Polarity indicator removal/replacement 1980 FC33
03-15-2009, 06:54
Trying to pull the polarity indicator to cure the GFCI trip problem. Pulled the
screws easy enough, but it doesn't want to come out. No rear access as far as I
can tell. Managed to destroy the voltmeter on one in my clumsy attempts. Any
tips or tricks? Should I just plan on completely replacing them both?
John Churchill
1980 FC33
LARGE MARGE
Sanibel, FL
03-15-2009, 10:31
I had a similar problem and got it out by removing the entire panel but the way
it finally came off, I'm not sure I'd ever get it back in.
I bought one of the Progressive surge protectors w/ indicator and may put the
indicator in the same place.
There are SO MANY things that you nearly have to destroy to remove.
Regards,
GPSGary
1984FC35SB
03-15-2009, 11:00
Gary, I was going to replace my generator remote start switch in that panel. After I took the panel off the wall and saw all that wiring, I thought that my generator switch on the upper dash works just fine.
Ernie Ekberg-- electrically challenged
83PT40
Wanderlodge
--- On Sun, 3/15/09, hippieforever3 wrote:
Subject: [WanderlodgeForum] Re: Polarity indicator removal/replacement 1980 FC33
Date: Sunday, March 15, 2009, 4:31 PM
I had a similar problem and got it out by removing the entire panel but the way it finally came off, I'm not sure I'd ever get it back in.
I bought one of the Progressive surge protectors w/ indicator and may put the indicator in the same place.
Regards,
GPSGary
1984FC35SB
