Air leak
05-25-2005, 07:50
Air leak
nope- the step- directly inboard of the cornering lamp. ernie
[Non-text portions of this message have been removed] |
05-25-2005, 10:19
Air leak
Right behind the cornering lamp at my entry step is a small 1 inch
diameter by 5 inch long cylinder with an air line that comes to it. The cylinder is leaking out the end of it- only with the step retracted. Is this a rebuildable item or is a new purchase warranted. Ernie-83PT40 in texas |
05-25-2005, 11:17
Air leak
is this for the step well cover? randydupree93wb
----- Original Message ----- From: Ernest Ekberg To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 25, 2005 6:19 PM Subject: [WanderlodgeForum] Air leak Right behind the cornering lamp at my entry step is a small 1 inch diameter by 5 inch long cylinder with an air line that comes to it. The cylinder is leaking out the end of it- only with the step retracted. Is this a rebuildable item or is a new purchase warranted. Ernie-83PT40 in texas ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-25-2005, 11:55
Air leak
ok,ohh,is it the cyl that locks the step out? if so i think its a bimba brand
cyl. look online at http://www.surpluscenter.com...randydupree93wb ----- Original Message ----- From: erniecarpet@... To: WanderlodgeForum@yahoogroups.com Sent: Wednesday, May 25, 2005 7:50 PM Subject: Re: [WanderlodgeForum] Air leak nope- the step- directly inboard of the cornering lamp. ernie [Non-text portions of this message have been removed] ------------------------------------------------------------------------------ Yahoo! Groups Links a.. To visit your group on the web, go to: http://groups.yahoo.com/group/WanderlodgeForum/ b.. To unsubscribe from this group, send an email to: WanderlodgeForum-unsubscribe@yahoogroups.com c.. Your use of Yahoo! Groups is subject to the Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
05-25-2005, 14:16
Air leak
ebay for air cylinders just measure and bid
got your letter thanks Stephen 77fc35 --- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > Right behind the cornering lamp at my entry step is a small 1 inch > diameter by 5 inch long cylinder with an air line that comes to it. The > cylinder is leaking out the end of it- only with the step retracted. Is > this a rebuildable item or is a new purchase warranted. Ernie-83PT40 in > texas |
05-26-2005, 00:46
Air leak
Stephen,
That cylinder is a one way job.... spring return...when the rod gets bent a little, which it does when it acts as a safety latch, air will leak around the rod and it gets harder to retract as the spring does not have enough umph to push it back... poor design.. blair in oregon At 07:16 PM 5/25/2005, you wrote: >ebay for air cylinders just measure and bid >got your letter thanks >Stephen 77fc35 > > > > >--- In WanderlodgeForum@yahoogroups.com, "Ernest Ekberg" > > > Right behind the cornering lamp at my entry step is a small 1 inch > > diameter by 5 inch long cylinder with an air line that comes to it. The > > cylinder is leaking out the end of it- only with the step retracted. Is > > this a rebuildable item or is a new purchase warranted. Ernie-83PT40 in > > texas > > > > >---------- >Yahoo! Groups Links > * To visit your group on the web, go to: > * > <http://groups.yahoo.com/group/WanderlodgeForum/>http://groups.yahoo.com/group/W\ anderlodgeForum/ > > * > * To unsubscribe from this group, send an email to: > * > odgeForum-unsubscribe@yahoogroups.com > > * > * Your use of Yahoo! Groups is subject to the > <http://docs.yahoo.com/info/terms/>Yahoo! Terms of Service. [Non-text portions of this message have been removed] |
02-12-2006, 14:26
Air leak
Hi all,
I wonder if there is anyone here who might help me figure out an air leak on a 1987 PT40. I have posted a photo in the photos section in LWatson album. The part that is leaking is located curb side in the engine compartment between the batteries and the engine. I'm guessing I will probably have to replace it, whatever it is, but not sure where to get one. Any help would sure be appreciated. Thanks, Larry Watson '87 PT40 Greensboro, GA (about half way between Atlanta and Augusta) |
02-12-2006, 14:45
Air leak
Larry:
That is the pressure reducing valve/regulator, BB part number # 1089436. It reduces the coach air to 80 to 90 psi for the cruise control and is also part of the air throttle air system. Safe travels, Ralph and Charolette Fullenwider Duncan, Oklahoma 580-574-2768 Ralph's RV Solutions http://home.swbell.net/rlf47/index At 02:26 AM 2/13/2006 +0000, you wrote: >Hi all, > >I wonder if there is anyone here who might help me figure out an air >leak on a 1987 PT40. I have posted a photo in the photos section in >LWatson album. The part that is leaking is located curb side in the >engine compartment between the batteries and the engine. I'm guessing >I will probably have to replace it, whatever it is, but not sure where >to get one. Any help would sure be appreciated. > >Thanks, > >Larry Watson >'87 PT40 >Greensboro, GA (about half way between Atlanta and Augusta) > > > |
02-16-2006, 01:25
Air leak
Ralph,
Thank you very much for your reply. The new part is on the way from BB! By the way, Earl gave me a new/different part number than the one you have (1087436 vs 1089436)but when I questioned him he said he would gladly exchange it if the one I receive turns out to be the wrong one. I guess that's fair enough! We'll see! Anyway, thanks again! Larry --- In WanderlodgeForum@yahoogroups.com, "Ralph L. Fullenwider" > > Larry: > > That is the pressure reducing valve/regulator, BB part number # 1089436. It > reduces the coach air to 80 to 90 psi for the cruise control and is also > part of the air throttle air system. > > Safe travels, > > Ralph and Charolette Fullenwider > Duncan, Oklahoma > 580-574-2768 > Ralph's RV Solutions > http://home.swbell.net/rlf47/index > > > At 02:26 AM 2/13/2006 +0000, you wrote: > >Hi all, > > > >I wonder if there is anyone here who might help me figure out an air > >leak on a 1987 PT40. I have posted a photo in the photos section in > >LWatson album. The part that is leaking is located curb side in the > >engine compartment between the batteries and the engine. I'm guessing > >I will probably have to replace it, whatever it is, but not sure where > >to get one. Any help would sure be appreciated. > > > >Thanks, > > > >Larry Watson > >'87 PT40 > >Greensboro, GA (about half way between Atlanta and Augusta) > > > > > > > |
08-20-2006, 12:53
Air leak
I have an air leak in the front of my 78FC33. Lying on the ground
and reaching up in the left front there is what looks like a distribution valve. It has at least two thin black hoses attached with screw on caps. When I shut off the coach it leaks for a few minutes then stops. The brake tanks keep about 75 lbs of preasure, but the step stops working. There is a tube that is designed to have a rubber hose sliped over it on one side of the valve, I can't see it, but that is where the air is leaking from, It seemed odd that there would be a slip on connection when all the others are the standard black tube with a screw on connector. Does anyone have any idea what this valve may be for? I had read that the cruise control used air passing over a venturi to generate vacuume, could this be it? Thanks Gardner 78FC33 |
