Refir LP and LP Heat Switch
11-06-2008, 12:31
I have been having sporadic luck getting my refir to work on LP. This
evening, I have determined that it appears that it will only work on LP when the "LP Heat" switch on the dash is in the on position. Anyone have any opinion why this would be? One should have nothing to do with the other. Scott Forman 86 PT38 Memphis |
11-06-2008, 13:21
Wonder if running a flame on the cooktop with the lp heat off would
prove ;refer working on lp. that may show some issue with the regulator not opening up for a minor referboiler flame????? or air in line. if lp tank is pushing air that fails to ignite the flame on the referboiler and the heaters running purges the line continously????? might be more evident on the cooktop performance my 94pt has a lpg master switch. maybe there is one on the 86pt that is automatic with the dash 'lpHeat' switch??? new fan mod could be blowing out the flame??? Greg94ptCa --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > I have been having sporadic luck getting my refir to work on LP. This > evening, I have determined that it appears that it will only work on LP > when the "LP Heat" switch on the dash is in the on position. Anyone > have any opinion why this would be? One should have nothing to do with > the other. > > Scott Forman > 86 PT38 > Memphis > |
11-06-2008, 15:06
Scott,
Over the years, I've chalked alot of LP gas prolems up to faulty pressure regulators. If you are still using the original ones, it might be time for some replacements. They don't cost too much and do eventually clog and/or wear out. Shane Fedeli 85PT40 Hershey, PA --- In WanderlodgeForum@yahoogroups.com, "Scott Forman" <scottforman75@...> wrote: > > I have been having sporadic luck getting my refir to work on LP. This > evening, I have determined that it appears that it will only work on LP > when the "LP Heat" switch on the dash is in the on position. Anyone > have any opinion why this would be? One should have nothing to do with > the other. > > Scott Forman > 86 PT38 > Memphis > |
11-09-2008, 16:02
<scottforman75@...> wrote: > Ed Gardels 89sp Arlington Texas Scott.. I had the exact same problem in my 89sp, and your right, you hace to have the lp heat sw on > I have been having sporadic luck getting my refir to work on LP. This > evening, I have determined that it appears that it will only work on LP > when the "LP Heat" switch on the dash is in the on position. Anyone > have any opinion why this would be? One should have nothing to do with > the other. > > Scott Forman > 86 PT38 > Memphis > |
11-10-2008, 05:12
I just went out to the 'Bird. The LP dash switch is in the off position. The frig. LP works in this off mode. Interesting.
On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels <"egardata@tx.rr.com"> wrote:
11-10-2008, 05:25
On myPT40-the 25 year old version. If the green lite is not on under the booth for the gas, there is no gas anywhere to be found, except in the LP tank
Ernie Ekberg 83PT40 Weatherford, Texas |
11-10-2008, 05:53
On our 88 FC, which has many of the same schematics as the PT's.
The LP Heat dash switch controls 12 volts to the Suburban Furnaces. So if the thermostats are set to ON and calling for heat the Suburbans will ignite. The Propane detector/ auto propane shut off solenoid, is wired through the Electronic Master. So the Electronics Master switch must be turned "ON", to make the Propane flow. --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > I just went out to the 'Bird. The LP dash switch is in the off position. > The frig. LP works in this off mode. Interesting. > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels > > > --- In WanderlodgeForum@yahoogroups.com > > "Scott Forman" > > <scottforman75@> wrote: > > > Ed Gardels 89sp > > Arlington Texas > > > > > > Scott.. I had the exact same problem in my 89sp, and your right, you > > hace to have the lp heat sw on > > > > > I have been having sporadic luck getting my refir to work on LP. > > This > > > evening, I have determined that it appears that it will only work > > on LP > > > when the "LP Heat" switch on the dash is in the on position. > > Anyone > > > have any opinion why this would be? One should have nothing to do > > with > > > the other. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
11-10-2008, 05:55
Post 38916 Signature,
Bill 88 FC Michigan --- In WanderlodgeForum@yahoogroups.com, "pattypape" wrote: > > On our 88 FC, which has many of the same schematics as the PT's. > The LP Heat dash switch controls 12 volts to the Suburban Furnaces. > So if the thermostats are set to ON and calling for heat the > Suburbans will ignite. > The Propane detector/ auto propane shut off solenoid, is wired > through the Electronic Master. So the Electronics Master switch must > be turned "ON", to make the Propane flow. > > --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > > > > I just went out to the 'Bird. The LP dash switch is in the off > position. > > The frig. LP works in this off mode. Interesting. > > > > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels > > > > > --- In WanderlodgeForum@yahoogroups.com > > > "Scott Forman" > > > <scottforman75@> wrote: > > > > Ed Gardels 89sp > > > Arlington Texas > > > > > > > > > Scott.. I had the exact same problem in my 89sp, and your right, > you > > > hace to have the lp heat sw on > > > > > > > I have been having sporadic luck getting my refir to work on LP. > > > This > > > > evening, I have determined that it appears that it will only > work > > > on LP > > > > when the "LP Heat" switch on the dash is in the on position. > > > Anyone > > > > have any opinion why this would be? One should have nothing to > do > > > with > > > > the other. > > > > > > > > Scott Forman > > > > 86 PT38 > > > > Memphis > > > > > > > > > > > > > > > > > > > > > -- > > Curt Sprenger > > 1987 PT38 8V92 "MacAttack Racing" > > Anaheim Hills, CA > > > |
11-10-2008, 05:56
More than interesting; potentially dangerous? I thought that both the
master LP switch and the gas alarm always had to be on for the LP to work on anything LP. Could PO have modified the frig? Mike Bulriss 1991 WB40 "Texas Minivan" San Antonio, TX --- In WanderlodgeForum@yahoogroups.com, "Curt Sprenger" > > I just went out to the 'Bird. The LP dash switch is in the off position. > The frig. LP works in this off mode. Interesting. > > > On Sun, Nov 9, 2008 at 8:02 PM, Ed Gardels > > > --- In WanderlodgeForum@yahoogroups.com > > "Scott Forman" > > <scottforman75@> wrote: > > > Ed Gardels 89sp > > Arlington Texas > > > > > > Scott.. I had the exact same problem in my 89sp, and your right, you > > hace to have the lp heat sw on > > > > > I have been having sporadic luck getting my refir to work on LP. > > This > > > evening, I have determined that it appears that it will only work > > on LP > > > when the "LP Heat" switch on the dash is in the on position. > > Anyone > > > have any opinion why this would be? One should have nothing to do > > with > > > the other. > > > > > > Scott Forman > > > 86 PT38 > > > Memphis > > > > > > > > > > > > > -- > Curt Sprenger > 1987 PT38 8V92 "MacAttack Racing" > Anaheim Hills, CA > |
11-10-2008, 06:28
I don't use the lp on my refer or stove much. I found that if i turned on the stove and got the gas flowing to it, then i was able to get the refer to work on the lp side. Jim Riordan Stuart Fl Curt Sprenger
