Strange smoke
10-25-2008, 13:37
Strange smoke
Don't know if anyone has had this problem, but my generator apparently "lugged down" for a while.
Yes, I should've used glow plugs, but it had been facing the sun at College Station for hours. It started quickly, then I walked back to the thermostat and toggled through all three zones to change the settings from heat to cool. It took a minute or two to get things started. I went inside the building to take care of business, when someone burst into the restroom and told me my bus was smoking. Diesel smoke black as coal was coming out of the generator roof exhaust.
I immediately shut off the first AC at the cockpit and the generator smoothed out, sped up and the smoke cleared. I had no other trouble and suppose (hope) I didn't do any damage. That has never happened before.
If anyone has any thoughts.....
BradBarton00LXiDFW bbartonwx@...
Stay organized with simple drag and drop from Windows Live Hotmail. Try it
10-25-2008, 15:03
Strange smoke
I think the lug in our case wasnt that it was more effort than the
engine could handle but the demand for more rpm/spinn was so sudden
that the kubota couldnt progressivly turn the turbo to fan the
fire's. the demand prompted dumping too much fuel. the setup on
generator engines are diff than kubota tractors because they are
unmaned and this problem is typical. my kubota driven hydroseed
pumps have centrifugal goveners that 'regulate the release of'
or 'limit the delivery of' more fuel than can burn with that rpms
given air. May be your weights are stuck or sticking.
on a SOB friends '07 coach (Its not the other way), he has one of
those energy managemet systems that shut things down on the demand
side when the amp supply is low. While hooked into shore power one
ac kicking on would shut off other items. turned out to be the start
capacitor in the ac was screwed.
Greg94ptCa
. --- In WanderlodgeForum@yahoogroups.com, brad barton
> If anyone has any thoughts.....Brad Barton 00LXiDFW bbartonwx@...
> _________________________________________________________________
> http://windowslive.com/Explore/hotmail?
ocid=TXT_TAGLM_WL_hotmail_102008
10-26-2008, 02:44
Strange smoke
Change the air filter. I, too, got a "your bus is on fire" scare when
excessive black smoke was coming from the generator exhaust. Turns
out, when the air filter gets clogged up, it causes inefficient
combustion in the engine, generating a TON of black smoke. Once
you've replaced the air filter, open the lower exhaust exit, start
the generator, and be prepared for a huge pile of soot to blow out
(something for you to clean up...). You might prefer to locate
yourself where the soot-pile won't present a difficult problem. It
blows a fair way from the exhaust exit. (i.e. don't park next to a
white car.)
aeonix1@...
On the road at
> exhaust.
10-26-2008, 03:30
Strange smoke
Thanks Pete. That goes on my to-do list. It sure went away when I temporarily removed the electrical load.
Date: Sun, 26 Oct 2008 09:44:52 -0400
Subject: Re: [WanderlodgeForum] Strange smoke
white car.)
"aeonix1@mac.com"
On the road at
> exhaust.
> Brad Barton 00LXiDFW "bbartonwx@hotmail.com"
When your life is on the go—take your life with you. Try Windows Mobile® today
10-26-2008, 03:36
Strange smoke
Greg,
That sounds reasonable. I'll have it checked. Thanks.
Date: Sun, 26 Oct 2008 03:03:08 +0000
Subject: [WanderlodgeForum] Re: Strange smoke
Greg94ptCa
. --- In "WanderlodgeForum@yahoogroups.com", brad barton
Store, manage and share up to 5GB with Windows Live SkyDrive. Start uploading now
10-26-2008, 11:01
Strange smoke
No load, not much fuel draw, not much air required = no smoke.
aeonix1@...
On the road at Ft. Chiswell, VA
> From: aeonix1@...
> white car.)
> Pete Masterson
> aeonix1@...
> On the road at
> > exhaust.
> Mobile® today
