Replacing PT generator
10-08-2007, 04:48
Knock on wood, my original Yanmar/Kohler gen is working like a champ
and only has 1800 hrs, so I expect to get many more years of service
out of it. Just for the sake of discussion, though, has anyone
replaced their 80's PT generator, and what model did you use?
Scott Forman
86 PT38
Memphis
10-08-2007, 06:10
Scott,
Mine had been replaced when I got it in 2005 with a Power Tech 8 kw in a sound
cabinet. Model CD8000, 35 Amps on each leg. Works fine. It has a Kabota 3
cyl. engine. The radiator is attached to the rear of the engine on the
slide-out, so no flat radiator in the left front under the driver.
Sent: Monday, October 08, 2007 9:48 AM
Subject: [WanderlodgeForum] Replacing PT generator
Scott Forman
86 PT38
Memphis
10-08-2007, 06:17
Can you run all 3 airs with the 8kw?
--- In WanderlodgeForum@yahoogroups.com, "Richard Hayden"
> Scott,
in a sound cabinet. Model CD8000, 35 Amps on each leg. Works
fine. It has a Kabota 3 cyl. engine. The radiator is attached to
the rear of the engine on the slide-out, so no flat radiator in the
> From: Scott Forman
> To:
WanderlodgeForum@yahoogroups.com om>
champ
service
> Scott Forman
> 86 PT38
> Memphis
10-08-2007, 06:52
Scott,
Well, I've never had the need to do that. I suppose one could if nothing else
was on. Remember, 35 Amps per leg. I've run the front two and didn't worry
about anything else being on. The front 2 are on different legs. That was in
So. Cal & Yuma last October, but have never run all 3 A/C's at once.
Sent: Monday, October 08, 2007 11:17 AM
Subject: [WanderlodgeForum] Re: Replacing PT generator
--- In
"Richard Hayden"
> Scott,
> From: Scott Forman
> To:
WanderlodgeForum@yahoogroups.com :WanderlodgeForum@...
om>
champ
service
> Scott Forman
> 86 PT38
> Memphis
10-08-2007, 07:28
Sent: Monday, October 08, 2007 11:48 AM
I replace mine with a 12Kw power teck.
Bob Loomas 1985 PT 36
Scott Forman
86 PT38
Memphis
10-08-2007, 09:29
Bob,
Was it a direct replacement (i.e. no mods to coach)? Able to use
original controls/gauges? Is it substantially quieter?
Thanks
--- In WanderlodgeForum@yahoogroups.com, "bloomas"
> From: Scott Forman
champ
service
> Scott Forman
> 86 PT38
> Memphis
10-08-2007, 10:28
Sent: Monday, October 08, 2007 4:29 PM
I was able to use everything.same gages and radiator.
and it is quieter.Know more slip ring and brushes
Bob,
Thanks
> From: Scott Forman
champ
service
> Scott Forman
> 86 PT38
> Memphis
