Needing air filter part number
12-11-2007, 11:20
I am looking for the part number for an air filter for an 1982 FCFB35
that has a CAT 3208NA engine. The filter measures 9 1/4 in dia. and 8 1/8 tall with fins. I looked it up under the files section on this site, but those numbers are not right. Any help would be appreciated. Thanks, Wendel, Georgia 82FCFB35 |
12-11-2007, 15:40
Wendel,
If you have the old air filter pull it out and take it to NAPA or just about any diesel repair shop, they can match it up. Problem with most part numbers on air filters every few years the manufactor changes the number and at times cross references do not match up. You could also check with other parts houses because air & oil filters are made by the small company at times but put in a different vendors box. John 88FC35 part --- In WanderlodgeForum@yahoogroups.com, "akav8r" wrote: > > I am looking for the part number for an air filter for an 1982 FCFB35 > that has a CAT 3208NA engine. The filter measures 9 1/4 in dia. and > 8 1/8 tall with fins. I looked it up under the files section on this > site, but those numbers are not right. Any help would be appreciated. > > Thanks, > > Wendel, Georgia > 82FCFB35 > |
12-11-2007, 16:14
Wendel,
My database comes up with the following NAPA number for my air filter: 2914-1290INI I don't have my bus at home, but your dimensions sound right. Donn '76 FC 33 South Kingstown, RI ________________________________________ From: WanderlodgeForum@yahoogroups.com [mailto:WanderlodgeForum@yahoogroups.com] On Behalf Of akav8r Sent: Tuesday, December 11, 2007 6:20 PM To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Needing air filter part number I am looking for the part number for an air filter for an 1982 FCFB35 that has a CAT 3208NA engine. The filter measures 9 1/4 in dia. and 8 1/8 tall with fins. I looked it up under the files section on this site, but those numbers are not right. Any help would be appreciated. Thanks, Wendel, Georgia 82FCFB35 |
