Air compressor and "that hose"
12-26-2007, 17:36
Rob,
I'm not sure who it was that made the additional access hole. But, the good
thing is to know it has been done before. I'm thinking it was done on a
PT38. I believe the 40' + units have a slightly different frame/cross frame
arrangement in that area. I've mentioned before to Randy that his skinny guy
(worker) would have to be REAL skinny to get up beside the transmission on a
38 footer.
On Dec 26, 2007 8:05 PM, Rob Robinson wrote:
> Curt not sure if this is relevant but both Randy and I cut away some
> plywood
> to provide greater access when we were working on our alternators. After
> removing the metal plate we found that we could cut away some of the
> plywood
> flooring closer to the passenger side outer wall. It was a square section
> approx 6" X 6"
> On 26/12/2007, Curt Sprenger
> > Scott,
> > As I think about air compressor access...Someone on the sites cut a
> second
> > access panel to gain better access to the air compressor. Hopefully they
> > will chime in here, or point us to a doc. addressing the creation of the
> > second access panel.
> > On Dec 26, 2007 7:24 PM, Curt Sprenger
> > wrote:
> > > Scott,
> > > Very possible you will be that lucky; would be great. Be sure both
> hoses
> > > are newer or get replaced.
> > > Good luck!
> > > On Dec 26, 2007 7:15 PM, Scott Forman <
sforman@...<sforman%40renasant.com>
> <sforman%40renasant.com>>
> > wrote:
> > > > Thanks! This is great. I am hoping to God that I open up the hatch
> > > > and see that those hoses are fresh and recent like the others on the
> > > > engine...but I am sure I will not be so lucky
> > > > Scott
> > > > --- In
WanderlodgeForum@yahoogroups.com
> > > > "Curt Sprenger"
> > > > wrote:
> > > > > Scott,
> > > > > Stick you head down in the hatch hole into the engine compartment
> > > > The engine
> > > > > air compressor is just forward of the cross member. Air compressor
> > > > forward
> > > > > hose (towards the front of the coach) runs to the curb side of the
> > > > engine
> > > > > block and above the starter. The rear hose runs to the manifold or
> > > > head on
> > > > > the curb side of the engine. Here is a link to a procedure I put
> > > > together
> > > > > some time ago. Check section "D". Let me know if you have any
> > > > questions.
> > > > > *http://tinyurl.com/3a628w*
> > > > > [Open in new window <http://tinyurl.com/3a628w>]
> > > > > On Dec 26, 2007 3:24 PM, Rob Robinson wrote:
> > > > > > Scott there are two hoses. Hopefully Curt Sprenger will chime
> > > > in here
> > > > > > soon
> > > > > > as he has done this job. Randy is in Bainbridge at his new house
> > > > and might
> > > > > > not be able to answer until later tonight.
> > > > > > On 26/12/2007, Scott Forman <sforman@...
> > > > > > wrote:
> > > > > > > This weekend, I am going to open up the hatch in the bedroom
> in
> > > > an
> > > > > > > effort to look at my air compressor and the associated hose
> > > > that has
> > > > > > > been the topic of so much discussion around here.
> > > > > > > My questions is this: when I open the hatch up, where is the
> > > > > > > compressor? I have only had it open once, and that was briefly
> > > > just to
> > > > > > > see if I could get it open. As I remeber, the exhaust pipe
> > > > crosses
> > > > > > > just below it and the alternator is directly below. Can
> someone
> > > > direct
> > > > > > > me the the compressor and the hose?
> > > > > > > Thanks
> > > > > > > Scott Forman
> > > > > > > 86 PT38, 8v92
> > > > > > > Memphis
> > > > > > Rob, Sue & Merlin Robinson
> > > > > > 94 WLWB
> > > > > > [Non-text portions of this message have been removed]
> > > > > Curt Sprenger
> > > > > 1987 PT38 8V92 "MacAttack Racing"
> > > > > Anaheim Hills, CA
> > > Curt Sprenger
> > > Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
> 94 WLWB
Curt Sprenger
Anaheim Hills, CA
12-27-2007, 01:54
Sent: Wednesday, December 26, 2007 9:46 PM
Subject: Re: [WanderlodgeForum] Re: Air compressor and "that hose"
When I replace mine I was able to do the job from the curb side of the coach
and one fitting from under side.
Bob Loomas 1985 PT36
Scott,
As I think about air compressor access...Someone on the sites cut a second
On Dec 26, 2007 7:24 PM, Curt Sprenger wrote:
> Scott,
> Very possible you will be that lucky; would be great. Be sure both hoses
> Good luck!
> > Scott
> > --- In
WanderlodgeForum@yahoogroups.com,
> > "Curt Sprenger"
> > wrote:
> > > Scott,
> > The engine
> > forward
> > engine
> > head on
> > together
> > questions.
> > in here
> > > > soon
> > and might
> > > > On 26/12/2007, Scott Forman <sforman@... <sforman%40renasant.com>>
> > > > wrote:
> > > > > This weekend, I am going to open up the hatch in the bedroom in
> > an
> > that has
> > just to
> > crosses
> > > > > just below it and the alternator is directly below. Can someone
> > direct
> > > > > Thanks
> > > > > Scott Forman
> > > > > 86 PT38, 8v92
> > > > > Memphis
> > > > 94 WLWB
> > > Curt Sprenger
> > > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
12-27-2007, 12:55
I was going to have mine checked when I was in Yakima, Wa. with air
problems.
Tech searched around and finally found it on the passenger side frame
rail. It is almost impossible to get to.
A future project will be to get a new compressor and move it to a more
easily accessable site.
Bob Lawrence
84 PT 36
Fulltiming (presently in Peoria, Az)
> This weekend, I am going to open up the hatch in the bedroom in an
> effort to look at my air compressor and the associated hose that has
> compressor? I have only had it open once, and that was briefly just
to
> see if I could get it open. As I remeber, the exhaust pipe crosses
direct
> Thanks
> Scott Forman
> 86 PT38, 8v92
> Memphis
12-29-2007, 12:34
Hey Curt,
That link says "The document you requested could not be found." Any
thoughts? I'd like to read that procedure, as I need to do this job
myself.
Thanks,
-Ryan
'86 PT-40 8V92
12-29-2007, 12:39
I took some pictures today of my investigation, I will get them
posted with some commentary soon.
Scott Forman
86 PT38
Memphis
> Hey Curt,
> myself.
> Thanks,
> -Ryan
> '86 PT-40 8V92
12-29-2007, 15:21
*Ryan,
http://tinyurl.com/3bak3e . I think the tiny URLs go *away after some time.
On Dec 29, 2007 4:34 PM, Ryan Wright wrote:
> Hey Curt,
> myself.
> Thanks,
> -Ryan
> '86 PT-40 8V92
Curt Sprenger
Anaheim Hills, CA
12-30-2007, 08:01
Thanks Curt.
Scott, I appreciate your taking pictures & look forward to seeing them
and reading your commentary.
-Ryan
On Dec 29, 2007 7:21 PM, Curt Sprenger wrote:
> *Ryan,
12-30-2007, 08:53
Yes, me also. I would like to know about the exhaust clamps on your coach. They
look nice. Did you fabricate them? Mine have the lead type material inside a
ring.
While my hoses look substantially better than yours I intend to change them out.
Does that bottom black hose go to the front of the compressor head?
Leroy Eckert
1990 WB-40 Smoke N Mirrors
Dahlonega, GA
Royale Conversion
Ryan Wright wrote: Thanks
Curt.
-Ryan
> *Ryan,
Looking for last minute shopping deals? Find them fast with Yahoo! Search.
12-30-2007, 09:20
Yes, that black (from oil & crud) hose goes to the top front of the
compressor. Of course, it is just beyond where the bulkhead is to
make it tough to get to.
The exhaust was replaced before I got the coach, can't speak about
the clamps.
Scott
coach. They look nice. Did you fabricate them? Mine have the lead
type material inside a ring.
change them out. Does that bottom black hose go to the front of the
compressor head?
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> Ryan Wright wrote:
Thanks Curt.
them
> -Ryan
> > *Ryan,
after some time.
Search.
12-30-2007, 10:26
Leroy,
Try here for those clamps
http://shop.ivalueinternet.com/shopdiese...n/home.htm
Select exhaust hardware. The calmps look very similar.
Gardner
78FC33
your coach. They look nice. Did you fabricate them? Mine have the
lead type material inside a ring.
compressor head?
> Leroy Eckert
> Dahlonega, GA
> Royale Conversion
> Ryan Wright wrote:
Thanks Curt.
them
> -Ryan
> > *Ryan,
after some time.
Yahoo! Search.
