Alcoa Wheels
03-23-2008, 07:19
Post: #21
Alcoa Wheels
--- In WanderlodgeForum@yahoogroups.com, "bubblerboy64"
> Well I have them home. They're nice but of course not like new and
not
> polished the why a proud BB's owner would like them. I
> started "working" on one of them and I just don't think I have it
in me
> to do four of them. I suppose it I have to do it myself I will but
> does anyone know of a professional wheel shop or a way to have them
> done professionally. A location in the Pa Maryland area would be
> helpful since shipping could get pricy. I searched on the net and
only
> found a place in BC which out of reach.
> John Heckman
> central Pa
> 1973 FC
John I would use the yellow pages for truck tires and rims. We have
a place over in tacoma that deals in truck tires and I noticed that
they also had rims. I observered a guy in the tire bay polishing
rims and so that is why I said you could contact a large tire outfit
that handles truck tires in your area. Jon
03-23-2008, 15:20
Post: #22
Alcoa Wheels
John,
I worked my fingers to the bone, wore out my 3/8 drill I have had
for 40 years, and the wheels are far from done. Mine are probably
like yours, lots of pits. Find a pro, that is what I will probably
do after correcting the other things on my coach. See you at Maxton.
Gardner
78FC33
> Thanks Shane, I'll check both of those out Monday. My fingers and
> hands are sore from my efforts. Not a good thing for my day job. I
> would have to start with something a lot more aggressive then 400
or
> I would attempt it. So considering the point at which I am
starting
> and the results I would like to have I better get some help. Same
> ole story know your limits. The wheels are decent but there are
some
> pits. I actually think from what I've been able to find on the
web
> that the professionals turn them on a lathe to start. That would
be
> about the only why I could see doing this from a practical stand
> point. Probably only have to take a couple thousands off but
that's a
> lot of sanding. I tried a couple things using an drill and that
was
> too aggressive and too difficult to get a smooth result. Just too
> much to do it by hand for me. I did start on the worst one I
think
> but still my best bet is to farm this one out. Thanks and I'll
make
> some calls Monday and let ya know. Looking forward to the run to
> Maxton in a ten days.
> John Heckman
> central Pa
> 1973 FC
> > Hi John,
> > There is a guy on Carlisle Pike off I-81 behind the strip
club
> that
> > does them at odd times. If you stop by one of the garages at the
> > flying hook or TA they can tell you more. I had a fun time doing
> mine
> > with wet sandpaper. Started at 400 or 600 grit and worked up to
1500
> > or 2000 grit and finally a buffing wheel on a mechanical buffer.
> Still
> > was not as good as a pro can get them with the right tools and
> > attachments. They probably know where to get them done at the
John
> > Wayne chrome shop down at Greencastle too.
> > Shane Fedeli
> > 85PT40
> > Hershey, PA
> and not
it
> in me
will
> but
> them
be
> and only
> > > John Heckman
> > > central Pa
> > > 1973 FC
03-23-2008, 16:27
Post: #23
Alcoa Wheels
Gardner, I found a couple sights on the web which show how it's
done. One is VIS Wheel Polishing and Refinishing. There is a neat
video on their sight. Apparently there are machines which handle it
easily. Some you don't even have to take the tire off the wheel. I
will make some calls tomorrow and see if there is a local outfit
don't it. My wheels are not that bad but it's still entirely too much
to do (for me). Sounds like it will cost about $50 a wheel and that
seems entirely reasonable considering how sore my fingers are from
what would be just a start on one of mine. I'll see what I can come
up with. This neck of the woods is just filled with truck terminals
and such. Should be something around this part of Pa. Shane gave me a
couple leads. I'll keep you informed.
John Heckman
central Pa
1973 FC
> John,
had
> Gardner
> 78FC33
I
> or
> starting
Same
> some
> web
> be
> that's a
> was
> think
> make
> > John Heckman
> > central Pa
> > 1973 FC
> > > Hi John,
> club
> > that
doing
> > mine
> 1500
buffer.
> > Still
> John
> > > Shane Fedeli
> > > 85PT40
> > > Hershey, PA
new
> > and not
have
> it
> > in me
> will
> > but
have
> > them
would
> be
net
> > and only
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
03-23-2008, 17:35
Post: #24
Alcoa Wheels
Alumniunm is shiney if it is flat. scratches interrupt reflection
and hold dirt. That is why it is best to remove pits and big
scratches with wet sandpaper then remove sanding marks with finer
(higher number grit) sand paper then polish the flat shine back into
the metal with a wheel. If you have wax on the rim road grime will
not touch the metal and the wax will protect the rim from
oxidation. When the rim needs a touch up it is important to remove
the wax fist with laundry soap so you wont be loading up the polish
compound grit with wax.
Now that my wheels are polished I wash off the wax; rub mothers
brand compound in; then clean the mothers off with a onestep
cleaner/wax. That keeps the mothers looking good.
GregoryO'Connor
94ptRomolandCa
it
I
much
that
come
terminals
me a
> John Heckman
> central Pa
> 1973 FC
> > John,
> had
probably
probably
Maxton.
> > Gardner
> > 78FC33
> and
job.
> I
400
> > or
> > starting
> Same
are
> > some
> > web
would
> > be
stand
> > that's a
that
> > was
too
> > think
I'll
> > make
to
> > > John Heckman
> > > central Pa
> > > 1973 FC
> > > > Hi John,
> > club
> > > that
> doing
> > > mine
to
> > 1500
> buffer.
> > > Still
> > John
> > > > Shane Fedeli
> > > > 85PT40
> > > > Hershey, PA
> new
> > > and not
> have
> > it
> > > in me
> > will
> > > but
> have
> > > them
> would
> > be
> net
> > > and only
> > > > > John Heckman
> > > > > central Pa
> > > > > 1973 FC
03-24-2008, 01:27
Post: #25
Alcoa Wheels
I found a place in Carlisle Pa which does the VIS process. Let you
know how it works out for me. The video looks inpressive.
John Heckman
central Pa
1973 FC
into
> GregoryO'Connor
> 94ptRomolandCa
neat
> it
> I
> much
> that
from
> come
> terminals
> me a
> > John Heckman
> > central Pa
> > 1973 FC
> > > John,
have
> > had
> probably
> probably
> Maxton.
> > > Gardner
> > > 78FC33
fingers
> > and
> job.
> > I
> 400
> > > or
> > > starting
> > Same
> are
> > > some
> the
> > > web
> would
> > > be
> stand
> > > that's a
> that
> > > was
> too
> > > think
> I'll
> > > make
> to
> > > > John Heckman
> > > > central Pa
> > > > 1973 FC
> > > > > Hi John,
strip
> > > club
> > > > that
at
> the
> > doing
> > > > mine
up
> to
> > > 1500
> > buffer.
> > > > Still
> and
> the
> > > John
> > > > > Shane Fedeli
> > > > > 85PT40
> > > > > Hershey, PA
like
> > new
> > > > and not
> > have
> > > it
> > > > in me
I
> > > will
> > > > but
> > have
> > > > them
> > would
> > > be
> > net
> > > > and only
> > > > > > John Heckman
> > > > > > central Pa
> > > > > > 1973 FC
