Help with the warning buzzer in dash........
08-14-2008, 09:04
Hello.... 83 PT40 when I start the engine there is a warning buzzer
that is located behind the dash that will not quit..... my front & rear tire pressuer and water level appears to be OK..... what other issues and or system(s) does the warning buzzer sound off for???? Thank You Brian ... with "The Green Hornet" |
08-14-2008, 09:34
08-14-2008, 09:37
Brian I am sure you mean 'Front and rear air brake tank pressure'
and not 'tire pressure'? if you have an aux compressor and it is a pressure gauge hung up, you can try filling the tanks and then letting the tank pressure out mannualy several times and or just draining the tanks manualy ( good once a year practice) are you connected to shore electric? the 94 has a buzzer prompted by the transfer switch reading shore power. Are your jacks up and stowed? GregoryO'Connor 94ptRomolandCa . --- In WanderlodgeForum@yahoogroups.com, "t3brian" wrote: > > Hello.... 83 PT40 when I start the engine there is a warning buzzer > that is located behind the dash that will not quit..... my front & rear > tire pressuer and water level appears to be OK..... what other issues > and or system(s) does the warning buzzer sound off for???? > > Thank You > Brian ... with "The Green Hornet" > |
08-14-2008, 09:40
08-14-2008, 09:40
Could be air pressure is not up or it could be hydraulic jacks not
fully up. R.E. (Ron) Marabito, Dallas, TX 92WB40 Currently in Newfoundland --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Hello.... 83 PT40 when I start the engine there is a warning buzzer > that is located behind the dash that will not quit..... my front & rear > tire pressuer and water level appears to be OK..... what other issues > and or system(s) does the warning buzzer sound off for???? > > Thank You > Brian ... with "The Green Hornet" > |
08-14-2008, 10:12
You have a jack not fully retracted. Make the the front jacks are all
the way "kicked up" and that the rears have retraced fully. I have to use a floor jack to push one of my rear levelers up the last inch or so, if not I will get the buzzer intermittantly. Scott Forman 86 PT38 Memphis --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > Hello.... 83 PT40 when I start the engine there is a warning buzzer > that is located behind the dash that will not quit..... my front & rear > tire pressuer and water level appears to be OK..... what other issues > and or system(s) does the warning buzzer sound off for???? > > Thank You > Brian ... with "The Green Hornet" > |
08-14-2008, 12:57
Hello I have a buzzer in the dash going off after I either turn the key
to the on position or when the engine is started...... All of my fluids are topped off, oil pressure looks good, suspension pressure in front & back OK, any thoughts about what other systems this buzzer monitors???? Thank You Brian Prinkki with 'The Green Hornet' |
08-14-2008, 13:00
OK... thanks guys.... I am going to try to extend the HWL jacks.....
and make sure that they are fully retracted...... I am just now arriving home from work and I am going to give it a shot!!!!!!!!!!!!! Thank You --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > You have a jack not fully retracted. Make the the front jacks are all > the way "kicked up" and that the rears have retraced fully. I have to > use a floor jack to push one of my rear levelers up the last inch or > so, if not I will get the buzzer intermittantly. > > Scott Forman > 86 PT38 > Memphis > > --- In WanderlodgeForum@yahoogroups.com, "t3brian" > > > > Hello.... 83 PT40 when I start the engine there is a warning buzzer > > that is located behind the dash that will not quit..... my front & > rear > > tire pressuer and water level appears to be OK..... what other issues > > and or system(s) does the warning buzzer sound off for???? > > > > Thank You > > Brian ... with "The Green Hornet" > > > |
