Aqua hot instrument panel switch
01-25-2009, 12:37
Be aware that there is an "Aqua Hot Users" forum within Yahoo Groups.
Just like this forum, it seems to be pretty active. Not having the
diesel portion of the Aqua Hot available during freezing weather is
ugly. I hope you get it fixed quickly.
One additional comment: The Aqua Hot/Vehicle Systems Inc. manuals are
among the best I have encountered for my ride. If you don't have one
run a Google search for Aqua Hot Manual. There are about three
different manuals if I recall correctly.
Just after I bought my bird I had a large dealer in OR repair my Aqua
Hot. In a few words: It was a disaster. I learned from that one
experience that I have got to learn the ropes on keeping this bird
flying. I quickly learned that that silver box is just full of nuts,
bolts and a few wires. With the aid of manuals I would be happy to
tackle almost anything in this box.
Good luck,
Eric Perplies
96' 42' WBWL
01-25-2009, 13:10
Not all Blue Birds are fortunate enough to use Aqua Hot products.
Some are Blue Bird built systems.
Ross
2006 LXi
01-26-2009, 00:47
Does anyone have any more info on the Aqua Hot owners?
Ernie-83PT40 in Texas
Subject: [WanderlodgeForum] Re: Aqua hot instrument panel switch
Date: Sunday, January 25, 2009, 7:10 PM
Ross
2006 LXi
01-26-2009, 05:56
Ernie, I called the Aqua Hot factory this past Monday and talked with
Tech Support. The guy I talked with said they were up and operating
and were accepting parts orders. I didn't press for more info.
Royal Washburn
--- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg
> From: Ross
> Ross
> 2006 LXi
01-26-2009, 06:22
Thanks Royal, probably an ongoing investigation.
Date: Monday, January 26, 2009, 11:56 AM
Royal Washburn
--- In "WanderlodgeForum%40yahoogroups.com", Ernie Ekberg
> From: Ross
> Ross
> 2006 LXi
01-26-2009, 09:54
Searching the Internet -- there doesn't seem to be any news beyond the initial reports, so far. Try searching Google on "Enander murder Colorado" ...
El Sobrante CA
"aeonix1@mac.com"
To:"WanderlodgeForum@yahoogroups.com"
Ross
2006 LXi
_
01-26-2009, 10:05
I looked, Pete, and there is no updates.
83PT40
Wanderlodge
http://autos.yahoo.com/group/erniesremodelingandrepair
Sent: Monday, January 26, 2009 3:54:07 PM
Subject: Re: [WanderlodgeForum] Re: Aqua hot instrument panel switch
El Sobrante CA
"aeonix1@mac.com"
Ross
2006 LXi
_
01-27-2009, 06:42
Pete,
There was a time prior to Oct last year that I would have said the
same thing.
When my AH got intermittent, like Hish, and then failed to satrt on
diesel at all, I went through the normal (by the manual) and even
abnormal trouble shooting. I consider myself pretty knowledgeable on
the AH. Thanks to Johnny at Bleakley in Unidilla, he fixed it in a
relatively quick fashion. Turns out it *WAS* the dash switch. All
measurements across it were good, it only failed after the purge cycle
when switched on. The purge cycle doesn't draw as much current as the
burner cycle so when the purge timed out and the controller called for
ignition, the switch went high resistive and not enough voltage at
igniter and faulting out.
Replaced the $3.98 switch and all is and has been well.
Paul
97WB43
Leaving sunny *warm* Florida tomorrow for the snow and cold at home Sad
> If the AquaHot fails to start, it will turn off the light and the
> diesel won't run. Discuss this with your AquaHot technician. If the
> switch is bad, the AquaHot won't cycle on at all.
> Pete Masterson
> <http://www.aeonix.biz/BBforsale.html>
> El Sobrante CA
> aeonix1@...
> On Jan 24, 2009, at 5:12 AM, Hisham Amaral wrote:
> > My instrument panel switch goes dead (light goes out and the diesel
> > does not run) after leaving it on for a couple of days. I usually rest
> > set it and the diesel starts and runs for a couple of day then the
> > switch goes dead again and must be reset. My question, is the switch
> > bad or is there something else going on in the system? Any advise is
> > welcomed.
> > Hisham Amaral
> > 97 Wanderlodge 43'
> > Titusville,FL for the winter
01-27-2009, 07:29
Wow! ... one of those subtle things. I did have my dash switch go bad ... and the symptom was that the AquaHot (and the little green light) simply didn't come on. Before the switch completely failed, I had the green light goes out thing, too. I didn't realize that there was a low-amperage draw that was affected by resistance in the switch. The technician did a complete annual service on the A-H at the time he found and replaced the dash switch, so I assumed that the service had "solved" the quitting behavior -- it never occurred to me that it was (probably) the dash switch going bad....
One of the continuing headaches with the WL (and I suppose nearly every RV) is the very long runs of 12 vdc wires. Resistance and voltage drop becomes a significant factor. When I had my pilot's license, the small aircraft I rented almost always had 24 vdc wiring (unless they were very old) -- While 24 volt circuits cause some headaches with finding bulbs, etc. it's almost too bad that RVs didn't standardize at 24 so that some of these problems would be less... Indeed, most busses use 24 vdc instead of 12 vdc...
El Sobrante CA
"aeonix1@mac.com"
On Jan 27, 2009, at 10:42 AM, p_a_lazar wrote:
Pete,
same thing.
Paul
97WB43
--- In "WanderlodgeForum@yahoogroups.com", Pete Masterson
El Sobrante CA
aeonix1@...
welcomed.
Hisham Amaral
97 Wanderlodge 43'
Yahoo! Groups Links
<*> Your email settings:
(Yahoo! ID required)
01-27-2009, 09:08
Hisham, there is a forum for hydronic heat on yahoo that has info if
you are not able to find your answer here.
Greg ofTim&Greg 94ptca
--- In WanderlodgeForum@yahoogroups.com, "Hisham Amaral"
rest
> welcomed.
> Hisham Amaral
> 97 Wanderlodge 43'
