Toilet emergency...Help!
09-02-2007, 09:22
Post: #21
Scott,
I purchased the Thetford Aqua Magic Style "Plus" China Bowl Toilet. The "Plus"
is the taller unit which gives a little more hanging room for men. I had to
turn the floor flange to line up with the new bolt holes. I also had to cut a
little off the bottom of the cabinet doors and mirrows behind the toilet. I left
the hinges as they were because they don't show. I ordered mine in Nov. 06 and
paid 175.00 + 19.95 S&H. I ordered thru Ebay Motors: search for Aqua Magic
Style Plus China Bowl Thetford RV Toilet, the Ebay vendor was RVExit. [Colaw RV
- Web dba RV Exit, 10389 Cimmaron Road, Suite A, Carthage, Mo. 64836.] Recieved
shipment from warehouse in Atlanta in two days.
Good Luck,
Howard
Sent: Sunday, September 02, 2007 10:44 AM
Subject: [WanderlodgeForum] Re: Toilet emergency...Help!
What model did you use? I wouldn't mind an upgrade, but need to know
what to use. I assume some models won't fit.
Scott
--- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt"
> Scott,
> Hopefully yours will be a simple and inexpensive fix. The parts to
fix mine was over half the price of a new one so I opted to upgrade
to the newer home looking china bowl. If you go the new route let me
know and I will send you my source.
> Howard T., Sowega, 86 PT40
> From: Scott Forman
> Sent: Saturday, September 01, 2007 9:01 PM
> Mine has a cut-off, thankfully.
> Still need to know how to fix it.
> Scott
> > Scott,
> > I had mine start leaking at RIV last year. I replaced the old
OE
> toilet with a new china one and put in a cut off valve while
doing
> the change. You might want to add a cut off valve tomorrow to get
you
> through the weekend. I was dumbfounded that BB did not have a cut
> off on the toilet. When you consider all the other redundant
items on
> the coach someone dropped the ball.
> > From: Scott Forman
> > Sent: Friday, August 31, 2007 7:16 PM
> > Subject: [WanderlodgeForum] Toilet emergency...Help!
> > I am at a Football tailgate, and my toilet will not quit
filling.
> I
> > have the original toilet, and don't even know how to take it
> apart to
> > look at anything. Any suggestions? I am having to keep my water
> pump
> > off now, and it is quite inconvenient & will create a challenge
> for
> > taking showers tomorrow morning.
> > Help!
> > Scott Forman
> > 86 PT38
> > Memphis
> > No virus found in this incoming message.
> > Checked by AVG Free Edition.
> > Version: 7.5.476 / Virus Database: 269.12.10/977 - Release
Date:
> 8/28/2007 4:29 PM
> Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date:
8/28/2007 4:29 PM
Version: 7.5.476 / Virus Database: 269.12.10/977 - Release Date: 8/28/2007
4:29 PM
09-02-2007, 10:29
Post: #22
Hi Don
No, I only have that shut-off under the kitchen sink behind panels. I
am glad now that I have both, electric and water emergency shut-offs
right by the toilet where they are needed.
Toilet will not quit cylcling...? shut of electric. grab beer
andInvestigate
Toilet wont shut off and wants to overflow...? shut off water, grab
beer and investigate. Makes life a lot simpler.
Juergen in PA
1991 WLSP36
--- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote:
> Hi Juergen Mine has a shut off in the vanity for the
toilet. There
> is a sprayer under the vanity that has a door that drops down on
the street
> side that has a shut off in the copper line that goes to the
toilet.It is hard
> to see because it is behind some other plumbing. Does yours have
that sprayer
> & the drop down door in the vanity?
> Don
> 89 SP 36'
> Butler, PA
> Howard hit the nail on the head. I had the same problem with my toilet
> years ago. Several times actually. Each time it was a piece of built
> up calcium in the water shut off solenoid. I installed a water
> shut-off valve right behind the toilet and a electric shut-off switch
> next to it. Also put an inline filter screen between the shut-off and
> toilet inlet. Havn't had a problem since. BB dropped the ball indeed,
> by not having an accessable shut-off. My original one is under the
> kitchen sink behind some panels that have to unscrewed, its hard to
> find, you need a flashlight, and if you forgot to shut off the pump,
> or hooked to external water supply, you just might drown in your own
> coach. Thanks,BB,..coach
> Juergen in PA
> 1991 WLSP36
> _Messages in this topic _
(http://groups.yahoo.com/group/Wanderlodg...ajRlN\
zkxBF9TAzk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSW
QDMTcwNTEyNjE4NQRtc2dJZAMyNzM2OQRzZWMDZnRyBHNsawN2dHBjBHN0aW1lAzExODg2MDkxNDIE
> dHBjSWQDMjczNjA-) (0) _Reply (via web post) _
(http://groups.yahoo.com/group/Wanderlodg...F9TAz\
BGdycHNwSWQDMTcwNTEyNjE4NQRtc2dJZAMyNzM2OQRzZWMDZnRyBHNsawNycGx5BHN0aW1lAzExOD
> g2MDkxNDI-?act=reply&messageNum=27369) | _Start a new topic _
k3MzU5NzE0BGd
ycElkAzE0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWMDZnRyBHNsawNudHBjBHN0aW1lAzExO
> Dg2MDkxNDI-)
> _Messages_
(http://groups.yahoo.com/group/Wanderlodg...WJiBF\
9TAzk3MzU5NzE0BGdycElkAzE0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWM
> DZnRyBHNsawNtc2dzBHN0aW1lAzExODg2MDkxNDI-) | _Files_
(http://groups.yahoo.com/group/Wanderlodg...BF9TA\
E0ODE1NTE4BGdycHNwSWQDMTcwNTEyNjE4NQRzZWMDZnRyBHNsawNmaWxlcwRzdGltZQMxMTg4NjA5
> MTQy) | _Photos_
(http://groups.yahoo.com/group/Wanderlodg...1BF9T\
> QRzZWMDZnRyBHNsawNwaG90BHN0aW1lAzExODg2MDkxNDI-)
> ************************************** Get a sneak peek of the
all-new AOL at
> http://discover.aol.com/memed/aolcom30tour
