Lean fixed- That was EASY!!!
03-14-2009, 09:45
LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I
had asked my mechanic to look at it along with some other stuff and it kind of got overlooked, so I've been trying to ignore it expecting a big expense. Finally, I did my homework by searching here, then slithered under the rear. I adjusted the height valve in about 5 minutes. Surprisingly, the nut was not frozen. Now I'm inspired. Everything else will be that easy and gratifying also right? |
03-14-2009, 09:46
--- In WanderlodgeForum@yahoogroups.com, "Robin"
> > LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I had asked my mechanic to look at it along with some other stuff and it kind of got overlooked, so I've been trying to ignore it expecting a big expense. Finally, I did my homework by searching here, then slithered under the rear. I adjusted the height valve in about 5 minutes. Surprisingly, the nut was not frozen. Now I'm inspired. Everything else will be that easy and gratifying also right? > Forgot to say who I am John Churchill Sanibel, FL 1980 FC33 "LARGE MARGE" |
03-14-2009, 11:02
03-14-2009, 12:22
--- In WanderlodgeForum@yahoogroups.com, Ernie Ekberg
> > " LARGE MARGE"-- classic!!! > > > Ernie Ekberg > 83PT40 > Wanderlodge > Weatherford, Tx > http://autos.groups.yahoo.com/group/erni...gandrepair She's named after the queen of our pack of chow dogs, Maggie, who is a full figure gal. I just put some pictures up of her lounging at the beach. http://groups.yahoo.com/group/Wanderlodg...8/pic/list JAC > > --- On Sat, 3/14/09, Robin > > From: Robin > Subject: [WanderlodgeForum] Re: Lean fixed- That was EASY!!! > To: WanderlodgeForum@yahoogroups.com > Date: Saturday, March 14, 2009, 3:46 PM > > > > > > > --- In WanderlodgeForum@ yahoogroups. com, "Robin" > > > > LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I had asked my mechanic to look at it along with some other stuff and it kind of got overlooked, so I've been trying to ignore it expecting a big expense. Finally, I did my homework by searching here, then slithered under the rear. I adjusted the height valve in about 5 minutes. Surprisingly, the nut was not frozen. Now I'm inspired. Everything else will be that easy and gratifying also right? > > > Forgot to say who I am > John Churchill > Sanibel, FL > 1980 FC33 "LARGE MARGE" > |
03-14-2009, 13:37
> > LARGE MARGE, my 1980 FC33 has been leaning to the right ever since I got her. I had asked my mechanic to look at it along with some other stuff and it kind of got overlooked, so I've been trying to ignore it expecting a big expense. Finally, I did my homework by searching here, then slithered under the rear. I adjusted the height valve in about 5 minutes. Surprisingly, the nut was not frozen. Now I'm inspired. Everything else will be that easy and gratifying also right? Which side does it lean too? I might suggest you either loose some weight or balance it out on the other side! I had that problem so I just left the wife home.
Jipjob Rebel Bird Bremerton > |
