brake light switch
02-19-2008, 02:57
brake light switch
Bruce,
On my 1986, I found a terminal strip with the wiring (labeled by the factory) inside the generator battery compartment, street side, in the same compartment as the windshield washer reservoir tank. Maybe you can be as lucky?
Kevin McKeown
Yorba Linda, CA
1986 38' PT
In a message dated 2/19/2008 10:20:34 A.M. Pacific Standard Time, birdshill123@... writes:
I am going to install a US Gear Unified brake system on our 88 FC. I
have installed these before. However, where do I find the brake light
switch or the wiring that leads to the switch ? Is it under the floor
by the treadle.
Thanks
Bruce
1988 FC35
Delicious ideas to please the pickiest eaters. Watch the video on AOL Living.
02-19-2008, 06:19
brake light switch
by the treadle.
Thanks
Bruce
1988 FC35
02-19-2008, 06:33
brake light switch
HI Bruce:
Yes, there are 2 switches. They are usually installed directly on the break
valve (front/rear) or they may have been routed to header usually found in
the drivers side front compartment.
Safe travels,
84FC35 "Ruff Diamond"
Duncan, Oklahoma
>by the treadle.
>Thanks
>Bruce
>1988 FC35
02-19-2008, 10:23
brake light switch
Bruce,
There is one in the battery bay driver side.
As Ralph suggests there is a header bracket just about an inch above
the batteries, mounted to a bracket with an air manifold.
Not sure of # 2.
Bill 88 FC Michigan
> HI Bruce:
the break
found in
> Safe travels,
> Duncan, Oklahoma
FC. I
light
floor
> >by the treadle.
> >Thanks
> >Bruce
> >1988 FC35
02-19-2008, 11:26
brake light switch
Thanks for the replies. That is going to make it very easy to tap into
the brake switch circuitry.
Bruce
1988 FC35
