turn signal switch
02-01-2008, 15:37
turn signal switch
My turn signal switch is not cancelling all the time. Doesnt look like
you can replace the switch. The whole stalk must be purchased. I know this item is off some HD truck. Couldnt find it in my Grote catalog. Does anyone know what vehicle uses this switch? Maybe a part #. Looking in the BB catalog it appears that most units use the same switch. I havent checked with BB for a price yet. Bruce 1988 FC35 |
02-02-2008, 03:39
turn signal switch
Hi Bruce, There are a couple of phillips screws that can loosen, One is visible and I believe the other is under the steering columne cosmetic covering, Tightening may help. Also years ago there was a recall on this switch, They were available at the Dealers at that time, Holland Michigan has a few , I acquired one about 4 years ago and I believe the previous owner of the McGinnis coach ,(BirdBraines) had one, The entire switch must be replaced and it is not a simple task. Guessing there are atleast 20 wire connections that need spliced, I chose to keep the replacement in the box it was shipped in, for future turnsignal trouble. Bill 88 FC Michigan -- In WanderlodgeForum@yahoogroups.com, "birdshill123" > > My turn signal switch is not cancelling all the time. Doesnt look like > you can replace the switch. The whole stalk must be purchased. I know > this item is off some HD truck. Couldnt find it in my Grote catalog. > Does anyone know what vehicle uses this switch? Maybe a part #. > Looking in the BB catalog it appears that most units use the same > switch. I havent checked with BB for a price yet. > > Bruce > > 1988 FC35 > |
02-02-2008, 07:12
turn signal switch
Thanks Bill:
I took the switch right off and applied some Lubriplate. That helped some but it still acts up sometimes. The screws are very tight. On Monday I will check with BB for a price. I just know it is off a HD truck. Bruce 1988 FC35 |
