Fans in the gen compartment
01-12-2008, 11:55
On the ceiling of my generator compartment, I have two small squirrel-
cage fans that blow into a large rubber hose that exits under the bus. I assume these are supposed to exhaust heat from the gen area, but does anyone know what makes them run? Are they thermostat controlled? Best I can tell, mine never run, and I am considering removing them to facilitate some new sound deadening. Anyone know anything about these? Scott Forman 86 PT38 Memphis |
01-12-2008, 12:34
HI Scott:
Those fans only come on when the gen set is running. There is a silver solenoid near the front of the gen set compartment on the curb side and that is where the 12 vdc comes to run those fans. Most of those fans are DOA and when I have re insulated the gen set compartment, I take them down but I do put them back up even if not running. one can happen upon working fan motors from time to time and it is an easy replacement. Many owners have just taken the fans out and tossed them too. Depends on your mind set at the time. Safe travels, Ralph and Charolette Fullenwider 84FC35 "Ruff Diamond" ( new floor and captains chairs, looking good) Duncan, Oklahoma At 11:55 PM 1/12/2008 +0000, you wrote: >On the ceiling of my generator compartment, I have two small squirrel- >cage fans that blow into a large rubber hose that exits under the bus. >I assume these are supposed to exhaust heat from the gen area, but does >anyone know what makes them run? Are they thermostat controlled? Best >I can tell, mine never run, and I am considering removing them to >facilitate some new sound deadening. > >Anyone know anything about these? > >Scott Forman >86 PT38 >Memphis > > |
01-12-2008, 14:37
Scott,
Contact Kevin McKeown. "Krminyl@aol.com" . He owns a 1986 PT38 and he may be able to assist and advise. On Jan 12, 2008 3:55 PM, Scott Forman <
"sforman@renasant.com"> wrote:
