Transmission "Do Not Shift" Light and Code 22 (Speed Sensor)
09-17-2007, 15:54
Leroy, I do not have any drawings of the TCM wiring or functions. I
focused on the speed sensor based on the transmission code being
flashed (22). Apparently the transmission is designed to "shut down"
and prevent shifting if it is not getting a signal from the speed
sensor. I first unplugged the sensor altogether and noted that there
was no change in symptoms. I then called an Allison shop to inquire
how to check the sensor. When I determined that it was showing a
satisfactory ohm reading, I then started rechecking the nearest
connections first and cleaning them regardless of how I though they
looked. My plan was to trace the wiring all the way back to the
TCM/ECM and check any conection I found along the way. Lucked out
that it was the first one even though it "looked" okay. I keep my
coach stored indoors, connected to shorepower at all times and use it
frequently. Even so, I guess time is not on our side in terms of the
age of some of the electrical connections. Hope this helps. David
Hanvy 89WB Crosby, TX
> Thanks for the report. Happy it was something simple.
> One question. What prompted you to zero in on the speed sensor? Do
you have a drawing of the TCM wiring and functions? If the bus is not
moving how does the speed sensor affect the shifter pad, if you know?
Just for future reference. I would like to know more since I do not
have a manual or drawing on my TCM. Thanks
> Leroy Eckert
> 1990 WB-40"Smoke N Mirrors
> Niceville, FL
> Royale Conversion
> From: David Hanvy
> Sent: Friday, September 14, 2007 1:09 PM
> Subject: [WanderlodgeForum] Re: Transmission "Do Not Shift" Light
> Leroy/Kevin,
> Thanks for your replies. I started the engine from the rear
remote
> and the transmission warning light/do not shift remains on. No
change
> when I switched back to the front either. Additionally, I
> disconnected from shore power and disconnected the ground cable
on
> the battery bank in an effort to reset the tranny. No luck on
that
> either. (do not shift equals WILL not shift) I plan to to locate
> read up on the Speed Sensor as a next step.
> All input is appreciated. David Hanvy 89WB PT40 Crosby, TX
> > Although I don't think your bus would start if the remote rear
> start switch was acting up, mine will give me a do not shift
light in
> the rear start position and in the front position if it is not
> engaged properly. Not all coaches are wired to give a do not
shift
> light on the remote rear start position but mine does. I have
never
> checked my codes so can't help there. I would cycle that switch
to
> rear, off, and back to front, restart and see what happens.. It
is a
> long shot but easy to do.
> > Let us know what you find for future reference.
> > Leroy Eckert
> > 1990 WB-40"Smoke N Mirrors"
> > Niceville, FL
> > Royale Conversion
> > From: David Hanvy
> > Sent: Thursday, September 13, 2007 8:48 PM
> > Subject: [WanderlodgeForum] Transmission "Do Not Shift" Light
> > Greetings All; I started my coach today which has been sitting
in
> > covered storage with shore power for about two weeks. The
> > transmission "Do Not Shift" light and check transmission light
> are
> > staying on. It flashes a Code 22 which indicates a Speed Sensor
> issue.
> > Does anyone have any experience with this issue? I did not note
> any
> > transmission problems on my last trip which was about two weeks
> ago. I
> > cleaned the ground strap connections on the transmission and
> frame and
> > checked the transmission cannon plug but the warning lights
> remain on.
> > Thanks. David Hanvy 89WB PT40 Crosby, TX
09-18-2007, 00:58
I now remember that code 22 in the original post. Apparently it is a loop that
allows everything to communicate. I was wondering if cleaning those plugs might
be a possible PM item to prevent such occurrences?? Time is not on our side when
it comes to electrical connections. On the other hand, if isn't broken, I wonder
about messing with it. Mess up and cause more problems. Thanks for the
information.
Leroy Eckert
Niceville, FL
Royale Conversion
Sent: Monday, September 17, 2007 10:54 PM
Subject: [WanderlodgeForum] Re: Transmission "Do Not Shift" Light and Code 22
(Speed Sensor)
> Leroy Eckert
> Niceville, FL
> Royale Conversion
> From: David Hanvy
> Leroy/Kevin,
remote
change
on
that
light in
shift
never
to
is a
> > Leroy Eckert
> > Niceville, FL
> > Royale Conversion
> > From: David Hanvy
in
> are
> issue.
> any
> ago. I
> frame and
> remain on.
