RV 3012 M
05-20-2008, 09:39
RV 3012 M
---------- Forwarded message ----------
From: <b class="gmail_sendername">Nick Klein[/b] <"customerservice@xantrex.com">
Date: Tue, May 20, 2008 at 3:42 PM
Subject: RE: Case Number (00102618) [ ref:00D3Wjr.500350ZIy:ref ]
To: ""dorn@hetzel.org"" <"dorn@hetzel.org">
[ref:00D3Wjr.500350ZIy:ref]
Dear dorn,
They are basically exactly the same units, but below is an explanation:
This line consisted of models RV2012M, RV2512M, and RV3012M, which were 2000, 2500 and 3000 watts respectively. These units were only used for Monaco coaches, and the M designation referred to a series of default programming items requested by Monaco. (See the section on "RC7 & RC7GS Setup Menus".)
Two knockouts on the inverter were left open at the factory. Otherwise they were physically indistinguishable from the regular version, and had no other unique features. Warranty is the same.
The "software" defaults which may be different from standard models were:
SEARCH SENSE – DEFEAT
BAT CAPACITY – AUTO
BAT TYPE – LIQUID LEAD ACID
CHARGE RATE – 80%
Yes, both models were designed for RV use.
For all correspondence regarding this issue, please make sure to include the case number (00102618) in the subject line of the email.
Technical Support
Customer Service Operations
Xantrex Technology Inc.
Website: www.xantrex.com
Confidentiality Notice: This e-mail message, including any attachments, is for the sole use of any recipient(s) and may contain confidential and privileged information. Any unauthorized review, use, disclosure or distribution is prohibited. If you are not the intended recipient, please contact the sender by reply e-mail and destroy all copies of the original message.
Case number: 00102618
Case Subject: how is rv3012M different from other rv3012
Description: Can you explain the differences between RV3012M and other RV3012 models. What does M series software mean? Are these models still suitable for an RV application?
05-21-2008, 11:03
RV 3012 M
Here is my responce from Xantrex to the RV3012M question.
I am awaiting a second e-mail to confirm if the new control panel
the RC/GS will funtion as well as the older RC7.
According to my local tech guy it will. You should be able to set
the inverter/charger to your particular application.
Kurt Horvath
95 PT-42
[ref:00D3Wjr.500350dxJ:ref]
Dear Kurt Horvath,
They are very similar units. Below is an explanation of the RV3012M
model and then the RV 3012 GS :
The RV3012M, which is 3000 watts respectively. These units were only
on “RC7 & RC7GS Setup Menus”.)
were:
BAT CAPACITY – AUTO
CHARGE RATE – 80%
The RV 3012 GS is the newer version that replaced the RV series.
This series looks almost the same as the original RV and largely has
the same specs and functions. Its main visual distinction is that
it only has two com ports, not three. There were a few enhancements
made with the Auto Gen Start feature and programming.
Both models were designed for RV use.
"RV3012 M be reprogramed to standard specs? If so what would the
cost be?"
You could program it yourself if you have a RC7, but if you do not
have an RC7 then you might be able to locate one by doing a "google"
search of the dealers online otherwise they are no longer available
as they have been obsolete for awhile now.
It would be good to update the system rather than repair the freedom
if they are really 15 years old.
I suggest the newer RV 3012 GS model rather than the "M" model.
But if it is a big difference in cost the "M" model will be fine if
an RC7 comes with it.
include the case number (00102708) in the subject line of the email.
Technical Support
Website: http://www.xantrex.com
Case number: 00102708
Case Subject: Xantrex RV 3012 M Inverter / Charger
Description: Could you please explain the diffrence between the
model RV 3012 M and the new RV 3012 GS. Is it just an older model or
are there significant diffrences between the two units? RV3012 M be
reprogramed to standard specs? If so what would the cost be?Can the
model
I have the old Freedom Combi aqua blue colored units in my coach.
They are 15 years old. would it be better to replace these unites
with the RV 3012 M or should I just have them refurbished. I am in
the process of refubishing all the systems so now is a good time to
do the inverter sysytem.
Thanks for your time,
Kurt Horvath
--- In WanderlodgeForum@yahoogroups.com, "Dorn Hetzel"
> From: Nick Klein
> To: "dorn@..."
> Dear dorn,
explanation:
were
used for
default
RC7GS
> Setup Menus".)
Otherwise they
had no other
models were:
> BAT CAPACITY – AUTO
> CHARGE RATE – 80%
include the
> Technical Support
attachments, is
please
original
> message.
other
models still
05-22-2008, 02:13
RV 3012 M
Well, I've ordered one of those RV3012M units. At $670 including shipping it seems worth taking the chance.
My present unit is just a battery charger with no inverter function anyway, and it seems to be dying, so with or without the proper RC unit it will be an upgrade Smile
Dorn Hetzel
77FC35
Hogansville, GA
On Wed, May 21, 2008 at 7:03 PM, bumpersbird <"bumpersbird@yahoo.com"> wrote:
Kurt Horvath
95 PT-42
Dear Kurt Horvath,
were:
BAT CAPACITY – AUTO
CHARGE RATE – 80%
cost be?"
Technical Support
model
Kurt Horvath
--- In "WanderlodgeForum%40yahoogroups.com", "Dorn Hetzel"
> From: Nick Klein
> To: "dorn@..."
> Dear dorn,
explanation:
were
used for
default
RC7GS
> Setup Menus".)
Otherwise they
had no other
models were:
> BAT CAPACITY – AUTO
> CHARGE RATE – 80%
include the
> Technical Support
attachments, is
please
original
> message.
other
models still
05-22-2008, 03:03
RV 3012 M
Dorn,
On ebay, type in Xantrex and scroll to page 3 or 4, there is an outfit in Mo. that has 15 -RC7 controlers for sale. They are not in origonal packaging but he states they are perfect condition. E-Bay Item number: 380027259205.
I'm still deciding what to do. The problem is should I place these new inverters back in the same place or move them into to thebay with the tool box and loose my BBQ grill.
Re routing all thoses cables is like reinventing the wheel.
Kurt Horvath
95 PT-42
--- On Thu, 5/22/08, Dorn Hetzel wrote:
Subject: Re: [WanderlodgeForum] Re: RV 3012 M
Date: Thursday, May 22, 2008, 9:13 AM
Dorn Hetzel
77FC35
Hogansville, GA
Kurt Horvath
95 PT-42
[ref:00D3Wjr. 500350dxJ: ref]
Dear Kurt Horvath,
were:
BAT CAPACITY – AUTO
CHARGE RATE – 80%
cost be?"
Technical Support
Website: www.xantrex. com
reprogramed
model
Kurt Horvath
> From: Nick Klein
> Subject: RE: Case Number (00102618) [ ref:00D3Wjr. 500350ZIy: ref ]
> To: "dorn@..."
> [ref:00D3Wjr. 500350ZIy: ref]
> Dear dorn,
explanation:
were
used for
default
RC7GS
> Setup Menus".)
Otherwise they
had no other
models were:
> SEARCH SENSE –
DEFEAT
> BAT CAPACITY – AUTO
> CHARGE RATE – 80%
include the
> Technical Support
attachments, is
please
original
> message.
other
models still
05-22-2008, 05:18
RV 3012 M
Ya,
I got one too and the RC7 display... Seems like a good replacement for
the Pace1500 :}
I called Xantrex and asked about the grounding issue in the manual and
its not a problem. Only thing you lose by not having the chassis
ground going through the inverter is the DC load info. You still get
the charge current and AC load info.
Since we have the shunts to read that info anyway I dont see that as a
big concern...
/Joe
'87PT40
San Francisco
05-29-2008, 08:50
RV 3012 M
Hi Kurt,
Did you receive a response from Xantrex about the RC/GS remote to
control this RV 3012 M? I am thinking about ordering one too &
replace all of the old components such as the Redline unit in my PT.
Can't find any info about the two working together.
Terry
Kurt Horvath
95 PT-42
Dear Kurt Horvath,
were:
BAT CAPACITY – AUTO
CHARGE RATE – 80%
cost be?"
Technical Support
model
Kurt Horvath
"Dorn Hetzel" >
> From: Nick Klein ...>
> To: "dorn@..." "dorn@..."
> Dear dorn,
explanation:
were
used for
default
RC7GS
> Setup Menus".)
Otherwise they
had no other
models were:
> BAT CAPACITY – AUTO
> CHARGE RATE – 80%
include the
> Technical Support
attachments, is
please
original
> message.
other
models still
05-29-2008, 09:30
RV 3012 M
If I understand the research I did, the RC7/GS works with the older RV3012 and it works with the newer GS (Gen. Start) model. The RC7 is for the older unit, the RC7/GS works for both the old and new units. Someone correct me if I'm wrong.
Check ebay http://tinyurl.com/457nr2 for the RC7/GS remote control. Eight of them available.
, May 29, 2008 at 1:50 PM, Terry Neal <"bird@mountainrovers.com"> wrote:
Hi Kurt,
Terry
Kurt Horvath
95 PT-42
Dear Kurt Horvath,
were:
BAT CAPACITY – AUTO
CHARGE RATE – 80%
cost be?"
Technical Support
model
Kurt Horvath
"Dorn Hetzel"
> From: Nick Klein
> Dear dorn,
explanation:
were
used for
default
RC7GS
> Setup Menus".)
Otherwise they
had no other
models were:
> BAT CAPACITY – AUTO
> CHARGE RATE – 80%
include the
> Technical Support
attachments, is
please
original
> message.
other
models still
Curt Sprenger
Anaheim Hills, CA
05-30-2008, 04:32
RV 3012 M
Terry,
Here is the responce from Xantrex Customer Serive.
I did buy 2 of these units. They are new in the box and Sun Electric
is an aurthorized dealer so the warrantie should be good.
I spoke with several tech guys and of course got several diffrent
answers. About all aspects of these units.
I was most impressed with a guy from Buddy Gregg Motorhomes in
Knoxville TN. Wayne Clapp a veteran BB Tech. His first question was
did I plan on keeping the coach? Well of course. Then you must get
these inverters out of the engine compartment and into one of the
bays. So were are going the reinvent the wheel. Not really a problem
the old compartment is really not large enough for the new inveters.
With the inverter box empty I think I'll throw in a couple more
Lifeline gell cells. That will make 8 house batts. Wayne also told me
he can with the addition of a few relays make the AC run on Batts.
With the additional 2 Lifeline's and the 2 new invetrers running off
of 8 Batts. in 2, four Batt. banks I should be able to run 2 AC'S.
The 300 amp alternator should be able to tow the line. I would be
nice to run the roof air with out the generator. Any help in fuel
economy is welcomed.
Any body want to buy a electric grill for their coach? Mine is coming
out, slide and electric components included.
I also bought 2 RC7/GS controlers off of e-bay. The were the best
deal for the $'s.
Kurt Horvath
95 PT-42 WLWB
Dear kurt daniel horvath,
"Can the RC/GS Remote Panel be use in place of the RC7."
No , this will not work properly. You are better off trying to locate
an RC7 by seaching the internet and the many dealers who may have a
NOS unit.
"Is the 24 month warrantie good on these new in the box units?"
If the unit is new in the box and purchased from proper dealer who
purchased it from a Xantrex Distributor than we shall honor the
warranty.
Xantrex Technical Support
Email: customerservice@...
t: (360) 925-5097 / (800) 670-0707
f: (360) 435-2636
--------------- Original Message ---------------
To: customerservice@...
Subject: Fw: Case Number (00102708) [ ref:00D3Wjr.500350dxJ:ref ]
----Original Message----
Date: 05/21/2008 3:27 PM
To:
Subj: RE: Case Number (00102708) [ ref:00D3Wjr.500350dxJ:ref ]
Dear Mr.Nick Klien.
If so, are there any peculiarities involed or is it just a simple
choice of which control is available.
Yes price is a consideration here the old unites are new and are an
exceptional deal at this time.
Thank You for your time,
Kurt Horvath
--- In WanderlodgeForum@yahoogroups.com, Terry Neal wrote:
> Hi Kurt,
replace
> all of the old components such as the Redline unit in my PT. Can't
find
> Terry
> > Kurt Horvath
> > 95 PT-42
> > Dear Kurt Horvath,
RV3012M
only
series
models
> > were:
> > BAT CAPACITY – AUTO
> > CHARGE RATE – 80%
has
enhancements
> > cost be?"
a "google"
available
freedom
if
email.
> > Technical Support
contain
or
be
> > model
to
> > Kurt Horvath
> > , "Dorn Hetzel"
> > > From: Nick Klein
> > > To: "dorn@"
> > > Dear dorn,
> > explanation:
which
> > were
> > used for
> > default
> > RC7GS
> > > Setup Menus".)
> > Otherwise they
> > had no other
> > models were:
> > > SEARCH SENSE - DEFEAT
> > > BAT CAPACITY - AUTO
> > > BAT TYPE - LIQUID LEAD ACID
> > > CHARGE RATE - 80%
> > include the
> > > Technical Support
> > attachments, is
confidential
> > and
disclosure or
recipient,
> > please
> > original
> > > message.
> > other
> > models still
05-30-2008, 04:50
RV 3012 M
A guy at Sun Electronics said the "M" is for "Marine" units...interesting.
On Fri, May 30, 2008 at 9:32 AM, bumpersbird <"bumpersbird@yahoo.com"> wrote:
Terry,
deal for the $'s.
Kurt Horvath
95 PT-42 WLWB
NOS unit.
warranty.
Email: "customerservice%40xantrex.com"
f: (360) 435-2636
To: "customerservice%40xantrex.com"
To: <"customerservice%40xantrex.com">
Dear Mr.Nick Klien.
Kurt Horvath
--- In "WanderlodgeForum%40yahoogroups.com", Terry Neal wrote:
> Hi Kurt,
replace
find
> Terry
> > Kurt Horvath
> > 95 PT-42
> > Dear Kurt Horvath,
RV3012M
only
series
models
> > were:
> > BAT CAPACITY – AUTO
> > CHARGE RATE – 80%
has
enhancements
> > cost be?"
a "google"
available
freedom
if
email.
> > Technical Support
contain
or
be
> > model
to
> > Kurt Horvath
> > , "Dorn Hetzel"
> > > From: Nick Klein
> > > To: "dorn@"
> > > Dear dorn,
> > explanation:
which
> > were
> > used for
> > default
> > RC7GS
> > > Setup Menus".)
> > Otherwise they
> > had no other
> > models were:
> > > BAT CAPACITY - AUTO
> > > CHARGE RATE - 80%
> > include the
> > > Technical Support
> > attachments, is
confidential
> > and
disclosure or
recipient,
> > please
> > original
> > > message.
> > other
> > models still
Curt Sprenger
Anaheim Hills, CA
05-30-2008, 04:59
RV 3012 M
Thanks Kurt. Nice report.
I too was getting differing stories from different people. One of the
techs at Xantrex told me Sun Electronics wasn't even an authorized
dealer or distributor & there was no record of them in their
listing. Of course, he didn't speak English that I could understand
real well so he may have be sitting in Bombay? Also, he kept saying
there was no RV 3012 "M" inverter either.
In my PT, to install an inverter outside the engine compartment means I
change a lot of wiring. Yours is probably the same. May be the best
solution though. I was also thinking I may be able to build a
compartment where the Rediline used to be and put it in there? Like
your idea of running a couple of ACs with the Detroit while underway.
I take it you are going to wire your system with the Gen Start
feature. That would be a good idea too.
Do you have a time frame for all of this? I may wait a little while to
see how you accomplish all of the changes. Please share your progress
with us. I much appreciate it.
Terry
Terry Neal
Bozeman, MT
82PT40 6V92TA
74FC34 6V53T
bumpersbird wrote:
Terry,
deal for the $'s.
Kurt Horvath
95 PT-42 WLWB
NOS unit.
warranty.
f: (360) 435-2636
Dear Mr.Nick Klien.
Kurt Horvath
Terry Neal "bird@..." wrote:
> Hi Kurt,
replace
find
> Terry
panel
set
> > Kurt Horvath
> > 95 PT-42
> > Dear Kurt Horvath,
RV3012M
were
only
series
section
regular
same.
models
> > were:
> > BAT CAPACITY – AUTO
> > CHARGE RATE – 80%
series.
largely
has
that
enhancements
> > cost be?"
do not
a "google"
available
freedom
model.
fine
if
to
email.
> > Technical Support
contain
review,
model
or
RV3012 M
be
be?Can
> > model
coach.
unites
am in
time
to
> > Kurt Horvath
> > <"Wanderlodge"Forum%40yahoogroups.com>,
"Dorn Hetzel"
> > > From: Nick Klein >
> > > To: "dorn@"
> > > Dear dorn,
an
> > explanation:
RV3012M,
which
> > were
only
> > used for
series of
> > default
on "RC7
> > RC7GS
> > > Setup Menus".)
factory.
> > Otherwise they
version, and
> > had no other
standard
> > models were:
> > > BAT CAPACITY - AUTO
> > > CHARGE RATE - 80%
sure to
> > include the
> > > Technical Support
any
> > attachments, is
confidential
> > and
disclosure or
recipient,
> > please
copies of the
> > original
> > > message.
RV3012M and
> > other
these
> > models still
