Wellnut Fastners
09-16-2007, 02:24
Wellnut Fastners
Discovered that a branch pulled the front of my main awning loose,upon
inspection I found a device or what was left of it called a Wellnut. Apparently the Stainless steel machine screw goes through the awning flange and is threaded into this fastener and somehow when it is thightened holds the awning flange in place. is this the best fastener for this application? the regular window awnings are all fastened with stainless screws but this main awning seems to use these Wellnuts for the entire length of awning flange. Would appreciate suggestions. Donald Brown 2000 LX-40 Palmetto,Florida |
09-16-2007, 02:48
Wellnut Fastners
Donald,
Wellnuts are the most secure way to attach the awning. You drill a hole place the wellnut insert into the hole then when you screw in the bolt it expands the insert making for a very secure fit. Howard Truitt, Camilla, Ga. 86 PT40 ----- Original Message ----- From: rvdependent To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 16, 2007 10:24 AM Subject: [WanderlodgeForum] Wellnut Fastners Discovered that a branch pulled the front of my main awning loose,upon inspection I found a device or what was left of it called a Wellnut. Apparently the Stainless steel machine screw goes through the awning flange and is threaded into this fastener and somehow when it is thightened holds the awning flange in place. is this the best fastener for this application? the regular window awnings are all fastened with stainless screws but this main awning seems to use these Wellnuts for the entire length of awning flange. Would appreciate suggestions. Donald Brown 2000 LX-40 Palmetto,Florida ------------------------------------------------------------------------------ Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24 PM [Non-text portions of this message have been removed] |
09-16-2007, 02:56
Wellnut Fastners
Thank you, I'll call Bluebird in the morning order enough for the repair
Donald Brown, 2000 LX-40 Palmetto,Florida "Howard O. Truitt" Donald, Wellnuts are the most secure way to attach the awning. You drill a hole place the wellnut insert into the hole then when you screw in the bolt it expands the insert making for a very secure fit. Howard Truitt, Camilla, Ga. 86 PT40 ----- Original Message ----- From: rvdependent To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 16, 2007 10:24 AM Subject: [WanderlodgeForum] Wellnut Fastners Discovered that a branch pulled the front of my main awning loose,upon inspection I found a device or what was left of it called a Wellnut. Apparently the Stainless steel machine screw goes through the awning flange and is threaded into this fastener and somehow when it is thightened holds the awning flange in place. is this the best fastener for this application? the regular window awnings are all fastened with stainless screws but this main awning seems to use these Wellnuts for the entire length of awning flange. Would appreciate suggestions. Donald Brown 2000 LX-40 Palmetto,Florida ---------------------------------------------------------- Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24 PM [Non-text portions of this message have been removed] --------------------------------- Building a website is a piece of cake. Yahoo! Small Business gives you all the tools to get online. [Non-text portions of this message have been removed] |
09-16-2007, 03:15
Wellnut Fastners
Donald,
Check your Yellow Pages for Fasteners - Industrial & Construction. listings up here are chains, Fastenal Company and Ricco Fasteners Inc.. This would give you a chance to compare and ask questions about installation. Good luck. Howard Truitt, Camilla, Ga. ----- Original Message ----- From: DONALD BROWN To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 16, 2007 10:56 AM Subject: Re: [WanderlodgeForum] Wellnut Fastners Thank you, I'll call Bluebird in the morning order enough for the repair Donald Brown, 2000 LX-40 Palmetto,Florida "Howard O. Truitt" Wellnuts are the most secure way to attach the awning. You drill a hole place the wellnut insert into the hole then when you screw in the bolt it expands the insert making for a very secure fit. Howard Truitt, Camilla, Ga. 86 PT40 ----- Original Message ----- From: rvdependent To: WanderlodgeForum@yahoogroups.com Sent: Sunday, September 16, 2007 10:24 AM Subject: [WanderlodgeForum] Wellnut Fastners Discovered that a branch pulled the front of my main awning loose,upon inspection I found a device or what was left of it called a Wellnut. Apparently the Stainless steel machine screw goes through the awning flange and is threaded into this fastener and somehow when it is thightened holds the awning flange in place. is this the best fastener for this application? the regular window awnings are all fastened with stainless screws but this main awning seems to use these Wellnuts for the entire length of awning flange. Would appreciate suggestions. Donald Brown 2000 LX-40 Palmetto,Florida ---------------------------------------------------------- Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24 PM [Non-text portions of this message have been removed] --------------------------------- Building a website is a piece of cake. Yahoo! Small Business gives you all the tools to get online. [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Internal Virus Database is out-of-date. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.10/995 - Release Date: 9/8/2007 1:24 PM [Non-text portions of this message have been removed] |
09-16-2007, 04:54
Wellnut Fastners
--- In WanderlodgeForum@yahoogroups.com, "rvdependent"
Goole wellnuts.You will find location near you. Bob Loomas 1985 PT 36 > > Discovered that a branch pulled the front of my main awning loose,upon > inspection I found a device or what was left of it called a Wellnut. > Apparently the Stainless steel machine screw goes through the awning > flange and is threaded into this fastener and somehow when it is > thightened holds the awning flange in place. is this the best fastener > for this application? the regular window awnings are all fastened with > stainless screws but this main awning seems to use these Wellnuts for > the entire length of awning flange. Would appreciate suggestions. > Donald Brown 2000 LX-40 Palmetto,Florida > |
