Mor-Co 24 Batteries
05-20-2005, 08:39
Mor-Co 24 Batteries
I know most of us have batteries far superior to the ones in question
here ....but just in case you run across some MOR-CO 24s in your wanderings. Kip In 2004 a battery explosion occurred at the VOR site at Socorro, New Mexico. After an investigation and lab tests, it was determined that the battery explosion occurred because the battery was poorly made [from recycled batteries] in Mexico. The battery, Model MOR-CO 24 is a lead acid battery sold by Interstate Batteries. The battery was installed in June 2003 and had been in service 15 months prior to the explosion. AOS is recommending that if this model of battery (Interstate Battery Model MOR-CO 24, Type 8-D) is found in service, it should be removed and replace with an equivalent rated battery. Results: Severe corrosion of positive plates and strap. Several positive plates broke off from strap (probable cause of explosion) Intermittent connect to the strap resulted in arching (arching ignited hydrogen in battery causing the explosion). Poor Quality in Manufacturing Note: The facility also reported repeated failures from this same type of battery in other installations. |
05-20-2005, 09:53
Mor-Co 24 Batteries
Kip:
Thank you for relaying this information, do you have a verifiable source for this? - Jeff Miller http://www.wanderlodge.net http://www.millercoachworks.com --- In WanderlodgeForum@yahoogroups.com, "kip_1948" wrote: > I know most of us have batteries far superior to the ones in question > here ....but just in case you run across some MOR-CO 24s in your > wanderings. > > Kip > > In 2004 a battery explosion occurred at the VOR site at Socorro, New > Mexico. After an investigation and lab tests, it was determined that > the battery explosion occurred because the battery was poorly made > [from recycled batteries] in Mexico. The battery, Model MOR-CO 24 is > a lead acid battery sold by Interstate Batteries. The battery was > installed in June 2003 and had been in service 15 months prior to the > explosion. > > AOS is recommending that if this model of battery (Interstate Battery > Model MOR-CO 24, Type 8-D) is found in service, it should be removed > and replace with an equivalent rated battery. > > Results: > Severe corrosion of positive plates and strap. > Several positive plates broke off from strap (probable cause of > explosion) > Intermittent connect to the strap resulted in arching (arching > ignited hydrogen in battery causing the explosion). > Poor Quality in Manufacturing > > Note: The facility also reported repeated failures from this same > type of battery in other installations. |
