Proper way to tow a Wanderlodge
03-02-2009, 04:07
Post: #21
You don't need to remove the generator crossbar if the tow truck has the long extension forks to put on the lift, I had my PT40 towed this way and the guy had different length extension forks to exend from the lift arms up to the front axle, thisallowed him to stay clear of the generator crossbar.
Wayne PT40
Sent: Sunday, March 1, 2009 9:07:48 PM
Subject: [WanderlodgeForum] Re: Proper way to tow a Wanderlodge
Scott,
Thanks. Seems like the opinions vary a great deal. I thought it
would be important to know this just in case. And, knowing I need to
remove the crossbar is important as well. I assume removing the
crossbar isn't going to allow the tow gear from crushing the
generator.
Jerry
85 PT40
Port Hueneme, CA
--- In "WanderlodgeForum%40yahoogroups.com", "Scott Forman"
<scottforman75@ ...> wrote:
> Jerry,
> Had my PT towed about 18 months ago. It requires removing the
> driveshaft and, of course, an air line to the brakes to keep the
> parking brakes released.
> Another tip...the crossbar that crosses under the generator
> compartment needs to be removed or it will be bent by the boom for
> the wheel
lift. When I got my coach, this crossmember was bowed
up,
> and I always wondered why. I figured it out when I had the tow and
> saw the lift boom slide right into that "nook". It creates no
problem
> to have it bent, but removing it is probably the right way to go.
> Scott Forman
> 86 PT38
> Memphis
> --- In "WanderlodgeForum%40yahoogroups.com", "jburgessx2"
> > Just to satisy my curiosity, I would like to know the proper way
to
> tow
> > my 85 PT40. I don't plan on having it towed but it would be nice
> to
> > know if the situation arises - it never hurts to plan ahead.
And,
> > sometimes the tow truck folks don't know or think they know and
> they
> > are wrong.
> > Thanks.
> > Jerry
> > 85 PT40
> > Port Hueneme, CA
03-02-2009, 05:13
Post: #22
Some may be aware of the big problem in towing these coaches...
When I call for a tow, I strongly state, "This is a 31' Wanderlodge,
a big, heavy coach. The front axel is some 5' behind the front
bumper. The weight is over 30,000#. We need a BIG tow rig".
So when the tow truck finally does arrive, the driver looks at the
Bluebird, and says, "Gee, I should of brought our big truck"!
Go figure......
Jack Smith
1973FC31
--- In WanderlodgeForum@yahoogroups.com, "jburgessx2"
> Scott,
to
> generator.
> Jerry
> 85 PT40
> Port Hueneme, CA
> --- In WanderlodgeForum@yahoogroups.com, "Scott Forman"
> <scottforman75@> wrote:
> > Jerry,
for
> > the wheel lift. When I got my coach, this crossmember was bowed
> up,
> problem
> > Scott Forman
> > 86 PT38
> > Memphis
way
> to
> > tow
nice
> > to
> And,
> > they
> > > are wrong.
> > > Thanks.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-02-2009, 07:23
Post: #23
Wayne,
Thanks! Appreciate the info.
Jerry
85 PT40
Port Hueneme, CA
--- In WanderlodgeForum@yahoogroups.com, Wayne Kotila
from the lift arms up to the front axle, this allowed him to stay
clear of the generator crossbar..
> Wayne PT40
> ________________________________
> From: jburgessx2
> Scott,
to
> generator.
> Jerry
> 85 PT40
> Port Hueneme, CA
> --- In WanderlodgeForum@ yahoogroups. com, "Scott Forman"
> <scottforman75@ ....> wrote:
> > Jerry,
for
> up,
> problem
> > Scott Forman
> > 86 PT38
> > Memphis
> > --- In WanderlodgeForum@ yahoogroups. com, "jburgessx2"
way
> to
> > tow
nice
> > to
> And,
> > they
> > > are wrong.
> > > Thanks.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-02-2009, 07:44
Post: #24
I forgot to mention and remembered when someone else commented about airing up the system to release the drive axle brakes, you can just release the back brakes by popping the little plastic covers of the round air brake pods. One one each side of axle, and thru the hole the plastic cover was in you can back off the brakes, this way you don't need to air up the system.
Wayne
Sent: Monday, March 2, 2009 1:23:07 PM
Wayne,
Jerry
85 PT40
Port Hueneme, CA
--- In "WanderlodgeForum%40yahoogroups.com", Wayne Kotila
> Wayne PT40
> ____________ _________ _________ __
> From: jburgessx2
> Scott,
to
> generator.
> Jerry
> 85 PT40
> Port Hueneme, CA
> > Jerry,
for
> up,
> problem
> > Scott Forman
> > 86 PT38
> > Memphis
way
> to
> > tow
nice
> > to
> And,
> > they
> > > are wrong.
> > > Thanks.
> > > Jerry
> > > 85 PT40
> > > Port Hueneme, CA
03-02-2009, 08:43
Post: #25
Ernie is right... I had our coach towed once ( when the Allison took a dump ) and they used wheel forks and tied it down and took the axel out starboard side. The trick was to put the coach up in the air just to get the forks under the coach ....thanks to the checked and split air bags an some blocks... that was the only way to get it high enough. In any case that got me out of the intersection.Tanks Coach Net and CPS
Scooter2000LX Ocqueoc MI
Date: Sun, 1 Mar 2009 11:08:59 -0800
Subject: Re: [WanderlodgeForum] Re: Proper way to tow a Wanderlodge
"take out wallet"- or just purchase Coachnet service for a little over a hundred bucks a year.
83PT40
Wanderlodge
Date: Sunday, March 1, 2009, 10:50 AM
real big truck with a wheel lift or stinger be sure to tell them it
has a 5 foot setback front axle and weighs 40,000 lbs
disconnect drive shaft OR pull rear drive axles Drive shaft is cleaner
but is Necessary to climb under coach to disconnect drive shaft
TAKE APPROPRIATE PRECAUTIONS OR SOMEONE WILL DIE
take out wallet
leave credit card with driver
Stephen 77fc35
--- In "WanderlodgeForum@yahoogroups.com", "jburgessx2"
> Just to satisy my curiosity, I would like to know the proper way to tow
> my 85 PT40. I don't plan on having it towed but it would be nice to
> know if the situation arises - it never hurts to plan ahead. And,
> sometimes the tow truck folks don't know or think they know and they
> are wrong.
> Thanks.
> Jerry
> 85 PT40
> Port Hueneme, CA
03-02-2009, 14:48
Post: #26
I had my FC towed twice. One truck lifted by the front axel and the
other lifted by the front tires. The first place couldn't handle the
transmission swap, hence the second tow. Both tow vehicles had air
hookups to fill the air suspension, but mainly to release the spring
brakes. On mine they removed one axel shaft. Since the transmission
had crapped out, I wasn't that worried about damaging it. I would
think that if one shaft was still engaged, it might spin the drive
shaft while towing. I would think something should be done to prevent
the shaft from turning.
Gardner
83FC35
--- In WanderlodgeForum@yahoogroups.com, Al Scudder
enough. In any case that got me out of the intersection. Tanks Coach
Net and CPS
> From: ernietex@...
> Ernie Ekberg
> 83PT40
> Wanderlodge
> Weatherford, Tx
> --- On Sun, 3/1/09, Stephen Birtles wrote:
> From: Stephen Birtles
cleaner
> take out wallet
> Stephen 77fc35
to tow
to
they
> > are wrong.
> > Thanks.
> > Jerry
> > 85 PT40
> > Port Hueneme, CA
03-02-2009, 15:30
Post: #27
Whether one axle turns (because the other has been removed) or both axles turn
(because the drive shaft has been disconnected) does not matter. The
differential is properly lubed by just turning, and in both cases the
transmission will not turn which is the point.
Don Bradner
90 PT40 "Blue Thunder"
>Gardner
>83FC35
03-02-2009, 18:18
Post: #28
When all else fails
ALLISON
Operator's Manual
AT, MT, HT Series
On-Highway Transmissions
Allison Transmission
AT 540
AT 542(N)®(NFE)
AT 543
AT 545(N)®
AT 1542P
AT 1545P(N)
MT 640, MT(B) 643, MT 643R, 644, 647
MT 650, MT(B) 653, 654CR
HT 740(D)(RS)(FS)
HT 747(D)
HT 750CRD, HT 750DR (DB)(RS)
HT 750DRI, HT 750DRD (DB)
HT 754CRD, HT 754CR (RS)
TOWING OR PUSHING
PARKING BRAKE
On a vehicle with no P (Park) position on the transmission shift
selector, always put
the selector in N (Neutral) and apply the parking brake (or emergency
brake if the
vehicle is not equipped with a parking brake) to hold the vehicle
when it is unattended.
CAUTION: Failure to disconnect the driveline or remove the axle
shafts before towing or pushing can cause serious transmission
damage.
The engine cannot be started by towing or pushing. Before towing
or pushing a vehicle, disconnect the driveline or lift the drive
wheels off the road. If the vehicle is a motor coach, remove the axle
shafts from the drive wheels. When the axle shafts are removed, be
sure to cover the wheel openings to prevent loss of lubricant and
entry
of dust and dirt. An auxiliary air supply will usually be required
to actuate the vehicle brake system.
Kurt Horvath
95 PT 42
10AC
axles turn (because the drive shaft has been disconnected) does not
matter. The differential is properly lubed by just turning, and in
both cases the transmission will not turn which is the point.
> Don Bradner
spring
transmission
prevent
> >Gardner
> >83FC35
03-03-2009, 04:43
Post: #29
Remove axle shaft???? is this in lue of removing a drive line? May be
this is done so the tow driver doesnt have to crawl under the bus?
The rear is not allison so I cant see where they predict damage at
the rear to demand you render motorchoach rear not moving during a
tow????? Plus what lubes the hubs when you remove the axle shaft. you
will need to displace the lost volumn of the metal of the shaft to
get oil up to the hub?
For me I would pull the bus to a parking lot with a chain off a tow
truck (you need a tow truck for compressed air)then call a mobil
truck repair tech to determine that repair required the bus be shop
stored. When things go to a shop most of the hours it is there is
just parking effort. Mobil tech are working on your bus every hour
they are there.
Greg ofTim&Greg
94ptCA
In WanderlodgeForum@yahoogroups.com, "Kurt Horvath"
> When all else fails
> ALLISON
> Operator's Manual
> entry
> Kurt Horvath
> 95 PT 42
> 10AC
03-04-2009, 06:52
Post: #30
Never remove the axle tube rods and tow these units. You risk getting sand in the tubes and pumpkin. You can not cover or seal them effectively. If you must move the coach, you must drop the drive shaft of you tow for any distance more than 15 to 20 miles. Any amount of sand in the differential will be fatal right quick to the gears, shims and bearings and it will never come out. Short distance towing is ok with a front lift truck but long distance must be done on a lowboy or roll away bed.
Gary
--- On Tue, 3/3/09, timvasqz wrote:
From: timvasqz Subject: [WanderlodgeForum] Re: Proper way to tow a Wanderlodge
To:
Date: Tuesday, March 3, 2009, 11:43 AM
they are there.
Greg ofTim&Greg
94ptCA
In WanderlodgeForum@ yahoogroups. com, "Kurt Horvath"
> When all else fails
> ALLISON
> Operator's Manual
> entry
> Kurt Horvath
> 95 PT 42
> 10AC
