unit you will see a circle plastic piece that is flush, with a small
knife blade pry it up and out but take care not to bang it up too much.
Now then there are 2 screws with nuts that hold the unit to the floor and
with a flash light peer down the hold of the cover you just removed, I use
a 3/8 drive 18 inch extension, a swivel and a deep well socket to loosen
and remove that nut. Then with a long stout screw driver, press down on the
foot pedal and use the long stout screwdriver to hold it down, now you can
see the second nut that must be removed. The commode is now up and out the
door to work on, oh, grab a beer on the way by the refer.
You are going to have to remove the flush mechanism to replace the ball
valve and should find some 8 or so screws around the base holding the flush
mech to the bowl, there are also 2 hoses held on by crimp hose clamps that
must be removed. Now the base is off and you can see where you have to go.
Whole job should take you about 1 hr 15 minutes or so from out to in and done.
Safe travels,
84FC35
Duncan, Oklahoma
>Scott
09-01-2007, 13:40
Ah, sorry, I saw the "no air" but missed the Thetford. Like many here I have a
"no air" Microphor. Electric.
>Scott
>Repeated below.
>to
>solenoid.
>and diaphragm.
>> Don Bradner
>> Eureka, CA
>Yahoo! Groups Links
09-01-2007, 14:23
Scott, if you need the replacement package for the Thetford I have one listed
for sale on WOO classifieds that is brand new. I came across it as I was
cleaning a box out in my garage.
Ralph, I have been following your latest ordeal and you have been in our
prayers. Glad to see you on the forums again.
Bruce Morris in Raleith, NC
1983 FC35RB
WOO - Webmaster
> From: "Ralph L. Fullenwider"
> Date: 2007/09/01 Sat PM 08:36:38 EST
> Subject: Re: [WanderlodgeForum] Re: Toilet emergency...Help!
> Hi Scott:
> Safe travels,
> 84FC35
> Duncan, Oklahoma
> >Scott
09-02-2007, 01:37
Well, short of driving to Memphis to do it for me, I'd say that's
about the most complete answer I could get...Thanks!
Scott
> Hi Scott:
commode is the
look where
the tube
front
a small
much.
floor and
removed, I use
loosen
down on the
you can
out the
ball
the flush
clamps that
to go.
in and done.
> Safe travels,
> 84FC35
> Duncan, Oklahoma
> >Scott
09-02-2007, 01:50
Scott,
Hopefully yours will be a simple and inexpensive fix. The parts to fix mine was
over half the price of a new one so I opted to upgrade to the newer home looking
china bowl. If you go the new route let me know and I will send you my source.
Sent: Saturday, September 01, 2007 9:01 PM
Subject: [WanderlodgeForum] Re: Toilet emergency...Help!
Scott
> Scott,
> From: Scott Forman
I
apart to
pump
for
> Help!
> Scott Forman
> 86 PT38
> Memphis
8/28/2007 4:29 PM
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
09-02-2007, 02:11
Ralph,
Brother,It is so good to see your post and hopefully you are feeling better.
I read your instructions for Scott. One thing you should consider adding in the
future concerning your time estimate.
Ralphs time 1 hr. 15 min., Novice time 7 hrs. 47 min. Plus.
Howard Truitt
Camilla, Ga.
Sowega [South West Georgia]
86, 8V92, PT40
Sent: Saturday, September 01, 2007 9:36 PM
Hi Scott:
Safe travels,
84FC35
Duncan, Oklahoma
>Scott
4:29 PM
09-02-2007, 02:44
What model did you use? I wouldn't mind an upgrade, but need to know
what to use. I assume some models won't fit.
Scott
> Scott,
fix mine was over half the price of a new one so I opted to upgrade
to the newer home looking china bowl. If you go the new route let me
> From: Scott Forman
> Scott
> > Scott,
OE
doing
you
items on
> > From: Scott Forman
filling.
> I
> apart to
> pump
> for
> > Help!
> > Scott Forman
> > 86 PT38
> > Memphis
Date:
> 8/28/2007 4:29 PM
8/28/2007 4:29 PM
