Dash heat working.
11-20-2008, 16:03
Dash heat working.
I have dash heat now. I ended up replacing the gate valve on the
return line with a ball valve. I was able to remove the guts from the
gate valve to check it. Upon re-assembly, I noticed the valve handle
was moving in and out. Turns out, the gate was staying closed and the
handle was doing the moving.
It was so close to the frame, that the only way to get it out was
either remove the water pump or modify the frame rail. I opted to
modify the frame rail. With a carbide grinder blade I was able to cut
the top flange on an angle to gain sufficient clearance to remove the
valve. I also removed the guts to get the required clearance.
Dash heat now works well.
11-21-2008, 03:07
Dash heat working.
--- In WanderlodgeForum@yahoogroups.com, "ronmarabito2002"
Good job, Ron. Glad you have dash heat. Very interesting.
Regards,
Jack
Regards,
Jack and Liz Pearce
Fulltiming in a 1993 Wanderlodge WB40
D'Hanis, TX
