Water Filter
02-07-2008, 17:58
Water Filter
The water filter on my 1985fc developed a leak. I removed it and
bypassed it. Do I track down the original part or does anyone have a replacement. Thanks... Mario 1985 fc 35 in sunny Leucadia CA. |
02-08-2008, 14:28
Water Filter
Buy a small domestic system Lowes Home Depot have them Easier to buy
the filters and replacement parts Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "mariopatti1" > > The water filter on my 1985fc developed a leak. I removed it and > bypassed it. Do I track down the original part or does anyone have a > replacement. Thanks... > Mario 1985 fc 35 in sunny Leucadia CA. > |
04-08-2009, 01:42
Water Filter
To ALL birders.
What kind of a potable water filter you all use. The reason I am asking this is because my coach came with a Bactereostatic filter mounted under my bed. This thing came from Louisiana and caost 10 years ago $400.00. It works fine but seems rather pricey. I use a regular 5 - micron sediment filter at the camp water outlet and the water then goes through the bacteiostatic to the tank. Use a small (0.5 micron) filter in kitchen for drinking, coffee, ice etc. Is there something new or different on the market today??? Thanks Juergen In PA 1991 WLSP 36 |
04-08-2009, 01:56
Water Filter
--- In WanderlodgeForum@yahoogroups.com, "Juergen"
> > To ALL birders. > What kind of a potable water filter you all use. The reason I am asking this is because my coach came with a Bactereostatic filter mounted under my bed. This thing came from Louisiana and caost 10 years ago $400.00. It works fine but seems rather pricey. > I use a regular 5 - micron sediment filter at the camp water outlet and the water then goes through the bacteiostatic to the tank. Use a small (0.5 micron) filter in kitchen for drinking, coffee, ice etc. > Is there something new or different on the market today??? > Thanks > Juergen In PA > 1991 WLSP 36 I just use one of those cheap attachment types that go on sink faucet or just drink bottled water. I guess if I were to be out full timming I would want something to filter the main water coming out of the system but I don't so bottle water seems the best to us. Jon\Rebel Bird Bremerton washington http://i2.photobucket.com/albums/y4/1942...ustom\ %20Motor%20Home/Donavanbirthdayparty016.jpg > |
04-08-2009, 05:13
Water Filter
Juergen -
We have an Everpure filter under the galley that supplies a small water tap on the galley sink. (No point in running wash water through this filter.) This is the filter cartridge: http://www.campingworld.com/shopping/ite...ridge/4142 The cartridge mounts in a filter head similar to this: http://www.freshwatersystems.com/p-703-q...cket.\ aspx Also, all the water entering the coach flows through a 10 micron filter that mounts on the side of the coach anytime a hose is connected. Bob Griesel '84FC1 WLII WA --- In WanderlodgeForum@yahoogroups.com, "Juergen" > > To ALL birders. > What kind of a potable water filter you all use. The reason I am asking this is because my coach came with a Bactereostatic filter mounted under my bed. This thing came from Louisiana and caost 10 years ago $400.00. It works fine but seems rather pricey. > I use a regular 5 - micron sediment filter at the camp water outlet and the water then goes through the bacteiostatic to the tank. Use a small (0.5 micron) filter in kitchen for drinking, coffee, ice etc. > Is there something new or different on the market today??? > Thanks > Juergen In PA > 1991 WLSP 36 > |
04-09-2009, 09:01
Water Filter
12-29-2010, 12:24
Water Filter
Hi folks,
My '86 PT-40 has a heavy, large diameter PVC water filter under the bed. Looks original. Anyway, it developed a hairline crack, so I pulled it out and bypassed it while I figure out what to do. Questions: 1. What's the purpose of this thing? Looks like it filters incoming water, but for what? 2. Should I replace it? If so, is there a recommended replacement model? Thanks folks. -Ryan '86 PT-40 8V92 |
12-29-2010, 13:34
Water Filter
Hi Ryan;
The original filter was a silver impregnated material that was very efficient in delivering good water from across a world wide span of water treatments or lack of. These unit were and are expensive but available. Now then, with that said a filter system of some sort is definitely needed and should be re installed. You can go with a replaceable cartridge type or? I suggest the files section be researched or do a search for water filter in the messages and you should get hits on the subject. Safe travels, Ralph & Charolette Fullenwider '84 FC35 "Ruff Diamond" Duncan, Oklahoma Sent via BlackBerry by AT&T -----Original Message----- From: Ryan Wright Sender: WanderlodgeForum@yahoogroups.com Date: Wed, 29 Dec 2010 16:24:44 To: wanderlodgeforum Reply-To: WanderlodgeForum@yahoogroups.com Subject: [WanderlodgeForum] Water filter Hi folks, My '86 PT-40 has a heavy, large diameter PVC water filter under the bed. Looks original. Anyway, it developed a hairline crack, so I pulled it out and bypassed it while I figure out what to do. Questions: 1. What's the purpose of this thing? Looks like it filters incoming water, but for what? 2. Should I replace it? If so, is there a recommended replacement model? Thanks folks. -Ryan '86 PT-40 8V92 ------------------------------------ Yahoo! Groups Links |
12-29-2010, 13:42
Water Filter
12-29-2010, 14:01
Water Filter
Mine is disconnected long ago. Note to cap off the air supply, as I had a situation where an air leak from that line prevented the coach from airing up. RWW
On Dec 29, 2010, at 7:42 PM, Ernie Ekberg <"ernietex@yahoo.com"> wrote:
