1985 Airstep parts
04-03-2008, 10:41
1985 Airstep parts
Greetings:
The problem began during this winter in 12 DF temperatures, and has worsened until now the airstep on my 1985 PT40 has failed: air leaks constantly from the controller and the main cylinder, and the step does not retract. Are repair kits (elastomer seals, for example) available to rebuild the three cylinders? Are NOS or other replacement parts available? The three assemblies are marked... Thanks-- M.R.Kane 1985 PT40 currently Pilot Point, TX |
04-03-2008, 11:25
1985 Airstep parts
We have the control solenoids for the air step
give us a call Stephen 77fc35 Dupreeproducts.com --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings: > > The problem began during this winter in 12 DF temperatures, and has > worsened until now the airstep on my 1985 PT40 has failed: air leaks > constantly from the controller and the main cylinder, and the step > does not retract. Are repair kits (elastomer seals, for example) > available to rebuild the three cylinders? Are NOS or other > replacement parts available? > > The three assemblies are marked... > > > > > > > > Thanks-- > > M.R.Kane > 1985 PT40 > currently Pilot Point, TX > |
04-03-2008, 13:24
1985 Airstep parts
Hi Mike,
The replacement cylinders can be had at Grainger (take the originals with you and they can size them up), but the small locking cylinder was a custom built piece for Bluebird from Clippard. You can order a small cylinder from Grainger too, but it will have a threaded end and you'll have to grind it down to a smooth point. As mentioned, Stephen has the switches and controller components. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings: > > The problem began during this winter in 12 DF temperatures, and has > worsened until now the airstep on my 1985 PT40 has failed: air leaks > constantly from the controller and the main cylinder, and the step > does not retract. Are repair kits (elastomer seals, for example) > available to rebuild the three cylinders? Are NOS or other > replacement parts available? > > The three assemblies are marked... > > > > > > > > Thanks-- > > M.R.Kane > 1985 PT40 > currently Pilot Point, TX > |
04-13-2008, 12:29
1985 Airstep parts
Greetings all:
I have obtained replacement parts to repair my ailing airstep, but none are the same as the originals, leaving me with some questions. The new relay/control assembly has all black wires, but the two solenoids are separate, so it is easy to see which wire goes to which solenoid. On the original control, all the wires emerge from one end. The hot wires from the coach are red and yellow, but I can't tell which should go where on the new controller. Any help? What is recommended for replacement air lines? Thanks-- M.R.Kane 1985 PT40 currently Pilot Point, TX |
04-13-2008, 17:15
1985 Airstep parts
The solenoid is not polarity protected ground one wire from each end
and connect the red and yellow to the two remaining wires one at each end if the step acts funky just swap the red and yellow Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "mrkane1952" <mrkane@...> wrote: > > Greetings all: > > I have obtained replacement parts to repair my ailing airstep, but > none are the same as the originals, leaving me with some questions. > The new relay/control assembly has all black wires, but the two > solenoids are separate, so it is easy to see which wire goes to which > solenoid. On the original control, all the wires emerge from one end. > The hot wires from the coach are red and yellow, but I can't tell > which should go where on the new controller. Any help? > > What is recommended for replacement air lines? > > Thanks-- > > M.R.Kane > 1985 PT40 > currently Pilot Point, TX > |
