Tranmission Code
09-23-2007, 15:17
Tranmission Code
On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. I am getting
a code 1 light pause then 2 quick lights. I assume this is a Code 12. Can anyone tell me what this code is. Thanks, Howard Truitt, Sowega [Non-text portions of this message have been removed] |
09-24-2007, 10:58
Tranmission Code
Howard,
I recently had a transmission problem. I, too, got a code 12 when the problem started. My trans tech told me that code 12 is an "initial" code that comes with any problem, sort of like a warning. There should then be another specific code that follows it. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. I am getting a code 1 light pause then 2 quick lights. I assume this is a Code 12. Can anyone tell me what this code is. > Thanks, > Howard Truitt, Sowega > > [Non-text portions of this message have been removed] > |
09-24-2007, 11:17
Tranmission Code
Scott,
I spent about 4 hrs searching for a code chart last night. Finally found one on WOO site. It list diagnostic codes for MT 600, HT 700, and CT700 series transmission. It says a code 12 is low lube pressure/oil level. Howard Truitt, Camilla, Ga. 86 PT40 "Knat Country" ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 6:58 PM Subject: [WanderlodgeForum] Re: Tranmission Code Howard, I recently had a transmission problem. I, too, got a code 12 when the problem started. My trans tech told me that code 12 is an "initial" code that comes with any problem, sort of like a warning. There should then be another specific code that follows it. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. I am getting a code 1 light pause then 2 quick lights. I assume this is a Code 12. Can anyone tell me what this code is. > Thanks, > Howard Truitt, Sowega > > [Non-text portions of this message have been removed] > ------------------------------------------------------------------------------ No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.28/1023 - Release Date: 9/22/2007 1:27 PM [Non-text portions of this message have been removed] |
09-24-2007, 11:45
Tranmission Code
Howard,
My trans has two checks on the stick. Hot and cold and the fluid needs to be balanced in between the lines so to speak. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Niceville, FL Royale Conversion ----- Original Message ----- From: Howard O. Truitt To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 6:17 PM Subject: Re: [WanderlodgeForum] Re: Tranmission Code Scott, I spent about 4 hrs searching for a code chart last night. Finally found one on WOO site. It list diagnostic codes for MT 600, HT 700, and CT700 series transmission. It says a code 12 is low lube pressure/oil level. Howard Truitt, Camilla, Ga. 86 PT40 "Knat Country" ----- Original Message ----- From: Scott Forman To: WanderlodgeForum@yahoogroups.com Sent: Monday, September 24, 2007 6:58 PM Subject: [WanderlodgeForum] Re: Tranmission Code Howard, I recently had a transmission problem. I, too, got a code 12 when the problem started. My trans tech told me that code 12 is an "initial" code that comes with any problem, sort of like a warning. There should then be another specific code that follows it. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. I am getting a code 1 light pause then 2 quick lights. I assume this is a Code 12. Can anyone tell me what this code is. > Thanks, > Howard Truitt, Sowega > > [Non-text portions of this message have been removed] > ---------------------------------------------------------- No virus found in this incoming message. Checked by AVG Free Edition. Version: 7.5.485 / Virus Database: 269.13.28/1023 - Release Date: 9/22/2007 1:27 PM [Non-text portions of this message have been removed] [Non-text portions of this message have been removed] |
09-24-2007, 11:48
Tranmission Code
Well that makes sense, as I received the code shortly after a
retarder line ruptured and all the trans oil sprayed out. Scott --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > Scott, > I spent about 4 hrs searching for a code chart last night. Finally found one on WOO site. It list diagnostic codes for > MT 600, HT 700, and CT700 series transmission. It says a code 12 is low lube pressure/oil level. > Howard Truitt, Camilla, Ga. 86 PT40 > "Knat Country" > ----- Original Message ----- > From: Scott Forman > To: WanderlodgeForum@yahoogroups.com > Sent: Monday, September 24, 2007 6:58 PM > Subject: [WanderlodgeForum] Re: Tranmission Code > > > Howard, > > I recently had a transmission problem. I, too, got a code 12 when > the problem started. My trans tech told me that code 12 is > an "initial" code that comes with any problem, sort of like a > warning. There should then be another specific code that follows it. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "Howard O. Truitt" > > > > > On my 86, 8V92, PT40 with the Allison HTB741, 4-speed transmission. > I am getting a code 1 light pause then 2 quick lights. I assume this > is a Code 12. Can anyone tell me what this code is. > > Thanks, > > Howard Truitt, Sowega > > > > [Non-text portions of this message have been removed] > > > > > > > > > -------------------------------------------------------------------- ---------- > > > No virus found in this incoming message. > Checked by AVG Free Edition. > Version: 7.5.485 / Virus Database: 269.13.28/1023 - Release Date: 9/22/2007 1:27 PM > > > [Non-text portions of this message have been removed] > |
