Another compressor problem
12-30-2007, 16:25
John, if the belt is tight and the compressor is spinning check the
key in the pully shaft???? you can also check to see if the
compressor head gets hot???
If it is a leak it must be big. you can not hear it because it wont
build enough pressure to hiss and while the cat is running there is
too much noise to hear a big leak hiss. I would hook the aux air up
to a remote shop compressor and look for a leak that way. build a
male to mail fitting for a remote compressor line's female end and
try and build up the tanks in the bus that way?????? I have had
valves hang up that just needed a jolt of reverse air to get thm
free.
It could also be that there is a blockage in the compressor output
line to the first tank
GregoryO'Connor
94ptRomolandCa
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
> Upon trying to take the son-in-law for a turn in the bus I found
that
> the compressor would not bring the air up to release the brakes.
> Checked and the belt is Ok and the compressors seems to be turning
Ok.
> Is there a solenoid or a switch which activates and deactivates
> compressor. I get about 30lbs on the air gauge but no more. The
only
> other clue is that when the compressor is running normally it
makes
> enough noise that I can hear it and it is not doing that. Don't
know
> beans about what I am dealing with but any help or suggestions as
to
> what to look at or for would certainly be appreciated.
> John Heckman
> central Pa
> 1973 FC converted to 3208 CAT
12-31-2007, 02:11
I haven't had a chance to look into this today as yet. I appeciate
the help to this point. My question is what regulates the
compressor? The pulley is spinning all the time but I can tell by the
sound that it cycles on an off as far as a load.The compressor
mounting rattles rather noisily when it is changing the tanks. Does
something close and open to fill the tanks? I have this idea again
perhaps I am wrong that this is electrical? Or as Gregory said there
is a valve sticking. Now where are the valves? In the top of the
compressor. Remember this thing is bits and pieces of parts so that
makes it even more interesting. I had this occur before one time and
my shore batteries were down. I got the batteries charged up and the
compressor kicked in. Could be just lucky or a coincidence? Seems
like a leak would leak all the time rather then come and go. I plan
on fooling around here today with it so I will be back and forth. I
guess the first thing I will do is just start the bus and try again.
I need to figure this out because at some point its going to stay
broke. Likely at the worst possible time. So I need to understand
the system a little better.
John Heckman
central Pa
1973 FC
wont
> free.
> GregoryO'Connor
> 94ptRomolandCa
> that
turning
> Ok.
> the
> only
> makes
> know
> to
> > John Heckman
> > central Pa
12-31-2007, 02:36
Well, I went out and started the bus and wouldn't you know it the
compressor immediately kicked on and functioned as it should. It
cycled up to 125psi on the gauge and shut off and every thing seems
fine. But we know that is not the case. Idea's thoughts anything on
this with this little bit more information.
John Heckman
central Pa
1973 FC
Does
there
that
plan
again.
> John Heckman
> central Pa
> 1973 FC
> wont
is
up
a
> > free.
output
> > GregoryO'Connor
> > 94ptRomolandCa
found
> > that
brakes.
> turning
> > Ok.
> > the
The
> > only
> > makes
Don't
> > know
as
> > to
> > > John Heckman
> > > central Pa
12-31-2007, 02:47
My guess is it's the governor, assuming there is a governor on your coach.
Myself, others, have reported like problems and resolved the problem by
removing the old governor and installing a new (not rebuilt) governor.
> John Heckman
> central Pa
> 1973 FC
> the
> Does
> there
> that
> and
> the
> plan
> again.
> > John Heckman
> > central Pa
> > 1973 FC
> the
> > wont
> is
> up
> a
> and
> > > free.
> output
> > > GregoryO'Connor
> > > 94ptRomolandCa
> > > --- In
> "bubblerboy64"
> found
> > > that
> brakes.
> > turning
> > > Ok.
> > > the
> The
> > > only
> > > makes
> Don't
> > > know
> as
> > > to
> > > > John Heckman
> > > > central Pa
Curt Sprenger
Anaheim Hills, CA
12-31-2007, 03:03
Ok, Where is the governor? You guys gotta remember I am pretty much
stupid on this stuff. The only thing on the compressor is what
appears to be a small filter housing on right side of the thing
looking into the engine bay from the front of the bus. Something
obviously opens and or controls the compressor because when it is
functioning I can hear it cycle on and off.
John Heckman
central Pa
1973 FC
coach.
problem by
governor.
seems
on
> > John Heckman
> > central Pa
> > 1973 FC
appeciate
by
> > the
> > Does
again
> > there
> > that
> > and
> > the
Seems
> > plan
forth. I
> > again.
stay
understand
> > > John Heckman
> > > central Pa
> > > 1973 FC
check
> > the
> > > wont
there
> > is
air
> > up
build
> > a
> > and
had
thm
> > > > free.
> > output
> > > > GregoryO'Connor
> > > > 94ptRomolandCa
> > > > --- In WanderlodgeForum@yahoogroups.com 40yahoogroups.com>,
> > "bubblerboy64"
> > found
> > > > that
> > brakes.
> > > turning
> > > > Ok.
deactivates
> > > > the
> > The
> > > > only
it
> > > > makes
> > Don't
> > > > know
suggestions
> > as
> > > > to
> > > > > John Heckman
> > > > > central Pa
> Curt Sprenger
> Anaheim Hills, CA
12-31-2007, 03:16
I wish I could answer your question. Here is a link to an air governor
picture. If there is a governor on your coach, I believe it will look like
this one, probable an aluminum color, not gold.
http://velvac.thomasnet.com/viewitems/ai...ernor\
-d-2-style-
> John Heckman
> central Pa
> 1973 FC
> coach.
> problem by
> governor.
> the
> seems
> on
> > > John Heckman
> > > central Pa
> > > 1973 FC
> appeciate
> by
> > > the
> > > Does
> again
> > > there
> > > that
> > > and
> > > the
> Seems
> > > plan
> forth. I
> > > again.
> stay
> understand
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> check
> > > the
> > > > wont
> there
> > > is
> air
> > > up
> build
> > > a
> > > and
> had
> thm
> > > > > free.
> > > output
> > > > > GregoryO'Connor
> > > > > 94ptRomolandCa
> > > > > --- In
> > 40yahoogroups.com>,
> > > "bubblerboy64"
> > > found
> > > > > that
> > > brakes.
> > > > turning
> > > > > Ok.
> deactivates
> > > > > the
> > > The
> > > > > only
> it
> > > > > makes
> > > Don't
> > > > > know
> suggestions
> > > as
> > > > > to
> > > > > > John Heckman
> > > > > > central Pa
> > Curt Sprenger
> > Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
12-31-2007, 03:22
While I'm thinking about it...The governor is most likely mounted on a frame
member, main channel or cross member. That is where they are located on the
1986 and 1987 PTs. Kevin McKeowns was so well hidden it took a lot of
looking to find it. He relocated it to a convenient sport to make it
accessible for any future work.
-d-2-style-
> > John Heckman
> > central Pa
> > 1973 FC
> > coach.
> > problem by
> > governor.
> > the
> > seems
> > on
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> > appeciate
> > by
> > > > the
> > > > Does
> > again
> > > > there
> > > > that
> > > > and
> > > > the
> > Seems
> > > > plan
> > forth. I
> > > > again.
> > stay
> > understand
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
> > check
> > > > the
> > > > > wont
> > there
> > > > is
> > air
> > > > up
> > build
> > > > a
> > > > and
> > had
> > thm
> > > > > > free.
> > > > output
> > > > > > GregoryO'Connor
> > > > > > 94ptRomolandCa
> > > > > > --- In
> > > > 40yahoogroups.com>,
> > > > "bubblerboy64"
> > > > found
> > > > > > that
> > > > brakes.
> > > > > turning
> > > > > > Ok.
> > deactivates
> > > > > > the
> > > > The
> > > > > > only
> > it
> > > > > > makes
> > > > Don't
> > > > > > know
> > suggestions
> > > > as
> > > > > > to
> > > > > > > John Heckman
> > > > > > > central Pa
> > > Curt Sprenger
> > > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
Curt Sprenger
Anaheim Hills, CA
12-31-2007, 03:43
The governor is mounted directly on the compressor. The governor
controls the compresser by recycling the air and thus the compressor
does not work hard when not needed. The drier will be mounted
elseware, perhaps in a frame member.
Gardner
78FC33
--- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger"
on a frame
located on the
of
governor
look like
> > http://velvac.thomasnet.com/viewitems/ai...air-brake-
valves/air-governor-d-2-style-
pretty much
is
> > > John Heckman
> > > central Pa
> > > 1973 FC
on your
> > > coach.
> > > problem by
> > > governor.
it
> > > the
should. It
thing
> > > seems
anything
> > > on
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
> > > appeciate
tell
> > > by
> > > > > the
compressor
tanks.
> > > > > Does
idea
> > > again
said
> > > > > there
of the
parts so
> > > > > that
one time
> > > > > and
up and
> > > > > the
coincidence?
> > > Seems
go. I
> > > > > plan
> > > forth. I
try
> > > > > again.
to
> > > stay
> > > understand
> > > > > > John Heckman
> > > > > > central Pa
> > > > > > 1973 FC
spinning
> > > check
> > > > > the
because it
> > > > > > wont
running
> > > there
> > > > > is
the aux
> > > air
> > > > > up
way.
> > > build
> > > > > a
female end
> > > > > and
have
> > > had
to get
> > > thm
> > > > > > > free.
compressor
> > > > > output
> > > > > > > GregoryO'Connor
> > > > > > > 94ptRomolandCa
> > > > > > > --- In
> > > > > > 40yahoogroups.com>,
> > > > > "bubblerboy64"
bus I
> > > > > found
> > > > > > > that
> > > > > brakes.
to be
> > > > > > turning
> > > > > > > Ok.
> > > deactivates
> > > > > > > the
more.
> > > > > The
> > > > > > > only
normally
> > > it
> > > > > > > makes
that.
> > > > > Don't
> > > > > > > know
> > > suggestions
> > > > > as
> > > > > > > to
> > > > > > > > John Heckman
> > > > > > > > central Pa
> > > > Curt Sprenger
> > > > Anaheim Hills, CA
> > Curt Sprenger
> > Anaheim Hills, CA
> Curt Sprenger
> Anaheim Hills, CA
12-31-2007, 03:49
PeteM sent a link to a booklet on air brakes.
http://www.gnb.ca/0276/vehicle/pdf/ab_manual-e.pdf
On page 12 of the 77 page pdf booklet is a good explanation of the
compressor on and off operation. The book is generic which would be
best with a 'as built' system like you have. Understanding of the
contents of the book is a requirement for a Federal commercial
drivers license CDL. This book may be a good pdf file to down load
and save for reading.
You hear the compressor strain when it is loading the tanks with
air. The governer directs flow of the 'compressor discharge line'
Governer is set to direct the discharge line to load the tanks when
tank pressure falls to 85#. therefor when the gov starts refilling
the tanks, it is pushing air against a pressure of 85 from the start
and you hear the strain.
When the tank is at max pressure the governer direction of air
pumped by the full time compressor switches to 'Unload', there is no
strain because unload is a circular path of air from and to the
compressor. (the term unload is not a depletion of tank pressure)
I do not believe that any component of the air brake system is
electrical.
<snip from page 12>
The compressor is in constant drive with the engine.
Whenever the engine is running, so is the compressor.
When pressure in the system is adequate, anywhere
from a low of 80 psi to a high of 135 psi it is not necessary
for the compressor to pump air. A governor (2) controls the
minimum and maximum air pressure in the system by
controlling when the compressor pumps air. This is
known as the "loading" or "unloading" stage. Most
compressors have two cylinders similar to an engine's
cylinders. When the system pressure reaches its
maximum, which is between 115 and 135 psi, the
governor places the compressor in the "unloading"
stage.
GregoryO'Connor
94ptRomolandCa
much
> John Heckman
> central Pa
> 1973 FC
your
> coach.
> problem by
> governor.
it
> the
It
> seems
anything
> on
> > > John Heckman
> > > central Pa
> > > 1973 FC
> appeciate
tell
> by
> > > the
compressor
tanks.
> > > Does
> again
said
> > > there
so
> > > that
time
> > > and
> > > the
> Seems
I
> > > plan
> forth. I
> > > again.
> stay
> understand
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> check
> > > the
because it
> > > > wont
> there
> > > is
aux
> air
> > > up
> build
> > > a
end
> > > and
have
> had
get
> thm
> > > > > free.
> > > output
> > > > > GregoryO'Connor
> > > > > 94ptRomolandCa
> > > > > --- In WanderlodgeForum@yahoogroups.com > 40yahoogroups.com>,
> > > "bubblerboy64"
I
> > > found
> > > > > that
> > > brakes.
be
> > > > turning
> > > > > Ok.
> deactivates
> > > > > the
more.
> > > The
> > > > > only
normally
> it
> > > > > makes
> > > Don't
> > > > > know
> suggestions
> > > as
> > > > > to
> > > > > > John Heckman
> > > > > > central Pa
> > Curt Sprenger
> > Anaheim Hills, CA
12-31-2007, 12:09
That is correct. The brake system has no electrical components other
than the switches that turn on/off the tail lights. All control and
actuation is done through air pressure changes as controlled by
various valves. Similarly, the air bags (suspension) also have no
primary electrical components other than the valves that 'dump' the
air and sensors that report pressure, or lack thereof, to the buzzers
and dash panel gauges.
A total electrical failure should not cause you any immediate
problems in the safe handling or braking of your coach -- at least,
not from either the brakes or suspension components.
The other air operated items may have an electrically operated valve,
such as the stair-well cover, the air-step, the bulk oil filler, the
dump valves, and the dryer vent. Each of these has an electric switch
that actuates an electrically operated valve to activate/deactivate
the item. The air-step has a microswitch (under the coach) that can
be a problem if it becomes clogged with dirt or otherwise is moved
out of position.
The main braking system is partially isolated from the non-essential
appliances, but leaks in the auxiliary systems can lead to an
eventual loss of brake pressure or the inability to air up the coach.
When the air system is working properly, the coach should remain
charged with air for several hours after shutting down, if the
suspension isn't dumped. Frequent cycling of the air step will
deplete the air more quickly. If the system doesn't hold air for 6 to
12 hours (or more), then it's time to go over all the air-actuated
systems to hunt for leaks. Note: this is _much_ longer than the
standard required by most DMVs. Here's the CA DMV air brake check
procedure:
In-Cab Air Brake Check
NOTE: All items marked with an asterisk (*) are critical parts of the
in-cab air brake test and must be demonstrated during DMV testing.
They may be performed in any order. If these items are not performed
correctly, it is considered an automatic failure of the pre-trip test.
Test air leakage rate. (* second test only)
* With a fully-charged air system (typically 125 p.s.i.), turn off
the engine, release the service brake (brakes off), and let the
system settle (air gauge needle stops moving). Time the air pressure
drop. The loss rate should not be greater than:
— 2 p.s.i. or less in one minute for single vehicles.
— 3 p.s.i. or less in one minute for a combination of two vehicles.
— 5 p.s.i. or less in one minute for a combination of three or more
vehicles.
If the loss is too much, check for air leaks and fix.
* With roughly a fully charged air system (typically 100-125 p.s.i.),
turn off the engine. Release all brakes and allow the system to
settle (air gauge needle stops moving). Then apply full steady
pressure to the brake pedal (brake on) and hold. After the system
settles again, the air loss should not be more than:
— 3 p.s.i. or less in one minute for single vehicles.
— 4 p.s.i. or less in one minute for a combination of two vehicles.
— 6 p.s.i. or less in one minute for a combination of three or more
vehicles.
If the air loss is too much, check for air leaks and fix. For testing
purposes, identify if the air loss rate is too much.
*Check air compressor governor cut-out pressure. Pumping should start
at about 100 p.s.i. and stop at about 125 p.s.i. (130 p.s.i.
maximum). Run the engine at a fast idle. The air governor should cut-
out the air compressor at about the manufacturer's specified
pressure. The air pressure shown by your gauge(s) will stop rising.
For testing purposes, identify when the compressor cuts out.
*Check air compressor governor cut-in pressure. Start with the air
pressure above the governor cut-in level (no lower than 85 p.s.i.).
With the engine idling, slowly pump the brake pedal to reduce the air
tank pressure. Watch the air gauge between pumps to identify when the
compressor cuts in (needle starts to rise). This should be at about
the manufacturer's specified cut-in pressure. If the air governor
does not work as described, it may not keep enough air pressure for
safe driving. For testing purposes, identify when the compressor cuts
in.
NOTE: To perform this test correctly, the compressor cannot already
be pumping air. If it is, allow the governor to cut-out before
performing this test.
A full discussion of air brakes and their operation from the CA DMV
Commercial Drivers License booklet can be seen at:
<http://www.dmv.ca.gov/pubs/cdl_htm/sec5_a.htm>
El Sobrante CA
aeonix1@...
On Dec 31, 2007, at 7:49 AM, Gregory OConnor wrote:
> <snip>
> electrical.
