Racor Vacuum Gauge
09-29-2007, 10:31
Racor Vacuum Gauge
Hi Guys Has anybody seen or used a vacuum gauge that goes on the
racor filter where the T handle is. It keep the highest reading that it goes to while driving. I think that would be kind of good to be able to see that when you stopped to take a break. It is supposed to keep you from changing filters unnecessary. Mine in the top gauge cluster isn't working & in looking for a new one I found this one. I haven't got one yet & was wandering if any one has used one. Don 89 SP 36' Butler, PA ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-29-2007, 20:28
Racor Vacuum Gauge
Don, disconnect your vacuum line from your gauge. Harvey Lawrence once told
me to do that. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-29-2007, 23:41
Racor Vacuum Gauge
Hi Don,
I have one- works fine. Seem to recall getting it from some marine supply place out west. Only drawback is that you need a wrench to loosen it when you change filters. BB parts had the one for the dash. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, dspithaler@... wrote: > > Hi Guys Has anybody seen or used a vacuum gauge that goes on the > racor filter where the T handle is. It keep the highest reading that it goes to > while driving. I think that would be kind of good to be able to see that > when you stopped to take a break. It is supposed to keep you from changing > filters unnecessary. Mine in the top gauge cluster isn't working & in looking for > a new one I found this one. I haven't got one yet & was wandering if any one > has used one. > Don > 89 SP 36' > Butler, PA > > > > ************************************** See what's new at http://www.aol.com > > > [Non-text portions of this message have been removed] > |
09-30-2007, 07:16
Racor Vacuum Gauge
Ernie What do you do when you disconnect the line? I have mine off
before. Don 89 SP 36' Butler, PA Don, disconnect your vacuum line from your gauge. Harvey Lawrence once told me to do that. Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-30-2007, 07:21
Racor Vacuum Gauge
Hi Shane I think I will get one to put on the Racor just to see when
the filter is ready to change. I have a West Marine not to far from me. Don 89 SP 36' Butler, PA Hi Don, I have one- works fine. Seem to recall getting it from some marine supply place out west. Only drawback is that you need a wrench to loosen it when you change filters. BB parts had the one for the dash. Shane Fedeli 85PT40 Hershey, PA ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
09-30-2007, 07:57
Racor Vacuum Gauge
Harvey told me to reconnect it. It somehow helped. But that was on my 35FC a
few years ago. Maybe it was a coincidence? Ernie Ekberg 83PT40 Weatherford, Tx ************************************** See what's new at http://www.aol.com [Non-text portions of this message have been removed] |
