Outside Storgage Compartment Latch locks
10-31-2007, 16:29
We have a '83 FC35SB that 3 of the 5 locking cargo compartment latch
locks have given up the ghost, literally. I have done several searches
but have not located an answer of where to locate these little items,
not to mention how to replace the locks. Unless, it cannot be done
with out compleatly replacing the entire latch mechanism. The latch
housing / flange on our's are original and were riveted in.
Any suggestions would be greatly appreciated.
10-31-2007, 16:49
So....did you try looking in the Parts Database for "Outside
Compartment Door Latches" for a link to Austin Hardware?
Also, please sign your posts.
Thanks,
1991 WB40 "Texas Minivan"
10-31-2007, 16:57
Oops... No I did not look under "Outside". I did look through the
data base for "Compartment" "Door" and "Latches" but... There it is
none the less. Thanks so much.
Sorry about the failure to sign. My Noobie light is flashing?
Scott Waldy
'83 FC35SB
Boise, Idaho
--- In WanderlodgeForum@yahoogroups.com, "mbulriss" <mbulriss@...>
> Thanks,
> Mike Bulriss
> San Antonio, TX
latch
searches
items,
done
latch
10-31-2007, 17:01
I believe you might have some luck in McMaster-Carr. Here's a link
http://www.mcmaster.com/
Rob, Sue & Merlin Robinson
94 WLWB
11-01-2007, 01:32
Try here orrorr.com
Bill 88 FC Michigan at RATS
searches
