Ride heigth
11-05-2007, 12:44
Ride heigth
My PT36 sits 6 to 8 inches high in the rear, both sides, w/suspention
fully inflated. The front is normal. It seems unlikely to have two mal- adjusted levelors. Is there something else I should be looking at? If it is indeed the levelors, is it much of a job to adjust them? Art Weatherly Riverside Ca '85 PT36 |
11-05-2007, 14:36
Ride heigth
Art,
Check the specs in your Blue Box. I believe my 83 was higher in the raer and it was per the specs in the Blue Box. The late Sid Clark and I checked it one time at a Lone Star Birds rally to verify the settings. FWIW..... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > My PT36 sits 6 to 8 inches high in the rear, both sides, w/suspention > fully inflated. The front is normal. It seems unlikely to have two mal- > adjusted levelors. Is there something else I should be looking at? > If it is indeed the levelors, is it much of a job to adjust them? > > > Art Weatherly > Riverside Ca > '85 PT36 > |
11-06-2007, 00:02
Ride heigth
Mine has an approximate ride height of 16" in the front and between 18-19" in
the rear. This is measured in front behind the front wheel from the body skin and in the rear measured in front of the drive wheel from the body skin. I wouldn't know if yours should be the same. Leroy Eckert 1990 WB-40"Smoke N Mirrors" Dahlonega, GA mbulriss <mbulriss@...> wrote: Art, Check the specs in your Blue Box. I believe my 83 was higher in the raer and it was per the specs in the Blue Box. The late Sid Clark and I checked it one time at a Lone Star Birds rally to verify the settings. FWIW..... Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "amweath" wrote: > > My PT36 sits 6 to 8 inches high in the rear, both sides, w/suspention > fully inflated. The front is normal. It seems unlikely to have two mal- > adjusted levelors. Is there something else I should be looking at? > If it is indeed the levelors, is it much of a job to adjust them? > > > Art Weatherly > Riverside Ca > '85 PT36 > __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
11-06-2007, 14:28
Ride heigth
Art,
I measured my ride height Home Depot paint stick (a paint stick for a 5 gal. bucket). I drew lines on a stick several years ago after Bennie informed me of the ride heights. I carry the stick in the bus, and use it to verify front & rear ride height. The line for the front is at 16", 18" for the rear. Bennie said the ride height could vary by 1", + or -. and the rear should always be higher than the front. Your issue, my guess, is the ride height valves need to be cleaned out or replaced. I experienced one side would ride high, increasing the other sides height some. Installing new ride height valves eliminated the problem, so far. On 11/5/07, amweath > > My PT36 sits 6 to 8 inches high in the rear, both sides, w/suspention > fully inflated. The front is normal. It seems unlikely to have two mal- > adjusted levelors. Is there something else I should be looking at? > If it is indeed the levelors, is it much of a job to adjust them? > > Art Weatherly > Riverside Ca > '85 PT36 > > > -- Curt Sprenger 1987 PT38 8V92 "MacAttack Racing" Anaheim Hills, CA [Non-text portions of this message have been removed] |
11-06-2007, 14:55
Ride heigth
Leroy, are those measurements just "what they are" or is it based on something
that says that's "the way they should be"? I assume mine and yours would be the same, but I have not seen anything to indicate what mine should be. I measured today at the points you indicate, and they are 14-1/4 front, and 16-1/4 rear. That would appear to be a couple of inches low, on both counts. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 11/6/2007 at 4:02 AM Leroy Eckert wrote: >Mine has an approximate ride height of 16" in the front and between >18-19" in the rear. This is measured in front behind the front wheel from >the body skin and in the rear measured in front of the drive wheel from >the body skin. I wouldn't know if yours should be the same. >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Dahlonega, GA |
11-06-2007, 22:17
Ride heigth
The measurements are just what they are. I have no data showing what it should
or should not be. I do know the rear sits a couple inches higher than the front. I would bet yours is within specification. Don Bradner Leroy, are those measurements just "what they are" or is it based on something that says that's "the way they should be"? I assume mine and yours would be the same, but I have not seen anything to indicate what mine should be. I measured today at the points you indicate, and they are 14-1/4 front, and 16-1/4 rear. That would appear to be a couple of inches low, on both counts. Don Bradner 90 PT40 "Blue Thunder" Eureka, CA On 11/6/2007 at 4:02 AM Leroy Eckert wrote: >Mine has an approximate ride height of 16" in the front and between >18-19" in the rear. This is measured in front behind the front wheel from >the body skin and in the rear measured in front of the drive wheel from >the body skin. I wouldn't know if yours should be the same. >Leroy Eckert >1990 WB-40"Smoke N Mirrors" >Dahlonega, GA Leroy Eckert 1990 WB-40 "Smoke N Mirrors" Dahlonega, GA __________________________________________________ Do You Yahoo!? Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com [Non-text portions of this message have been removed] |
